Old 05-30-2008, 08:24 PM   #1
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
1998 30' Excella 1000
Sherwood , Oregon
Images: 12
Loose Ball Nut - CAUTION
Hi ALL,
It was barely perceptible. But, last Monday on loading up, I was not 100% lined up with the ball when I lowered the tongue onto it. I thought I saw the ball slide a little sideways. So I reached down and tried to turn the nut, but it wouldn't move. Thinking that nearly all of the stress on the ball's shaft is horizontal sheer vs. vertical and that the Reese load leveling bars tend to push the tongue down onto the ball, I thought I'd chance it and check it at home after parking the trailer. At home with the trailer load off it, sure enough, I could move the ball a bit. I don't have a wrench big enough to fit (It's a huge nut), so I took it to a shop where they had to scrounge to find something that would fit. They did and it's tight now. The guy at the shop grinned when I gave him a 20 for his time and attention. That's a cheap, big trouble avoidance cost.
This post is strictly intended as a serious CAUTION to everyone to check for loose ball nuts to avoid dangerous situations. That nut might have been loose for years and ready to vibrate down and off -- I have no way of knowing.
Hope I got your attention,
Walt
Driver1 is offline   Reply With Quote
Old 05-30-2008, 08:27 PM   #2
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
That's a good post on possibly a huge problem...Thanks for sharing!
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 05-30-2008, 08:34 PM   #3
richinny's Avatar
2011 34' Classic
i like to put a little burr in the thread at the edge to keep the nut from spinning off on it's own. just a small one will do in case i need to remove the nut.
Ricky
Old 05-30-2008, 08:36 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My Nut was loose too
Before my last trip I put on a new 2 5/16" ball with a 1" shank and lock washer and really torqued that sucker down good. When I got back it was loose as a goose
Old 05-30-2008, 08:55 PM   #5
easyride's Avatar
1977 27' Overlander
Naples , Florida
I bought a hitch wrench,big-big box end w/2 different sizes,always check before hooking up.I think Reese makes the wrench,I got mine at Tractor Supply.
easyride is offline   Reply With Quote
Old 05-30-2008, 09:57 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I took mine to the local RV place and had the Incredible Hulk guy in the back get after it with a wrench the size of a third world country. I think he also put a lock washer on it, too.
Good advice, Walt.
www.nesa.org
Air No. 6427
Old 05-31-2008, 04:48 AM   #7
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Tightnut
LOCTITE
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-31-2008, 05:59 AM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
ditto on the locktite, also you can turn your hitch 90 degrees in the reciever to allow you to stand on the wrench when tightening the nut.
if you see ANY rust around the base of the ball it is probably loose!
i figure they are consumable items and replace mine every 2 years or so, cheap insurance for about 20 bucks for a new one!
john
you call them ferrets, i call them weasels.
Old 05-31-2008, 08:41 AM   #9
Images: 59
I don't think the problem is the ball nut vibrating loose, If the ball clamp is tight, everytime you go around a corner you are putting a ton of torque into unscrewing the ball.
Be sure the ball clamp allows the ball to rotate freely, expecially if you have adjusted or replaced the clamp latching mechanism.
markdoane is online now   Reply With Quote
Old 05-31-2008, 09:49 AM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
markdoane makes a good point about friction. That is one of the reasons I grease the hitch ball every time I hitch up. I also wipe the ball dry every time I unhitch. That removes any grit it may have picked up and prevents my yellow lab from getting an ugly smudge from it. I use Reese's hitch ball lube.
Richard
Old 05-31-2008, 10:07 AM   #11
richinny's Avatar
2011 34' Classic
don't forget to clean the hitch and latch too.
Ricky
Old 05-31-2008, 11:01 AM   #12
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by Jim Clark
LOCTITE
LOCTITE blue not red. you will not get the red loose ever again.
Michelle TAC MT-0
Sarah, Snowball
Old 05-31-2008, 11:21 AM   #13
TIMEMACHINE's Avatar
Huntington Beach , California
Cool good thread
Thanks driver1, a good message for all. My first purchases after buying our AS was a torque wrench, large thin walled socket and a Reese wrench for the Equalizer hitch nuts/bolts. A little bit more than the $20 for the mechanic, but they fit in the truck better than a mechanic (and no kidnapping charges).
time
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 05-31-2008, 10:13 PM   #14
Driver1's Avatar
Sherwood , Oregon
Images: 12
Is there a recommended torque for these nuts?
Walt
A Word Of Caution !! lewster Electrical - Systems, Generators, Batteries & Solar 14 05-06-2007 06:16 PM
Axle Caution. Inland RV Center, In Axles 26 03-28-2007 08:43 PM
Refrigerator caution Pahaska Refrigerators 0 08-16-2004 08:41 AM
Black-Water Caution raebaker06 Waste Systems, Tanks & Totes 0 07-03-2004 11:22 AM
