Old 05-25-2011, 08:49 AM   #1
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
LED Tow Vehicle to LED Trailer Problems
I have a 2010 MB GL and it has LED lights.
The 2011 FC 23FB also has LEDs.
Problem: It appears there is a resistance issue between LED sets that cause (when the tow vehicle has its headlights on) the trailer running lights to blink on and off quickly.
etrailer.com has an adaptor 7 pin cable that MB says takes care of the issue.
Etrailer will not have any in supply until July.
Does anyone know of an alternative solution to this issue?
TIA
murreywalker is offline   Reply With Quote
Old 05-25-2011, 09:13 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've heard of some folks wiring in incandescent bulbs just to provide the resistance, but I also think you can get the adapter from Andrew T.
Old 05-25-2011, 09:48 AM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
In a earlier post I read where someone found the running and stop lights wires under the couch, and put a incandescent bulb in-line there, to get the resistance to allow the LED lights to work. I'm not sure where your wires are but having a light inside your unit and not touching anything to where the heat from the light would not cause any problems should be fine. To get you on your way.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-25-2011, 10:11 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
You can get the adapter from VW dealers but it will cost more than at Etrailer.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 05-25-2011, 10:21 AM   #5
Branson , Missouri
Are you sure VW has the adapter? Etrailer has them on backorder and won't have them until July.
Old 05-25-2011, 10:37 AM   #6
Branson , Missouri
I talked with them and they suggested the incandescent method.
The harness is located under the bed and splicing in sockets to hold bayonet style bulbs in three wires would be a solution to the issue.
What I don't understand is, why didn't Airstream address this issue when they knew it (I talked with them earlier this morning, and they acknowledged it was an issue)?
Old 05-25-2011, 11:27 AM   #7
Gainesville , Florida
I believe this is a tow vehicle problem not an AS problem. AS can't be expected to solve every issue that may come up with all the diferent types of tv. Same as hitches, if it will not work on an AS, then it is not AS problem, it is the hitch mfg problem. Go to your MB dealer and ask them why their car will not work with the AS. I bet they will say something like--we can't make our car compatible with every trailer mfg. Same as AS , they can't make their trailers work with every tv made. jim
Old 05-25-2011, 11:32 AM   #8
Branson , Missouri
Seems to me to be a chicken or egg issue, jim. It is, indeed, an engineering challenge.
However if I knew there was an issue in MY manufacturing process that impacted a growing body of users, I probably would spend some time and effort in providing a solution to my future customers.
JMHO, though.
Old 05-25-2011, 11:40 AM   #9
Okay, so why isn't MB doing that? jim
Old 05-25-2011, 12:19 PM   #10
Branson , Missouri
I don't know that they aren't.
Old 05-25-2011, 01:26 PM   #11
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
I'm not familiar with this issue, but is it related to the power to the LED being too high with not enough resistance? Alternatively if it is because of the aspect of using LEDs for both, couldn't you just wire in a relay with a separate lead from the battery in order to have direct power to the lights, and then put a load resistor on it? You can pick those up at Fry's or Radioshack.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 05-25-2011, 02:40 PM   #12
Wayne&Sam's Avatar
Images: 21
I think you can count those of us who tow with a Mercedes on one hand.
Old 05-25-2011, 02:57 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm guessing that the "adapters" mentioned that are out of stock are nothing more than an appropriately-sized resistor.
It sounds like the same behavior that modern cars exhibit when a lamp burns out, but applied to the running lamps instead of the turn lamps. I'd assumed it was an intentional design for turn signals, so that you're alerted that a lamp is out. I wonder if it's an inadvertent "feature" that's triggered for the running lights as well, since many modern high-tech cars don't have mechanical flashers anymore, it's done by one of the onboard computer modules.
— David
Old 05-25-2011, 03:32 PM   #14
Branson , Missouri
It not only applies to MB. Audi, VW and Porsche Cayenne seem to be having the same issue.
Lot's of good feedback from many of you, but so far I'm of the opinion that installing incandescent sockets with bulbs at the right location in the trailer, seems to be the best approach.
Of course, as LED technology becomes more prolific, the solutions will rush to the marketplace.
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 08:27 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
The ultimate tow vehicle! I found it! brad1 Tow Vehicles 8 03-21-2011 07:47 PM
