Old 10-18-2008, 05:43 PM   #1
Cracker's Avatar
Pittsfield , Maine
Masterlock Hitch Pin Cracks
I have a set of Masterlock locking hitch pins. One for the receiver and the other for the trailer latch - keyed alike. The pin for the receiver has a bushing over it to properly size it for the receiver hole and, upon unhooking last week, I noticed that the bushing was beginning to split longitudinally at one end for about one-half inch. My first impression was that it was a rather insignificant problem, but the more I thought about it, if the ends of this bushing deteriorate enough (---and fall out of place,) creating slop where the pin passes through the receiver walls, that could result in enough fore and aft slippage to generate a high shearing load on the pin and possible failure. I plan to contact Masterlock about the problem but, in the meanwhile I would advise anyone who has this lock to check it out. My locks are at least five years old - and possibly older if I used then on earlier trailers???
Cracker
Cracker is offline   Reply With Quote
Old 10-18-2008, 07:36 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You have defined the problem well.
I am not sure I would trust any pin that required a bushing unless the bushing was a hardened material to provide the strength of a normal hitch pin.
2004 Excursion 4x4
Old 10-19-2008, 06:19 PM   #3
Cracker's Avatar
Pittsfield , Maine
Well --- I thought that the bushing was just that - but apparently not!
Cracker
Old 12-24-2008, 10:22 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Master lock with sleeve.
Hi, I had that same lock set; And when I got home with my brand new trailer, I noticed the shaft was bent. This hitch lock made it from Eugene, Oregon to Lakewood, California. One trip and it was bent, so I bought another lock with a solid shaft [5/8"] and haven't had any problems since.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-28-2008, 08:08 PM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I bought one of those Master Lock pins with lock ... and when I got it home and took it out of the package and saw that it had that "shim plate / tube" thing, I decided just not ever to use it - just the look of it scared me. Based on your experience and the other writers' notes, I think I made the right decision. So, I wasted the money, but learned a lesson.
AirsDream is offline   Reply With Quote
Receiver Hitch pin hole repair ? Davis Hitches, Couplers & Balls 17 06-15-2017 06:03 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
Adjustable hitch by Masterlock Dan S Hitches, Couplers & Balls 4 05-31-2007 08:41 PM
A-frame cracks Inland RV Center, In Repairing/Replacing Floor &/or Frame 7 08-11-2005 09:28 PM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 12:42 PM
