Old 03-26-2011, 03:50 PM   #1
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Leaving trailer hitched?
We try to take a camping weekend every 4 - 6 weeks year round. We pull our 31' with an Excursion. It's stored between trips in our concrete floor RV shed.
When we get to a CG we immediately unhitch in order to explore. But, do we really have to do this at home between trips? We can back the trailer into the shed, leave it hitched, and just lower the roller shed door down to the top of the hitch. We're ready to go next time.
Problems to either the trailer, truck or hitch doing this?
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 03-26-2011, 03:57 PM   #2
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
I do it all the time but I put the tongue jack down to take the weight off the truck's suspension.
Steve
TinLoaf is offline   Reply With Quote
Old 03-26-2011, 03:59 PM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Leaving it attached is OK, I would recommend releasing the tension on the weight distribution bars, use the hitch jack to take the weight off the rear of your tow vehicle and disconnect the umbilical (7 pin plug) so as to not draw down your vehicle battery.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-26-2011, 04:01 PM   #4
Ottawa , ON
My personal thoughts are that the trailer won't suffer any damage by storing it that way.
However, not so sure about your TV, the Excursion. You would be leaving the full tongue weight of the trailer on the suspension of the TV for all that time. I can't imagine that would do any good for the TV's suspension.
You could put the TT's tongue jack down,and release some of the weight from the Excursion, I suppose. That would mitigate the pressure on the suspension.
I would also disconnect the umbilical, to ensure no power loss on the TV's battery.
[Edit: I type too slowly!]
Old 03-27-2011, 03:33 AM   #5
2005 19' Safari
GLENDALE , AZ
If wired properly, the hot lead from your TV's battery back to the connector near the hitch should have an in-line relay that removes power to the umbilical plug when the ignition is turned off. The Airstream dealer installed one when they replaced the hot wire on our old pickup, and our newer model Tundra (with tow package) came from the factory wired that way.
Old 03-27-2011, 08:02 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Nice and convenient that you can do that. If you usually keep the trailer hooked up to house electric it 'might' be a good idea to disconnect your TV electric connection. There should be a problem leaving that connection, but we don't always know what can happen when we are not 'looking'.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-27-2011, 02:48 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Interesting, IC device to disconnect power to Airstream batteries when vehicle is powered off....
Any Hoots, unless the OP has said upgrade installed, then I would strongly suggest removal of the umbilical from TV while in storage along with relaxing load distro & resting weight of tounge upon electric trailer jack.
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-27-2011, 03:38 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Yeah, modern tow vehicles are supposed to have a diode to prevent the trailer pulling from the TV. Ask Foiled Again how you can't count on that... Disconnect the umbilical.
I'd do exactly what Kevin242 says about releasing the spring bars & putting down the tongue jack. I have left the spring bars engaged if I'm traveling fast and it's just one night.
5 meter Langford Nahanni
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
7 Way Trailer Cord aname4me Electrical - Systems, Generators, Batteries & Solar 6 03-09-2011 11:20 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
