Old 06-19-2007, 12:03 PM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
measurements??
I am buying a new Equlizer hitch and need to know what the measurement is from the ground to the top of where the ball will be on a 1994 34'footer. The trailer is 900 miles away so I cant measure it myself. Also will I be o.k. with the 1000 lb. bars or do I need to use the 1200 lb. bars. I know at one time I could find weights and measurements at the Airstream site but now I cant seem to locate that area. Any help will be appreaciated.
Bing-Bing is offline   Reply With Quote
Old 06-19-2007, 12:28 PM   #2
ScottW's Avatar
Hernando , Mississippi
All airstreams lately have an 18.75" ball height. Maybe an expert can verify this.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-19-2007, 01:31 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Scott, you're as good as we've got! Looks like 18.75" is as close as Airstream is going to say. See the figures for 1992 I guess -- http://www.airstream.com/airstream/p.../weights-1.pdf
5 meter Langford Nahanni
Old 06-19-2007, 08:14 PM   #4
Bing-Bing's Avatar
1994 34' Excella
Thanks Scott and Bob I'll go with 18.75.
Old 06-20-2007, 08:23 AM   #5
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I am guessing (hoping?) you will have some tools with you to set up the hitch when you get there?
And for some level of comfort/safety while travelling?
Should take 5 mins to tweak the hitch...
Here is the link you are looking for...
Airstream :: Customer Services
Good luck, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 06-20-2007, 11:17 AM   #6
A proper ball height can only be determined, "after" you load your trailer.
Torsion axles are weight sensitive, therefore the more weight you add to the trailer, the lower the ball height will be.
Also, if you have a 3/4 ton rated tow vehicle, you should not use more than a 550 to 600 pound rating hitch bars.
A 1/2 ton truck can use 750 pound bars.
Excessive rated bars usually offer little sway control, but do offer severe damage to the shell of an Airstream trailer.
Friction type sway controls are motion restrictors, period. They have no idea if your rig is in a straight line. A Reese dual cam hitch offers sway control, using torsion, not friction. It does know when the rig is not in a straight line. When that happens, the torsion on the arms increase, helping the rig to return to that straight line. You can do that within reason, by taking your hands off the steering wheel.
The trailer must have a soft ride, that is defeated as soon as you use an excessive rated hitch with a heavy duty tow vehicle.
Damage to the trailer, in time, from excessive hitch ratings, will run into the thousands for proper repairs.
Old 07-03-2007, 07:10 PM   #7
Bing-Bing's Avatar
1994 34' Excella
I am buying the hitch at a dealer in greeley colo. and he will be installing it. He felt I needed the 1000 lb bars but I remember Andys post some time back explaining the bar issue and wondered if I might need lighter weight bars....
Old 07-05-2007, 09:44 AM   #8
What year and length trailer do you own?
What make and model tow vehicle do you have?
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Gaucho measurements for 65 Caravel krikles Cabinets, Counter Tops & Furnishings 3 06-02-2007 05:44 AM
65 OVerlander measurements kdenault Cabinets, Counter Tops & Furnishings 0 08-12-2006 06:20 AM
curtain measurements angie@smartw Upholstery, Blinds, Walls & Interior Finishes 6 01-14-2006 05:31 AM
Screen door measurements 85/345 General Motorhome Topics 7 09-18-2004 01:59 PM
