Old 05-31-2008, 10:21 PM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It depends on the make of the ball and the size of the shank. Reese states these numbers:
*When installing REESE hitch balls, torque all 3 4in. shank balls to 120 ft. lb., torque all 1in. and 1-1 4in. shank balls to 200 ft. lb.
Richard
Old 05-31-2008, 10:38 PM   #16
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
1998 30' Excella 1000
Sherwood , Oregon
Images: 12
Thanks azflycaster.
Walt
Driver1 is offline   Reply With Quote
Old 06-01-2008, 05:58 AM   #17
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
HENSLEY
ok I'm out....
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 06-01-2008, 06:15 AM   #18
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by thecatsandi
LOCTITE blue not red. you will not get the red loose ever again.
I get red loose all the time. I use the Blue in my guns, flywheel bolts, clutch pressure plate bolts, and hitch ball nuts get Red. Cheater pipe and heat will do wonders, of course I am not working on flying machines.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-01-2008, 06:38 AM   #19
Images: 59
The torque numbers are: 3/4" - 160 ftlb, 1.00" - 250 ftlb, 1.25" - 450 ftlb. If you don't have a 450 lb torque wrench, take it to a truck shop.
Old 06-01-2008, 07:03 AM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
or take a 225 pound lineman, a 2 foot long wrench, turn hitch 90 degrees in reciever and jump up and down on the wrench!
john
you call them ferrets, i call them weasels.
Old 06-01-2008, 09:21 AM   #21
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have a separate ball shank for a utility trailer that I have. Last year I discovered that ball was loose. It must have been loose a long time because the nut was rusted in place so it was not coming more loose but the hole for the ball had worn to a larger diameter. The utility trailer is used for loads up to 4000 lbs. Had it been our Trade Wind the ball stem sliding back and forward could have been disasterous. I checked the hitch receiver/ball for the AS and it was tight but I could get another quarter turn of torque. The hitch ball is the 'weak link' in the hook up.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-01-2008, 09:22 AM   #22
Cracker's Avatar
Pittsfield , Maine
john
That's exactly what I came up with - but I'm just 225 pounds of old fart. I do use a slight variation - i.e. - a large cresent wrench with a 2'-0" long, 2" pipe extension slid over the handle. I slowly apply my weight, without jumping up and down. I try to finish up with the extension horizontal.
Cracker
Cracker is offline   Reply With Quote
Old 06-01-2008, 12:16 PM   #23
Images: 59
Originally Posted by Cracker
. . . - a large cresent wrench with a 2'-0" long, 2" pipe extension slid over the handle. I slowly apply my weight, without jumping up and down. .
Or you could use a 150 ft-lb torque wrench three times
unngh . . . 150
urgggghr . . . 300
hrnhghhgzx . . . 450
A Word Of Caution !! lewster Electrical - Systems, Generators, Batteries & Solar 14 05-06-2007 06:16 PM
Axle Caution. Inland RV Center, In Axles 26 03-28-2007 08:43 PM
Refrigerator caution Pahaska Refrigerators 0 08-16-2004 08:41 AM
Black-Water Caution raebaker06 Waste Systems, Tanks & Totes 0 07-03-2004 11:22 AM
