Old 05-13-2006, 09:06 PM   #1
1963 19' Globetrotter
Moline , Illinois
Lost the snap up lever to my Equal-i-zer hitch
Not a good idea to set this black wrench on the black bumper and drive off especially after you have told your wife that you are going to spray it a bright color so this doesn't happen.
Will a Wonder bar (crowbar) work just as well or do I just part with $20.95 plus shipping for a new one and just add this to my list of RV adventures.
63air is offline   Reply With Quote
Old 05-14-2006, 05:32 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can go to your friendly hardware store, and get a piece of steel pipe about 2 feet long. It's cheaper, and if you drive away and leave it again, you aren't out a lot of money. Just get a piece of pipe with a large enough diameter to fit the lug on the lift point.
Old 05-14-2006, 07:21 AM   #3
2003 25' Safari
Eden Prairie , Minnesota
I never use mine! Just lift the front of the trailer with the jack enough so that the weight distribution bars are easily placed on the "L" brackets.
Dan
dmac is offline   Reply With Quote
Old 06-04-2006, 07:56 AM   #4
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
We are changing truck and trailer, to a 25' Airstream and HD2500 Chevy. We are considering Equal-i-zer hitch instead of Reese dual cam. How has it been for you?
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 06-04-2006, 03:33 PM   #5
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
hitch
I also lift the trailer to do it by hand.Fortunantly I have air suspension on my vehicle so I can do it that way also.I rarely use the wrench but have used it a few times.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 06-04-2006, 04:08 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Equal-i-zer Hitch spring bar tool?
Hi, the other day while at a friends house, He showed me his beat up, bent up, scarred up spring bar tool. I asked him "what the heck did you do to that tool?" He told me that his son and him hooked up a piece of pipe to the handle to get enough leverage to install the spring bars on his [same as mine] Equal-i-zer brand hitch. Then I proceeded to tell him that I don't even use that tool on mine. Now, I can't even mention how and what he said to me, in total disbelief, that "I don't use that tool."
It took some time for my neighbor to calm down long enough for me to show him on his trailer to let the tongue jack do all the work. Now he thinks I'm Einstein or something.
Bottom line, put that twenty something dollars in your gas tank; You don't need that tool as you can read it right here on this forum.
Old 06-04-2006, 04:24 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep I used that bar for about two trips and said to my self, "Jack,just crank that jack down about two more inches and the bars will slide on without any help. Doh! "
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-06-2006, 08:51 PM   #8
Moline , Illinois
I really like the Equal-i-Zer hitch and I do crank the jack all the way up( while it's sitting on a tongue jack stand) ,but you still need a little lift on the bars sometimes as my 3/4 ton truck sits fairly high. Being the true farmer I am,a $3 Chinese crow bar at the local farm store has solved the problem. It will also come in handy for whatever at the farm. You never know when you might run into a problem that wire and pliers won't fix.
Old 06-08-2006, 07:39 AM   #9
2003 25' Safari
63air, If you are having to use a crow bar to put the spring bars into place, then the spring bar tension may be too high. Perhaps either:
- The hitch head angle is set too large. Adjust with the washers.
- You said the truck sits high... is is possible the hitch ball height is too high? You may need to lower the hitch on the drop bar, or purchase a different drop bar.
Dan
Old 06-08-2006, 08:41 AM   #10
Killo1's Avatar
2005 22' Safari
Santa Ana , California
That's how I was told to do it by the dealer when I took the delivery. The only side note is the I have an electric tongue jack. Without that, doing it this way could give you an arm cramp.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
