Old 10-31-2007, 08:03 PM   #1
Haze Grey & Underway
2008 27' Safari FB SE
Cedar Crest , New Mexico
Mud flap ground clearance?
How much ground clearance should my solid mudflap have above the road when towing to not pick up gravel etc. on bumps or dips. The instructions with the hitch mounted flaps had no specifics. Thanks.
hazegrey is offline   Reply With Quote
Old 10-31-2007, 08:07 PM   #2
_
hi 'grey
1-3 inches after hitching up and springing the spring bars...
are they enkays?
there are several threads here on the enkays...
search enkay or nk or rock tamers, for lots of pictures and tips...
cheers
2air'
Old 10-31-2007, 08:24 PM   #3
2air,
THey are Road Wings so they do not have the tilt capability of the enkays but hook to the hitch in a similar manner. R/Haze gray and underway.
Old 10-31-2007, 08:30 PM   #4
_
hi 'grey
i have no experience with the road wings...
someone who does will jump in soon.
IF they are as stiff as the enkays 1-3 inches is about right.
at 1 inch mine did drag when turning sharply or backing into some sites...
but none of this kicked up rocks.
they are now at about 2.5 inches when hitched and never drag...
cheers
2air'
Old 10-31-2007, 08:42 PM   #5
2air,
Thanks they are quite stiff so Friday when I take it in for survice I will probably take a little more off. R/ Haze grey and underway.
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 07:11 AM
Raise ground clearance on 25', '91 Excella? ldetsf Axles 11 10-18-2006 06:29 PM
What should the ground clearance be? 63air Towing, Tow Vehicles & Hitches 4 07-19-2006 01:01 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
how much ground clearance? Chuck Plumbing - Systems & Fixtures 1 05-26-2004 10:10 AM
