Old 05-24-2007, 10:41 PM   #1
Prescott , Arizona
Question Load leveling Bars?
Bought a 1959 airstream and it has 2 short bars on each side of the frame just behind the tongue. They move down and look like some part of a load leveling system. Does anybody know how they work?
thanks
59overlander is offline   Reply With Quote
Old 05-25-2007, 12:59 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
It sounds like you're on the right track, post some photos if you can. You should get some answers.
Fyrzowt is offline   Reply With Quote
Old 05-25-2007, 02:38 AM   #3
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
thanks
Welcome to the forums! If I were to guess, I think you are referring to the weight distribution bars. Take a look at some of the threads below and see if any of these help to answer your question. I hope this helps.
  1. http://www.airforums.com/forums/f464...-up-30679.html
  2. http://www.airforums.com/forums/f464...sis-19236.html
  3. http://www.airforums.com/forums/f464...tup-24880.html
  4. http://www.airforums.com/forums/f464...red-24603.html
  5. http://www.airforums.com/forums/f464...ars-23809.html
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-25-2007, 04:41 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If they are attached to the trailer and hang down, they have some chains attached to them, they are the cams for the Reese Twin Cam system. You need to see if the previous owner still has the head and the weight distribution bars to complete the system. Otherwise those parts some times show up on ebay separately. Once in a while you can find them at a swap meet at a Region rally or at a garage sale. If those avenues fail you can always buy new at your local trailer or RV store.
Old 05-25-2007, 05:31 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Load leveling Bars?
Greetings 59Overlander!
Welcome to the Forums and the World of Vintage Overlander ownership!
What you describe sounds like the trailer side of the Reese Dual Cam setup. The cam bars were typically clamped to the tongue, but in the early days of the system may have been welded to the tongue (I know of two 1960 Overlanders with the welded setup). I am attaching a photo of the Reese Dual Cam setup on my '78 Minuet. The hitch uses the Reese Trunion Hitch with standard weight distribution bars -- the standard chains are unbolted and replaced by steel saddles that ride in the stirrups on the coach -- you can also purchase new style bars that have a hook on the end that don"t require th saddles. The saddles and other parts are still available from Reese.
Good luck with your Overlander!
Kevin
Kevin D. Allen
AIR #827
Old 05-26-2007, 10:55 PM   #6
Prescott , Arizona
Thanks for all your help !!!
We found the rest of the hitch inside the trailer.
It is a twin cam set up.
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
