Old 02-10-2013, 06:03 AM   #1
1972 31' Excella 500
Mount Vernon , Is For Lovers
Lengthening hitch
This might be oversimplifying but can you lenghten the shank on your hitch? mine has 2 positions to choose about 1 1/2" difference.
Sylver Slypr is offline   Reply With Quote
Old 02-10-2013, 06:32 AM   #2
dznf0g's Avatar
Oswego , Illinois
Yes, you can, but any lengthening does have some effect on the ball to axle overhang distance. But 1.5" to get the gate down....probably wouldn't notice any handling or sway difference.
You should always be conscious of lengthening that distance though.
-Rich-
Old 02-10-2013, 07:31 PM   #3
This was a response to a low profile jack question on a different thread> I don't know why it was moved.
Old 02-10-2013, 07:50 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have had three different hitches with the two holes in the adjustable shank, an old Quality-S, a Reese Dual Cam, and an old style Reese. If I remember correctly, the shortened length was rated 1,200 lbs tongue weight. When slid out to the longer length the ratinging changed to 1,000 lbs tongue weight.
Alan
Old 02-10-2013, 08:02 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I have a Reese shank that has 2 holes about 1" apart for the receiver pin. The specs on it say it is rated at 15,000/1,500lb in the short position and 10,000/1,000lb in the longer position.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Hitch age? Skater Hitches, Couplers & Balls 18 09-03-2011 01:12 PM
BMW X5 OEM Hitch says NO WD device - Help valmog Hitches, Couplers & Balls 8 07-12-2011 11:15 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
