Old 09-02-2008, 12:46 PM   #1
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Question Mouse entrance via hitch...
My hitch is composed of what I was told is box channel. It is open at the hitch and allows for mice to enter the frame area under the subfloor in the trailer.
Does anyone know of a way to plug this entrance?
One side will have my plug for running lights- but wonder if I can spray some sort of expanding sealer in the tube to block varmants? Please let me know if you have figured out a way to block this entrance?
Tks, Z
Zstream is offline   Reply With Quote
Old 09-02-2008, 01:15 PM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
yeah- you could spray in some expanding foam, or fit a piece of screen over the opening, to keep the mice from getting in there. Check the back end of the rails too. Once in the belly pan area, there's all kinds of access holes into the interior. Mine were getting in from the plumbing access area, by the fresh water tank. Good luck!
tphan is offline   Reply With Quote
Old 09-02-2008, 01:19 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes the frame is hollow but there should not be any hole from the frame to the subfloor. The floor is screwed to the frame and no reason for any other passage between them.
If you have mice in the trailer I would look for another path. There are large holes around the plumbing that goes from above to below the floor.
2004 Excursion 4x4
Old 09-02-2008, 01:32 PM   #4
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Don't know how it is on a '91 or a '63, but on my '72 there most definitely are holes (like 3" diameter) on the sides of the main frame channels (for lightening?) allowing EASY access into the belly area.
Old 09-02-2008, 01:33 PM   #5
kstampa's Avatar
2004 28' International CCD
tampa , Florida
Images: 35
foam is just fun for mice. steel wool is a great void filler. you could sandwich the wool between foam fill to keep it in place. Got thick w/ the steel wool.
kstampa is offline   Reply With Quote
Old 09-02-2008, 01:41 PM   #6
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Hitch mouse door..
Thanks for the info. My trailer is gutted...that said... If a mouse enters the box channel hitch entrance at the ball area of the hitch...he can walk straight back into the trailer...as the channel is wide open. From there mice would be able to move about freely in the space between the belly pan and the subfloor. Looking for a way to block the channel space. FYI- had a similar entrance in the rear cargo/bumper area but a welder was able to block off that entrance after I redesigned the rear cargo box.
Old 09-02-2008, 01:45 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Another reason to plug the opening is that wasps, mud daubers, or bees may also discover this access and decide that it would make a wonderful new home. I had overlooked checking the material stuffed in that opening and had bees trying to establish a nest/hive in the underbelly. I didn't block the opening before departing on my trip to International, and somewhere along the road, a small brown squirrel decided that it made a nice home and couldn't be coaxed to leave the security of the underbelly until we were in Yellowstone -- the squirrel thrashed around in the underbelly of the Minuet immediately under my bed for three nights. My fall project is to do my best to premanently block these two openings and get the hitch painted in its original burnt orange.
Kevin
Kevin D. Allen
AIR #827
Old 09-03-2008, 10:51 AM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I would use aluminum screen - scrunch a square into a ball and stuff it in. I would not bother with steel wool.
Pat
pmclemore is offline   Reply With Quote
Old 09-03-2008, 01:37 PM   #9
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Here's a pic of what the frame of a '72 looks like, complete with holes. The smaller hole you see is at the end of the Y-frame coming from the hitch, and is larger than a mouse. The larger holes are in the main frame, under the kitchen area. At least one of them is in the plumbing well, inside the kitchen cabinet, in the box the fresh water tank sits in. Very easy access from open frame under hitch to interior of coach- at least in the '72 models.
hitch, mice
Huge potential mouse entry on all Airstreams wacnstac Steps 15 02-14-2017 08:44 AM
mouse in my house Annemac General Interior Topics 6 08-24-2007 01:50 PM
A mouse in the house pittsf Off Topic Forum 12 08-21-2007 02:28 PM
Mouse problems 88Excella General Repair Forum 28 09-13-2005 09:19 PM
mouse mdlay General Repair Forum 13 02-28-2004 01:08 PM
