Old 01-15-2010, 06:26 PM   #43
_
Originally Posted by Jammer View Post
... The whole point behind WD bars is to keep the rear axle suspension of the truck in an area where the spring rate is lower...
not so.
the primary reasons for using w/d bars are...
- to RESTORE steering axle loads to the UNhitched/normal load...
-and because the RECEIVERs are rated higher than 'on the ball' ONLY when w/d gear is used.
_____________
the stream is stressed by high amplitude/low frequency bumps/holes, and low amplitude/high frequency stuff (road surface)
but MOST of the load rides on the trailer axles and tires, not the tongue.
one would need to measure the htz of each type of vibe over a LONG period and assess the reaction of the metal to this...
this can't be simply computer modeled, because of the hi VARIABILITY in build characteristics for each stream...
in any one year or decade, or model change or FRAME change or SHELL change (skin/rivets/ribs/floors) that's part of the product history.
the axle manufacturer has changed, the specs have changed, the tv have changed, tires have changed and so on...
60s or 70s data (if it existed and it doesn't) would NOT apply to ANY current 'stream.
they are built VERY DIFFERENTLY now.
this has been done for example with HUMANS riding/sitting in vehicles,
such that we now know when htz is most damaging to the human spine with prolonged exposures...
the differences between exposure to HIGH amplitude and LOW amplitude stuff on the spine.
____________
and the trailer frame flexes/extends/rotates when placed on the ball or with w/d tension...
this happens when PARKED as well as with movement.
but a 38 year old trailer with missing rivets or shell/frame issues is just an old trailer that's been used.
tired axles, old frame, old skin, old rivets and road weary and connected to a variety of mules over those 4 decades.
the skin/rivets are also stressed by WIND and air pressure while towing.
ANY aluminum riveted thing that old with miles would have loose/missing rivets or other signs of fatigue.
streams don't get inspected and regularly maintained like flying machines or boats as examples.
using 500 lb w/d bars with a 1000 lb tongue is POINTLESS for w/d unless the tv is otherwise modified.
_____________
much more on this stuff is posted here.
find the "body separation" thread and see hiho's work linked in post 35 above.
cheers
2air'
Old 01-15-2010, 07:37 PM   #44
Central , Mississippi
FCJ,
Really cool thread...
I just typed a long response...now gone into cyberspace...
I think real hitch/overhitch issues won't come from accel number but from stress gaging the A-frame.
It's easy to argue both sides of it. Big, sloppy vehicles allowing things to whip and flop things into pieces. Not much acceleration but a huge amount of energy in the low frequency, high ampliture sinusoids.
Tight suspensions that keep the ball from jumping up and down (Use a locomotive and the hitch will never bounce or move, thus never transfering any rivit popping energy into our egg like shells). But it does transfer small amplitude higher frequency energy that will cause cyclic failure.
Tight WD bars that lock stuff together and minimize flopping. Spingy Bars that don't pull on the A-frame...
As we know, the numbers tell the truth, not Cause-and-Effect speculating. I can say that new axles/Old axles, Heavy WD bars/No WD don't make much of a difference in the energy transfer from the road to the trailer.
Keep up the good work...ya got a few strain gauges and some paint stripper?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-10-2015, 06:49 PM   #45
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Still a great thread. Joe, did you continue with this test series elsewhere?
Old 01-10-2015, 07:07 PM   #46
2007 22' International CCD
Great stuff!
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 01-11-2015, 09:42 AM   #47
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by ROBERT CROSS View Post
Joe,
Just ordered this two days ago, tired of guessing.
Seems like a VG product, I'll let you know.
Sherline Trailer Tongue Weight Scales
I bought a Sherline last summer.....interesting, when I weighed the tongue the first time. I found that the weight on my 2001 30' Excella was about 125 pounds LESS than what some of the "experts" on here say it should be.
That being said, the next trip, we loaded a bunch of heavy stuff behind our recliners, and got the tongue weight up to 900 pounds. The trailer towed just fine before the increase in tongue weight, and there was no difference after I increased the weight...
For whatever it's worth
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 01-12-2015, 11:17 AM   #48
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Thanks Slow'
Haven't touched my accelerometer gear since this experiment.
Maybe my son and I could finagle this into his science fair project...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 01-12-2015, 11:50 AM   #49
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Inquiring minds want to know.
Sure beats papier- mâché volcanoes.
You know who to make it appear was doing the driving. And flying across the RR tracks with an external shot.
Boy, that would be fun.
Old 05-05-2015, 05:31 AM   #50
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Winston-Salem , North Carolina
Struggling with stuff shaking to pieces inside my 31' Excella. Uses a Reese hitch and TV is a Chevy 3500 HD dually. AS tech says axles and shocks are good. 1000 # bars, 6 links. Other than trading my TV any suggestions?
Raconteur, Bon Vivant, Curmudgeon, and other depending on Susan's mood at the time...Retired, so don't ask me to do a damn thing
oledawg is offline   Reply With Quote
Old 05-05-2015, 05:44 AM   #51
Dearborn , Michigan
Images: 21
I guess the first question I'd ask is; what do you mean by 'stuff shaking to pieces'?
- Tires balanced? I recently discovered tire balancing is like just about every other service out there- sometimes you don't get what you pay for. Had to go back to the tire shop twice, before they got it right on my Suburban.
The other item are your torsion bars. A '94 Excella 30' is listed as 750# tongue weight. I'm surprised you need (or are getting) any weight transfer at all with a 3500 dually.
Old 05-05-2015, 07:24 AM   #52
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I actually had one name brand national tire shop tell me that trailer tires do not have to be balanced. I took my tires out of there as fast as I could and went to another shop that is used by most of the RV/trailer dealers in my area.
MICHAEL
Old 05-07-2015, 05:44 PM   #53
I'm known at the local tire store as 'that guy that balances his trailer tires'
Old 05-08-2015, 04:33 AM   #54
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Leaf spring has such short range of motion in some common co figs that tire balance is something of a nonstarter
Old 05-08-2015, 06:12 AM   #55
Gainesville , Florida
I use 800 pound bars with my one ton. Very little weight transfer us needed, but a little is just enough. Sway control is more important. The ride inside is okay with these bars. I wouldn't use any heavier bars than that. Jim
Old 05-08-2015, 11:33 AM   #56
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
Campbell , California
Great test subject!!! This could be VERY VERY informative for users, hitch vendors, etc.
Thanks for thinking of this!
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Measuring Sofa dannyo General Interior Topics 0 03-28-2008 08:27 AM
market forces... Airstream prices... boondockdad Trailer Values 4 09-28-2007 07:38 AM
Measuring inverter output guy99 Electrical - Systems, Generators, Batteries & Solar 8 01-04-2007 07:24 PM
measuring propane pressure emanon25 LP Gas, Piping, Tanks & Regulators 2 09-27-2004 05:48 PM
propane, measuring pressure emanon25 LP Gas, Piping, Tanks & Regulators 4 09-20-2004 11:46 AM
