12-15-2018, 08:49 AM
Tampa
Keyboard engineers opine?
I have a new shank that's 3" longer than my current shank on the Equalizer hitch.
Before I try it I was wondering how it might effect my WD.
Being longer, I assume it will create a longer lever arm for a given tongue weight. Thinking the fulcrum is the front axle.
However, doesn't that also mean the WD bars will have a greater effect and the net result be the same?
I currently have 5 washers and a bit of sag. I'm thinking while I have it apart I'll add another washer.
Currently, it tows perfectly. Not being to open the tailgate while hooked up is a pain.
12-15-2018, 08:56 AM
Spokane
"A bit of a sag". How much is a "bit"? If you are comfortable with it as is, I wouldn't add a washer unless your theory mentioned above proved to be true.
I think weighing your set up before and then after would tell you a lot.
12-15-2018, 09:09 AM
2013 27' FB International
El Dorado Hills
I had a shop drill a second pin hole in the my Equalizer shank for the express purpose of keeping its extension as short as possible. This was on the advice of CaAm Andy. Having the ball as close to the rear axle as possible keeps the weight and sway leverage to it's minimum.
I also spoke to Equalizer, they said they drill the pin hole on the shank the way they do for people that want to attach those slide on mud and rock guards. They had no issue with me drilling a second hole making the effective shank extension about 3" shorter.
I have about 25,000 miles now on my hitch. I've found it necessary to add a washer of two over time to compensate for wear in.
12-15-2018, 09:46 AM
2007 27' International CCD FB
San Diego
I believe I was summoned?!
For this situation in restoring front axle FALR, the fulcrum should be modeled at the hitch ball. So the WD bars lever arm didn't change in length at all. But the lever arm to restore FALR just got 3" longer. Reducing WD bar leverage.
Yes, you'll want to increase WD tension to get back to what you were at. An added washer should do it.
12-15-2018, 10:19 AM
2022 25' Flying Cloud
NCR
, Ontario
you need to keep the ball as close to the female end of the TV shank as possible.
The longer it is, the higher the pivot point away from your vehicle and less stable is the WD/Anti sway.
go to the the CAN-Am RV video page and they will show you why
There are also many threes on this forum with the same Q&A.
search for more details
cheers
12-15-2018, 10:45 AM
Vancouver
, British Columbia
I would consider the fulcrum to be the rear axle, so for the front axle load restoration you would just need some additional leverage from the WD bars with the additional rear offset caused by the longer shank.
The bigger issue, in my mind, isn't one of consideration of the vertical plane and the load restoration, since that can be accommodated with WD settings. I would think more about the horizontal plane. Any lateral forces act on the hitch ball and can cause sway because they are offset from the rear axle, which is where those lateral forces are resisted. You can't change settings to accommodate this longer lever arm you are setting up, there is simply more leverage side to side (unless you are using a 3P hitch design).
12-15-2018, 11:02 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The relevant measure is from the hitch ball to the center of the rear axle. You are moving things three inches out of a couple feet. Getting more exact than that would require a bit of data about your exact truck and the rest of the hitch setup.
12-15-2018, 12:18 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I believe closer to the TV axle is to help mitigate sway, 3" won't +/- WD much at all.😉
12-15-2018, 12:50 PM
Walnut Creek
Make it short. You can make it long? Folks do it. They also raise the coach, raise the TV, run without using the trailer brakes on down hill grades and other stuff too. They do what they want to do. So, if you do, do it, slow down at least a tad. Don't pass so much, follow a bit further back and get extra rest each day. Compensate for your shift to less than optimum engineering spec by adjusting the usage profile.
And note that a keyboard engineer can not help you. They are much too far from the wheel, the brake, the mirrors and the turn signal.
Travel safe. Pat
12-15-2018, 01:05 PM
Tampa
Here's why I said the front axle.
By adding more tension to the WD bars the effect is a lifting of weight off the rear axle and moving it to the pivot point on the front axle. If the rear axle is the fulcrum, the rear end of the truck would not move as weight is transferred.
Of course, but it doesn't help me open the tailgate. It's all compromise.
Originally Posted by ROBERT CROSS
I believe closer to the TV axle is to help mitigate sway, 3" won't +/- WD much at all.��
That's what I think too. Making the lever arm longer is offset by making the WD effect greater.
Sway? I have never had a hint of sway, so 3" will suddenly cause a rollover? I don't think so.
BTW, since driving with the trailer, I make a habit of looking at other trailers I see on the highway. Horse trailers, boat trailers, car trailers, motorcycle trailers, utility trailers, and you know what I don't see? A WD hitch on any of them. The WD hitch seems to be unique to travel trailers.
12-15-2018, 01:43 PM
Vancouver
, British Columbia
You can use either as a fulcrum, depending on what you want to calculate. Enter your figures in the calculation here:
https://www.rv.net/forum/index.cfm/f...d/14265335.cfm
12-15-2018, 03:34 PM
San Diego
Yes, it's a complex system and depending on what one wants to model, would use a different fulcrum.
Consider this particular case where we're talking about adding 3" to the shank, and whether we need to increase WD tension.
If you modeled the fulcrum at the rear axle, increasing shank length should give the WD more leverage. Increasing front axle weight restoration.
That is not the case here. Which would indicate the rear axle is not the fulcrum.
The ball is where the effective fulcrum is for the WD bars. He will need to add more WD tension.
12-15-2018, 04:17 PM
Vancouver
, British Columbia
Take a look at the link and the formulae there.
The trailer side doesn't change with the lengthened shank, so there is still the same increased load on the trailer axles, using the ball is the fulcrum for the WD bars, as you said.
Now use the rear axle as a fulcrum to calculate changes on the front axle from the increased shank length.
Use the front axle as a fulcrum to calculate changes on the rear axle from the increased shank length.
Agree he needs more WD tension to get the same effective change to the TV axle loadings.
T
12-15-2018, 04:47 PM
Tampa
That's the question.
However, I must disagree.
How can one say the longer shank makes for more leverage on the rear of the TV(agree), but not consider that the sway bars also provide additional lift to the chassis? (having a longer lever arm)
I contend it's a zero sum game.
12-15-2018, 06:07 PM
San Diego
T
In violent agreement.
I think the bolded sentence might be the point of confusion. Sway bars do not lift the chassis. It projects weight forward to the front axle (and trailer axles), which takes some load off the rear axle. The reduced weight at the rear axle reduces compression of the rear spring, allowing the hitch to ride higher.
12-15-2018, 06:15 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Simply, do whatever it takes to eliminate the squat. squat means you need to send more load to the front axle of the tv.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
12-15-2018, 08:13 PM
Vancouver
, British Columbia
The longer shank provides more leverage to both the tongue weight pushing down, and the WD equipment pulling up. It would be a zero sum game if the WD pulled up as much as the tongue load pushed down, as measured at the ball.
Try using the formulae in the links, with your vehicle’s specific numbers.
