Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-09-2003, 09:23 PM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Question Multi- ball Set Up
First, I need a new 2-5/16" ball. Anyone have luck with the ball sets with interchangeable balls. I want a 10,000# rating ball to pull cargo trailer too. Reese has such an animal.
Second, I have an old Eze-lift ball mount. No room to put socket on the 1" nut [1-1/2] across the flats. The bar sockets are too close. How do you tighten it!!! Thanks Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 04-10-2003, 12:07 PM   #2
zduke4x
zduke4x's Avatar
Profile:
multi-ball set-up
I have used these exchangeable ball set-ups for a long time...2" for box trailer and 2 5/16 for a 26' boat @ 6000 pounds plus and they are great....just be sure it has the 10,000 or greater post the balls go on, some are rated lower..... there are also several brands I've noticed that secure the ball differently.....mine is not a Reese...it has a pin the goes thru the ball and can be tightened from the top, I looked but couldn't see the maker but have seen then in many hitch shops.........lol..jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 04-10-2003, 03:47 PM   #3
niftypkg
niftypkg's Avatar
Cornville , Arizona
Multi-Ball Setup
Thanks, Dude. You are right, need the 10k set up!! Tough to tighted that nut; can't get any thing in there and I don't want to put a pipe wrench on it. Figure once it's tigtened just change the balls!!
Old 04-10-2003, 10:02 PM   #4
zduke4x
zduke4x's Avatar
Profile:
one clarification
The shank of my multi-ball at the top side of the base has 2 sides that are flat so a open wrench will tighten it from the top with a locknut on the bottom side...I probablly would give it a tug on the bottom if at all possible...went and found the smaller ball that I seldom use and no readable brand..sorry, but here in Fla. I have seen them often in towing/camping stores....jem
The Silver Buffalo
WBCCI # 14067
Hitch Ball Height RivetED Hitches 4 03-21-2004 09:25 PM
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches 2 12-07-2003 12:04 PM
silly ball height question. AV8 Hitches 7 11-09-2003 06:32 PM
Help-Hitch Ball problem Chitown AirStreamers Hitches 4 07-22-2003 01:35 AM
Ball Size on '70 Caravel? MattyBoy Hitches 3 01-06-2003 09:03 PM
