Wayne,
I ran across the same information a couple days ago and wondered if it was such a good idea. If it works then I am all for it. I really haven't thought about measuring both sides of my vehicle until I hit the CanAm site and now that you bring it up again, I will check it out the next time I hook up. I have tinkered with several link adjustments and not noticed a change in ride other than the tighter link raised the vehicle just slightly and pointed the trailer tail closer to the ground, something I didn't want. I am considering a lower hitch bar since I need to start a couple inches closer to the ground before I even attach the spring bars. Thanks for the picture because that says everything.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
