Old 03-17-2016, 04:33 PM   #1
1975 31' Romany
Kansas City , Missouri
Is Weight Distribution Hitch needed with 3/4 ton
I have a question about WDH's so I'll pipe in here. I went from a Yukon Denali to a 2500 crew cab duramax as my tow vehicle. The Yukon squatted quite a bit when hooked up to a 1975 31' Romany and the WDH was necessary to keep the front wheels on the ground. Empty advertised weight for the trailer is 5000 lbs and 500 lbs tongue weight. Now the tongue weight has little or no effect on the attitude of the new truck. The weight bars are 800 lbs. After leveling everything, should I just use less chain links, meaning less weight distribution, or does anyone bother with the WDH with a 3/4 or 1 ton.
kosullivan is offline   Reply With Quote
Old 03-17-2016, 07:00 PM   #2
jump's Avatar
2013 30' International
lubbock , Texas
Yes ... Sway control, also .
jump is offline   Reply With Quote
Old 03-17-2016, 07:53 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Your tow vehicle owners manual may have the answer to your question. (mine does)
My opinion: If the measurement from the pavement to the fender at the center of the front wheels remains the same when you add the tongue weight, then there is no need for weight distribution. If the measurement increases when the trailer is attached, add tension to the bars until the measurement returns to the original measurement without the tongue weight.
Old 03-17-2016, 08:36 PM   #4
1994 28' Excella
Burkburnett , Texas
I have a 2003 Dodge dually and do not use WD and pulls great even in the worst cross winds. The eight sidewalls lock the rear end to the pavement. The truck sits level as well as the trailer.
paulken is offline   Reply With Quote
Old 03-17-2016, 08:37 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Imho, WD, NO, sway control YES.
So, you might as well get both.
Here is the deal, I have a 72 and a 75 31' Sovereign, and they both want to sway over 60 MPH, and the trailer could care less what tow vehicle you have or how big it is.
Talis gentium ceciderunt.
Old 03-18-2016, 10:44 AM   #6
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I have a reese and just upgraded to a 2500 so I'm am getting new bars. This thread: http://www.airforums.com/forums/f464...-43568-12.html was a source of a great deal of info for me and seems to suggest even a 3/4 ton can benefit.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-18-2016, 10:51 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yes.
Only difference is you will be transferring a little less weight to the trailer axles and to the truck's front axle.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-18-2016, 11:16 AM   #8
2007 25' Safari
Attleboro , Massachusetts
I have a 2010 GMC Sierra 2500 and have never used WD bars either for my 07 27 ft Safari or my 28 foot enclosed steel framed car trailer(with race car, pit boxes, and all of it inside) Can't even tell there is a trailer behind me!
romeb is offline   Reply With Quote
Old 03-18-2016, 12:08 PM   #9
2014 27' FB International
Clearwater , Florida
I did the 1/2-3/4 ton change. I have a Reese style WD hitch with 1000lb bars. On the 1/2 ton I was 3 links into the bars. I now use 2 links. I use a friction anti-sway bar and am careful about loading. I have so far not had any "wiggle". As to your question, yes, use the WD hitch. It really dampens the vertical trailer pitching when driving. Damping vertical oscillation at the hitch.
ChuckFeldt is offline   Reply With Quote
Old 03-18-2016, 03:50 PM   #10
1975 31' Romany
Thanks for everyone's input
Old 03-18-2016, 04:01 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Now thats encouraging.....can't even tell whether the trailer is there or not.
I never realized that was the goal...
Sweet Streams....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-22-2017, 08:32 AM   #12
2014 22' FB Sport
2017 28' Flying Cloud
Southwest Ranches , Florida
Most Airstreams towed by larger pick-ups don't need a weight distribution hitch. The reason is that the unloaded truck typically has most of it's weight, 55-60%, over the front wheels. Considering that the truck will handle best with equal load on the front and rear axles, adding load to the hitch ball will actually result in a better balance by increasing the rear axle load and lowering the front axle load by leverage. A weight distribution hitch that transfers load to the already higher loaded front axle will not improve your handling, and may even make it worse.
Mergatroyd is offline   Reply With Quote
Old 03-22-2017, 08:42 AM   #13
Gainesville , Florida
That is absolutely true. My one ton needs no WD but sway control helps.
Old 03-22-2017, 08:44 AM   #14
I've been trying to say that for a long time. My truck needs weight on the rear to handle properly. A little off the front actually helps. Adding weight to the front is nit needed.
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 10:13 PM
