Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-08-2005, 03:50 PM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Levelling Expedition/Reese dual cam prob...
My trailer is level but the Expedition is slightly elevated in the front. I would like to have more weight on the front end If anything I prefer the "feline" look... nose down.
Am beginning to think this is impossible--lowering the front end. My Reese dual cam, etc. (it's all Reese stuff) "eccentric" washer is at full rear tilt/cant--number on the washer is (6). Is this impossible because the Expedition has that "swing axle" configuration in the rear--ummmm, sorry, independent suspesion
My tow bars are the 1,000 lb. rated bars. The dealer here in Tucson set the whole thing up, by the way.
What would you suggest to get more weight to the front of the Expedition?
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 04-08-2005, 04:14 PM   #2
j54mark
Profile:
I am no expert, but it sounds to me as if you need more drop in the hitch ball.
Mark
'85 Sovereign, 25'
Old 04-08-2005, 05:10 PM   #3
Kistler
Kistler's Avatar
To my way of thinking (blink, blink) that will make my problem worse. What do you think about heavier bars? Capable of less bend, I guess is what I mean.
If I lower the hitch, I am even lower in the rear; the trailer is now level. All I want is the front of the Expedition lowered.
Kistler
Old 04-08-2005, 05:23 PM   #4
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
How much load are you putting on the equalizer bars? As you load them you should see the front of the Expedition lower. The loading of the bars shifts the weight from the rear of the truck to the front. Your Reese manual should give some examples of this. My bars show visible spring when attached.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-08-2005, 05:28 PM   #5
Kistler
Kistler's Avatar
I don't know how much load but not enough apparently. The "dealer did it" is my excuse and I should have complained but......
Aren't the bars supposed to be parallel to the frame of the trailer under load?
I don't have an instruction book. I think maybe I have weak bars...at least too weak for the "weak kneed" rear of the Expedition.
IF I were to get higher rated bars, would that fix my problem?
Kistler
Old 04-08-2005, 05:42 PM   #6
Tarheel
Tarheel's Avatar
Images: 21
The way I attach my bars is by hooking up the trailer to the truck. Then I raise the jack until I have picked up the back of the truck considerably. I then put on the chain and lift up the cam and lock into place. Then I lower the jack and remove the jack stand. I have either 4-5 links between the cam and the lock. The bars 1000 lb in my case show deflection, but the truck and the trailer are level. Hope this helps.
WBCCI # 3485
Region 3 1stVP
Old 04-08-2005, 08:28 PM   #7
j54mark
Profile:
Kistler
It seems to me that:
If the trailer is level, then the coupler is where it should be when everything is right. If the front of the truck needs to come down, then the rear must come up (at least a little). If the rear comes up, but the coupler remains in the same point in space, then you must have more drop. Probably very little more, but maybe an inch or two.
Once upon a time I read somewhere about computing the necessary drop. I remember nothing about it now.
1,000 lb. bars are plenty for a 25'.
Mark
'85 Sovereign, 25'
Old 04-08-2005, 08:41 PM   #8
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Kistler, how much does the Expedition's rear end drop when the trailer tongue is set onto the ball? You should see it 'squat' a couple of inches without the bars, and it should be level with them. Tarheel's method of installing the bars is what I use. I generally drop five or six links (free). My bars have visible flex in them, and my Excursion is level with the trailer. Taking up another link or two on the WD bars may make a big difference as well. I agree with Mark that is possible that you may need a little more drop in your ball height, and that the 1000 lb bars should be more than enough for a 25'. My bars are 1000lb bars for my 34' with a 900 lb tongue weight.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 04-08-2005, 08:50 PM   #9
Kistler
Kistler's Avatar
Thank you, everyone! OK, I guess I'll experiment with the drop of one hole and see what happens.
I hate to buy a wrench just for those big nuts. Maybe my pipe wrench will work.
Kistler
Kistler
Brenda
Misty (Maltese)
2002 Classic 25'
Old 04-08-2005, 09:14 PM   #10
flyfisher
flyfisher's Avatar
Profile:  2004 30' Classic
Lancaster County , PA & MT
Kistler -
Well, at least your dealer installed your Reese hitch so that your trailer rides level. The dealer I bought my Airstream from last year (Turner Airstream) installed my Reese HP Dual Cam hitch haphazardly (the weight bars didn't seat properly in the cam arm), the hitch bar was too short for my tow vehicle, my trailer rides higher in the front and lower in the rear, and I still haven't got it fixed.
I made an appointment to get it fixed at Bretz RV (an Airstream dealer) in Missoula, MT last summer, but they were worse than Turner's, and claimed they had never seen a Reese Dual Cam before, if you can believe that!
Anyway, to address your concern, my suggestion would be to get a copy of Reese's hitch installation instructions. They seem to have these instructions available to download from their internet site, however, I was not able to get it to download a week or so ago when I tried. If you have problems like I did, you can probably contact their technical service people by phone or email to get the instructions. The instructions are pretty detailed, and I know others who have followed them step by step with excellent results (not the 2 Airstream dealers I've been to, unfortunately).
After you check the entire hitch installation instructions, you may find that you can't level your Expedition completely - you didn't say how much the front end is elevated. I've always had a slight front end elevation (maybe 1/2") with my F250 Super Duty even when I've had my 1000# spring bars fully loaded.
John
ps - I wouldn't try to take a hitch apart with a pipe wrench! Even if you were able to get it apart, you'd need to re-torque it properly, and I don't think you could do it manually (from memory, I think they require 300# of torque - and you don't want it coming apart when you're towing - if you think your front end is elelated now... )
Flyfisher
flyfisher is offline   Reply With Quote
Old 04-08-2005, 10:27 PM   #11
wheel interested
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 118
where are you finding the 1000#bars?
We were told that it jumps from 800-1200 pounds. And I just looked it up now to see about the 1000# bars and don't see them.
http://www.reese-hitches.com/hi_pef_trunnion_bar_wd.htm
We have an Expedition/25'Classic combo and dual cam but our bars are only 800 and we inquired about this because the hitch weight of the 25'Classic is closer to 900#
Can you tell me how the weight of the bars and the tightening or loosening of the chains affect the ride and handling?
Thank you.
Carol
Mackinaw City Forums Rally October 3-5
wheel interested is offline   Reply With Quote
Old 04-09-2005, 12:38 PM   #12
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
..... I guess I'll experiment with the drop of one hole and see what happens....
Kistler:
Below is a link to the PDF on the Reese site for the installation of a trunion bar equalizing hitch.
http://www.reeseprod.com/support/sup...fs/66006IN.pdf
Since you are going to redo it, may I suggest you go to a Cat scale and weigh your rig now, with no equalizing bars, and finally with the new set-up?
A three axel weighing is only about ten bucks, with reweighs only a buck apiece - lots of information can be derived from sequential weighings.
If possible, also get separate weights on your final set-up - just to insure both of the axles are carrying the same load.
Dennis
WBCCI # 1113
AirForums #1737
Old 04-09-2005, 05:49 PM   #13
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
Reese's instructions are very clear, and easy to follow if you can measure. Download the instructions and follow them, and you will solve your problem. While you are there, e sure to download the instructions for the dual cam installation.
It is likely that the dealer adjusted everything with the trailer empty, and now that you have loaded, you need to increase the load on the spring bars a link or two.
Good luck, and just follow those instructions. If you have problems downloading the instructions, PM me before Monday and I will forward the files. I have them in my computer.
jimmickle is offline   Reply With Quote
Old 04-10-2005, 03:54 PM   #14
Tarheel
Tarheel's Avatar
Images: 21
Kistler go to http://www.airstream.com/airstream/p.../weights-1.pdf it shows that the ball heigth of your truck should be 18.750". Set your ball as close to this height as you can then adjust using your equalizer bars to bring your truck level.
WBCCI # 3485
Region 3 1stVP
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches 19 03-19-2003 06:17 AM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
Reese Twin Cam Setup Road Ruler Hitches 5 09-15-2002 12:23 PM
