Old 05-16-2019, 11:20 AM   #15
Waterloo , Ontario
I have pretty much the same set up. There is another reason to disconnect the electrics: The Touareg pulses the trailer lights every now and again to see if there is anything there. With LED lights, you'll find that they mysteriously flash now and again.
I always use the jack to either level or at least stabilize. That also reduces the chances for me to forget to plug the electrical back in.
Rhinno is offline   Reply With Quote
Old 05-16-2019, 11:53 AM   #16
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Short Answer: No problems leaving it connected.
However, you need to disconnect it during a full moon.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 05-16-2019, 12:44 PM   #17
2007 22' International CCD
Leave TV hooked up overnight or disconnect
Or high humidity or darkness.
I use an EZconnector that hooks up magnetically and has a storage point on the Airstream A-frame. I also use “remove before flight” streamers as reminders. They go on hooks on the back of the closet door. Empty hook means I missed something.
Old 05-17-2019, 06:33 AM   #18
2014 27' Flying Cloud
Wenatchee , Washington
Originally Posted by moosetags View Post
We often stay hooked up overnight, but always unplug from the tow vehicle.
Brian
+1. I haven’t bothered to look up whether I can leave our FC 27FB plugged in to the Ram overnight or not... anything made by man can fail so I just unplug every time we stop for the night. Just one less thing to worry about.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 05-17-2019, 07:59 AM   #19
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Brian
Ditto.
banderabob is offline   Reply With Quote
Old 05-17-2019, 09:54 AM   #20
2019 30' Classic
Wherever I may roam , America
I'll leave it hooked up if it's in my driveway and I'm not sleeping in it. If I'm sleeping in it anywhere, I disconnect in case of the very very small chance someone somehow steals my vehicle I'm not stuck in the Airstream being pulled around by an idiot.
johnparris is offline   Reply With Quote
Old 05-18-2019, 08:03 AM   #21
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Don't forget to remove the intake covers before starting your engine!
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 05-18-2019, 08:37 AM   #22
Forgetting is a quick way to FOD an engine...
It’s an old habit based on years on a ‘bird farm’ and working for Boeing. “Head up and locked” is not the way to go.
Old 06-08-2019, 06:55 AM   #23
RidingmyRV's Avatar
2015 28' International
Portsmouth , Virginia
I leave it hitched and lower the tongue jack
Originally Posted by Hastalavista View Post
Silly question maybe? We park our 25RBT in the driveway overnight to pack and leave the next day. Any negative reasons to disconnect the TV (a 2014 Touareg diesel) from the AS? We had hitch reinforced at can am in London Canada.
Using load distribution hitch. What do y’all think?
I lower the tongue jack while hitched but I use my two concrete squares and three of the those plastic squares you can buy to put under the wheels to level the trailer. That way I’m not using the batteries as much to get the jack down. I raise the trailer until I see my truck and trailer are even. Then I lower the stabilizers. I don’t like the motion the trailer gives because it gives people imagination. see ya down the road
RidingmyRV is offline   Reply With Quote
Old 06-08-2019, 09:00 AM   #24
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Every setup is a bit different. With our F250, it disconnects from the trailer pretty much as soon as you shut the truck down. No voltage to the 7 pin to worry about. I have a DC/DC converter between the 7 pin and the AS system so no problem with back feeding the 7 pin either.
Old 06-08-2019, 08:48 PM   #25
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
We are in the camp of leaving it hitched up is overnighting as well. I also just leave it plugged into the TV. Just lower the stabilizer jacks and hit the hay. Just remember to raise them in the a.m. before pulling out. Nothing ruins your day better than if you forget.
thewarden is offline   Reply With Quote
Old 06-09-2019, 06:29 AM   #26
Half a Rivet Short
Hi
..... which is why we often don't lower them
Old 06-09-2019, 06:39 AM   #27
We typically only lower the stabilizers when disconnected from the tow vehicle. The one exception was one horribly cold, rainy, and windy day in Texas. Lowered all the stabilizer jacks to stop some of the wiggling we were getting while waiting out the weather. Even hitched and aimed into the wind there was still some movement. Decided to sit it out instead of being on the road.
Old 06-09-2019, 12:57 PM   #28
gypsydad's Avatar
Hi
Have done it both ways...I disconnect the electrical plug from the F250 for safety...I had one of my 25's where the AS batteries drained down while leaving connected to my F150, so just to be safe now I disconnect. Was not aware the F250 stops all electrical when engine is off?? I know it does in the cab...just wasn't sure about the trailer connection. I have started using duck tape to hold the connection while traveling, so it's a pain to unwrap, disconnect now...I may try leaving it connected if your sure, UB?? I plan to remedy the connection some time this summer...just not sure if the EZ Connect is the way to go?? Any additional suggestions on the F250 plug replacment is appreciated...
As for stabilizers, wife likes them down...so you can guess why we put them down. Just need to make sure you remember they're down...and also to make sure your plug is in.
Overnight Discharge in Disconnect caseydogmusi Batteries, Univolts, Converters & Inverters 9 02-24-2019 04:20 PM
Interior vinyl and wood layer, to leave or not to leave? amaelish General Interior Topics 0 05-29-2017 12:18 AM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Dometic Refrigerator...Hooked up wrong???? Carol Payett Refrigerators 9 10-15-2006 04:09 PM
Filling H20 Tank via Hooked-up Hose Mike76251 Fresh Water Systems 9 03-20-2004 07:39 PM
