10-22-2008, 02:30 PM
1967 26' Overlander
Owings Mills
, MD
Manual hitch jack
Our '67 Overlander had a power hitch jack. I'd like to install a simple manual hitch jack. Any suggestions on a replacement?
10-22-2008, 02:36 PM
1967 24' Tradewind
Wickenburg
If the old power jack is still there I would fix it and use it. My '67 has the power jack and it is great. In my original owners manual it says the power jack is so easy even the little lady can use it. Helen didn't think that was as funny as I did!
10-22-2008, 02:49 PM
1998 28' Excella
Dolores
I have seen manual jacks on some of the older units and the LP tanks are usually in the road. I had the electric jack go out on my older 71 unit and replaced it for less than $300. Replacement jacks either electric or manual can be purchased at any RV supply store.
FCU
WBCCI 10105
AIR 28748
10-22-2008, 03:04 PM
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
My electric jack went out on this last trip. While the manual alternative (it came with a manual crank) isn't as hard to use as I thought it would be, I'd rather use the electric one. I have to remove the gas tank cover and the motor every time I want to hand crank the tongue up or down or hitch and unhitch.
Mine is a 3,500# one. I'd like to get a more powerful one since I often have a golf cart in the bed of the truck and use the jack to lift the tongue to install the spring bars of my Equal-i-zer brand hitch without using the lift bar thingie. I think the cause of it going out was lifting so much weight all the way up to the top of the post shaft. I've done this before but for some reason it blew the fuse this time and I couldn't get the motor to ground out per the instructions. I took it to a trailer shop and once they got it to ground out it kept blowing fuses every time I reached the top or bottom of the post or end of the motor's rotation limit...the shop I took it to didn't fully reverse the motor before installing the motor head on the post like they were supposed to so it would only turn a couple of turns before it reached its limits. Now it won't ground out again. I think I probably just need a new motor at this point.
Does anyone know if Airstream puts a stronger motor on the Pan America or one of the slide-out models since they have more tongue weight? The strongest thing I have found is 3,500# at Camping World.
2006 30' Safari - "Changes in Latitudes"
2008 F-250 Lariat Power Stroke Diesel Crew Cab SWB
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
10-22-2008, 03:08 PM
1967 26' Overlander
Huntsville
Don't do it
My '67 Overlander has it's original, manual, tongue jack. Due to my yearly oiling, I doubt it will ever quit. But I wish it would.
I am just plain tired of cranking it. If I could stand to replace something "that ain't broke", I would replace the jack in a hearbeat with an electric version.
Electric jacks work carefree IF the limit switches are properly adjusted.
FWIW, I tried to remove my manual jack for painting during the original refurbishment. It would not budge, and it's obstinance lead me to believe I was missing a hidden weld. Later posts by others in another thread affirmed that jacks, sometimes, need a lot pounding to get them to release from the A-frame.
If I could get my manual jack free of my Overlander easily, I would offer you a simple trade because I am just plain tired of manually cranking the Airstream's tongue up.
I recommend you keep your electric jack. IIRC from your past posts, you (like me) ain't no spring chicken.
Tom
10-22-2008, 03:48 PM
2020 30’ Globetrotter
2001 30' Excella
Phoenix
Manual Jack
We have a new manual jack that was installed by the PO. it is a Bulldog brand and serves us well. The propane tanks are not an issue in our case.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
10-22-2008, 03:51 PM
Austin
You know, I normally agree with TomW. He's about as smart as they come, and he's "been there and done that" for just about any Airstream restoration project you can imagine.
But I too like the simplicity of the manual jack. It doesn't use up precious battery life whilst boondocking, and it doesn't stop working in the case of a loss or interruption of power.
As an engineer, I've always believed in the philosophy of KISS. And manual tongue jacks keep it plenty simple.
10-22-2008, 04:02 PM
1967 26' Overlander
Owings Mills
, MD
Well, I'm not a spring chicken but I did manage to persuade the hitch jack to let go.
I think both Tom and you are bright guys, Marcus. There are fair and reasonable arguments for both manual and power options. My instinct is to begin simple and resist as long as possible the slouching towards complexity and convenience. I need a jack to tow the tin girl. A manual jack (if I can find one that drops in and doesn't require a great deal of fuss) will work for the immediate future. If the ravages of time leave me weak of limb, I can always drop in the electric. I'll prewire the hitch just in case I find the power too great a temptation later.
10-22-2008, 04:43 PM
Austin
Well thanks, that's mighty kind of you.
The bolt-in tongue jacks seem to be pretty standard. Just three bolts arranged in a triangle around the cylindrical housing. When I experienced a loss of power on my electric one, right as I brought the trailer home for the very first time and desperately needed to unhook my TV, I just ran over to my favorite local outdoor/marine shop and bought a manual replacement for it.
I still have the electric one and it should still work, so maybe if Tom will come to the Texas State Vintage Rally I can hook him up with a great deal on one...
10-22-2008, 04:54 PM
1967 26' Overlander
Huntsville
The last one I attended even made it to a web page entry
Originally Posted by utee94
... so maybe if Tom will come to the Texas State Vintage Rally I can hook him up with a great deal on one...
Believe it or not, I'm still agitating about that rally. I thoroughly enjoyed the last one we attended, and Kim enjoyed the time to ourselves while doing something fun.
The current distance, though, is a killer for us time-wise.
I would like to change my mind - Texas is a great state.
Tom
10-22-2008, 06:50 PM
, At Large
Some tongue jacks come with a vertical, rather than horizontal, crank. That way they don't tangle with the LP tanks. There was one on our '63 when we got it, had I known Marcus wanted a manual, I would have left it on.
10-22-2008, 07:05 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I really like my electric jack, even though it has failed (I had to use the crank) and needed some parts replaced. It works well.
I also use power tools rather than manual tools when I can.
Why walk when you can ride? Why crank when you can push the button?
10-22-2008, 07:31 PM
1968 28' Ambassador
Cedaredge
Tom
Yep, I have used both,, we borrowed our friends AS that had a power jack.. was very nice.... But my manual one works just fine... If I do replace it, it will be one of the last things....
Like Tom says, IF it ain't broke why fix it.... Especially for a manual...
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-22-2008, 07:42 PM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Last year at one of our Penn Wood rallies there was a couple from Canada with a vintage unit (I can't remember what year and model), but he had the neatest vintage tongue jack. It was a manual hydraulic jack. It was operated just like a little floor jack. Put the pump handle in, pump up the tongue, and twist the handle to release the pressure and the tongue would go down. It was very easy to use and was a lot easier than a manual crank jack. If I had a vintage unit I would sure be looking for one of those little beauties.
It looked a lot like this one I found on the Internet...
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
10-22-2008, 10:47 PM
1966 24' Tradewind
Placerville
I wanted to stay with my old manual jack. But raising and lowering twice each time to install WDH was too much. Mrs. Santa brought me an electric one last Christmas.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
10-22-2008, 11:21 PM
1969 25' Tradewind
Irmo
, South Carolina
I don't even use a WD hitch (1-ton dually, no need for it really) and I still hate my manual jack. There are plans for a powered unit one of these days, but so many other things I want to upgrade first. Anyone considering ditching their power jack for a manual one is welcome to come by and crank mine up and down four or five times to try it out. That thing will make anyone want power.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
10-23-2008, 03:35 PM
Austin
No worries Terry, the thing that prompted the switch was that the on-board battery was dead and/or the battery connection was loose, so the electric jack wasn't working when I returned home. Cat's husband had actually used his truck battery and a couple of long leads to operate it the first time just to unhitch Goliath from his vehicle and hook him onto mine. When I attempted the same thing at home, I couldn't get it to work at all. I know the jack works because I've seen it, so I'm sure I just wasn't getting a good connection (Cat's husband messed around with it for about 10 minutes before he got it to work initially).
So anyway, I decided I didn't want to be reliant on external power in the case of an emergency need to disconnect the trailer from the TV, so off I went to buy the manual one.
I still have the electric one, and will likely keep it as a back-up. Perhaps I'll even reinstall it one day when I feel like farting around with those electrical connections. But for now it works fine as it is.
10-23-2008, 05:26 PM
1967 24' Tradewind
Wickenburg
Mine was not wired up when I bought the '67. the PO was moving it with a tracter I guess. I always carry a jump box with me, hooked up the jump box and away it went. I still carry my jump box around. Handy gadget. John
