08-12-2015, 05:12 AM
#21
2012 27' Flying Cloud
W
, New England
Originally Posted by philipsinewe
This is not the Hensley Bump. Totally different situation.
Can you say more? What do you think it is? Thanks.
08-12-2015, 05:28 AM
#22
2003 30' Classic
Centerville
, Ohio
The bump is from the trailer moving forward as you are breaking, in a turn. In that situation, the trailer hitch has "play" and if your trailer brakes are not set properly, the trailer thumps forward. It, in part happens on all trailers, in that the trailer is pushing forward. Thus trailer brakes are important to be set aggressive on all trailers. With the Hensley you also get that thump. You clearly need to be aware of it.
What this original thread is referring to is the hitch bar "popping" in the receiver box at low speed. No big deal at all. I find all the "fixes" kind of silly, for me, it reminds me that I have a very nice hitch, and that I have 10,000 pounds that's wants to sit in the passenger seat with me. But to each his own.
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
08-12-2015, 02:56 PM
#23
2007 22' International CCD
Corona
That explains why I set my Prodigy II controller to boost 1 or boost 2 depending upon terrain. That pretty much eliminates bumps from weak trailer braking. Much more aggressive braking curve this way.
08-13-2015, 06:30 AM
#24
2009 19' Flying Cloud
Fairfield
, Connecticut
So I emailed Hensley about the use of rattle reducers, and here is their response:
Byron,
We don't have a specific recommendation on using such a tightener. Usually
any noise created in the receiver can be mitigated by spraying silicone
spray inside the receiver so it will move a little easier without creating
noise.
Any sound created in the vehicle receiver will not alter the function or
performance of the Hensley Hitch so its up to you if you decide to tighten
it up.
Having ruled out everything else, and seeing how common the 'rattle' is, I am comfortable that this is what I, as a newbie to towing, am experiencing. I like the lubricant idea is general, so will start with that and then perhaps add a specific device.
Thanks to all - I learned something.
08-13-2015, 12:53 PM
#25
2013 30' Classic
Greenwood
, Mississippi
The $22.95 anti-rattle device certainly cannot hurt anything.
Without it, the shank will wiggle around and start to distort/elongate the pin hole.
With it, no worries.
Seems like you would still get the "Hensley bump" braking, backing, or staring from a standing stop due to the design of the hitch.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
08-13-2015, 01:44 PM
#26
Oswego
If you're talking about the stinger moving around and clunking in the receiver due to not much WD "binding" it in place, I agree......but that's not the "bump".
It takes a pretty hard braking event, in a (minimum) slight turn to get the bump. It is caused by "over-rotation" by the swing arms, for lack of a better term. Tight bearings (all 8 of them) will help minimize it dramatically. I've only experienced it 3 times, all during hard braking and some steering input to head for an escape route, if needed. Struts need to be adjusted for centering of the head and box and need to be pretty firmly under compression.
-Rich-
08-26-2015, 10:08 AM
#27
S.E Lower Michigan
, Michigan
Try a Hitch-Vise. http://hitchrider.com/nowobble.htm
I have one that I use on my bike carrier and it really stops all movement of the shank in the receiver.
Barney
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hensley Cub?
AWCHIEF |
Hitches, Couplers & Balls |
9 |
09-18-2012 09:28 AM |
Hensley Cub
grwalk |
4 |
07-12-2012 06:34 AM |
HENSLEY CUB w/73 Tradewind
my3sonsdad |
5 |
08-02-2011 07:31 PM |
The Hensley Cub
bredlo |
23 |
10-22-2008 10:56 AM |
