Old 09-07-2017, 07:26 AM   #1
2017 19' International
Tallahassee , Florida
Least-Hassle Weight-Distributing Hitch?
I may need to get a weight-distributing hitch. Currently towing with a standard hitch with a friction sway-bar attached.
Since the tongue weight is not extreme, less than 700 pounds, I would think most hitches can handle that burden. So I might have a lot of options.
With that in mind, I'm interested to hear opinions on which weight-distributing hitches are easy to use ... and which ones are the most complicated to hitch and unhitch.
Don't know anything about weight-distributing hitches, so ... fire away with some wisdom!
WhereStream is online now   Reply With Quote
Old 09-07-2017, 07:47 AM   #2
2016 30' International
Florence , Alabama
I'm partial to my BlueOx. Hooks up like a standard hitch, then jack the trailer up a bit to take weight off TV, attach sway bars which just slide in. Apply tension using included wrench (or I prefer to purpose-bought 24" breaker bar with socket) - it's a 1/2 rotation of the locking head on each side.
joshjack is offline   Reply With Quote
Old 09-07-2017, 08:56 AM   #3
2010 25' FB Flying Cloud
Davenport , Iowa
I would use the Andersen considering your trailer, but you don't mention your tow vehicle.
Like above, I also use the BO; but that because of TV and TT and pay load.
mj
Airtandem is offline   Reply With Quote
Old 09-07-2017, 08:56 AM   #4
UncleBad's Avatar
2018 28' Tommy Bahama
Oro Valley , Arizona
Great question. Following with popcorn. Here we go!
UncleBad is offline   Reply With Quote
Old 09-07-2017, 09:01 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Popcorn with loads of real melted butter,
Put "Weight distribution" in the Airforums search block above.
MICHAEL
Old 09-07-2017, 09:18 AM   #6
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
Equalizer is very easy
dmbecke is offline   Reply With Quote
Old 09-07-2017, 01:27 PM   #7
Vintage Kin
Fort Worth , Texas
Need to distinguish:
1) WD solely; or,
2) WD with integrated antisway
Old 09-07-2017, 02:25 PM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There are a number of hitches that work on the "crank up the jack, attach the bars" principle. Some are slightly simpler than others. To the extent they are it may be not needing to grab a tool or maybe one more motion to the process. I'd call them all "simple" once you have done it a couple of times. The more exotic hitches are a bit more critical of alignment when hooking up. How much more of an issue that is ..... we have several hundred threads and many thousands of posts debating that exact question.
All that said, the Equal-i-Zer probably is the "most simple". I would not try and tell anybody that alone is a sufficient reason to pick it over all the rest.
Old 09-07-2017, 03:26 PM   #9
2017 27' Flying Cloud
Ocala , Florida
The multitude of opinions on this topic will prevent a consensus ~ that said ~~ I prefer the Equal-i-zer is simple and effective. I pull a 2017 Flying Cloud 27FB with a 2016 F150 with a 3.5 eccoboost and it works perfectly for me.
I figured I would throw trucks into the discussion -
Mikenbern is offline   Reply With Quote
Old 09-07-2017, 03:30 PM   #10
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
I'm not qualified to say which hitch is the best, but I use an Equal-i-zer with our 25' Flying Cloud Twin and F150. For reference, the gross weight of the trailer is 7300# and the hitch weight is 835# per factory specs, for whatever that's worth. This combination trailers beautifully and while other hitches may be "better" depending on the application, I can't imagine how any WD hitch could offer less hassle or be easier to use.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 09-07-2017, 03:56 PM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
X5 for Equalizer.
Simple and it works. Easy to adjust. Provides WD and anti-sway. Driver and can backup the rig without having to get out and detach anything.
25k miles towing. Have used with 1/2 ton SUV + 25' AS and 3/4 ton truck + 30' AS. Works for me, and I like simple.
wulfraat is online now   Reply With Quote
Old 09-07-2017, 07:57 PM   #12
1979 23' Safari
Wayland , New York
I think my Blue Ox is great and very easy to use and maintain. Plus not lots of noise. I think lots of the pain of any is handling the stinger and hitch head. To make that easy I had a buddy weld a piece of 2" receiver tube under the a frame. On and off the truck to the A frame is really easy and convenient.
Old 09-07-2017, 09:25 PM   #13
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Equalizer. 27 FB towed by a 2017 F150. Simple. Have about 15k on this combo.
kscherzi is offline   Reply With Quote
Least hilly and hassle free route - moving & towing, Toronto to Vancouver JustSomeGuy On The Road... 32 12-24-2014 07:44 PM
From the Noob desk: weight vs. weight distributing TINLOVE Hitches, Couplers & Balls 5 10-12-2014 10:10 PM
Looking for weight hitch, least expensive that will do job starcraft Hitches, Couplers & Balls 0 04-14-2012 09:29 AM
Blue Ox Weight Distributing Hitch Bill Price; Hitches, Couplers & Balls 5 02-28-2004 11:18 PM
Weight Distributing Hitch joshua32064 Hitches, Couplers & Balls 1 09-27-2003 07:16 AM
