I have what I think might be an odd problem. My hitch coupler appears to be worn out, bent, or in need of repair or rebuild. I am looking for any advice applicable.
The equipment:
1973 31' Sovereign-Marvel 2 5/16 inch trailer coupler with Eaz-Lift Load Distributing Hitch.
The symptom:
The hitch ball assemply ( the ball, the male side of the receiver hitch & spring bar receiver) will fall out of the coupler when in the coupler is in the latched position. Fully locked-Safety pin in.
So this means that the only thing keeping the coupler attached to the ball is the hitch or tongue weight and the downward force of the cocked load distributing spring bars. This scare me.
I only discovered this today after coming back from a 3,300 mile trip to Florida and back. I sometimes unhitch by uncocking the LD spring bars and using the electric jack to pickup the load/tongue weight-then remove the reciever hitch pin and pull away. This leaves the spring bars-sway control bar and hitch ball assembly all stored on the trailer-up off the ground (still latched in the coupler).
This seem unsafe at best.
1. Is this normal?
2. Has any one else experience this?
3. Can the couple components be rebuilt?
4. Would stretching/elongation of the vertical tension bar (connects the flip latch and the dog/pawl on the bottom) cause this)
5. Can I weld to build up the seat on the pawl/dog to correct this?
6. Is complete removal and replacement of the couple my only option?
I have seen some re-builds on utility trailers and a small flat bed, but never on a travel trailer. If it were mine, I would go for REPLACEMENT! You just have too much riding on that ball to rely on anything other than a perfectly functioning coupler.
1. Is this normal?
Trevis
Trevis, to answer your questions:
1: No, it is a sign of wear, and needs to be addressed ASAP.
2: At least one forums member has experienced this problem, and has had the trailer jump off the ball while towing.
3: They can be rebuilt, but for peace of mind, replacement is best.
4: It is only one part of the assembly, and it has all worn together.
5: You can, but it is not recommended.
6: It is the safest, best, longest-term solution.
Terry You repair things with tools. You fix things with a hammer.
AIR#2611
If it is those parts most decent RV places should have them.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years! http://Michelles-Adventures.US
This is a good thread to add that every time you hitch up, you should make the tongue jack lift the trailer tongue AND rear of the tow vehicle to ensure that a) you're connected properly, and b) that you're coupler isn't so worn as to have the coupler jump the ball as is described here. I've had it happen with a Trillium 4500 and believe me, it's no fun.
Specifically regarding your Marvel coupler, parts are available to rebuild the spoon. I have chosen on a couple of different older trailers to just replace the coupler with a more modern coupler. The parts are usually around $35 and whatever a welder will charge you to cut the old one off and re-weld the new one on.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein 2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Rebuilding my hitch latch using the part azflycaster is showing. There is a hallow metal pin that goes in the latch handle to hold the whole assembly together. It's inserted and mushroomed slightly on the ends to keep it from sliding out.
Does anyone have experience with this pin and the easiest way to get a proper expansion on the ends - to be sure it does not come out. I'm thinking of just cutting the old one off using a Dremel......
