Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 08-24-2012, 08:26 AM   #1
1991 Excella 29' Polished
Timofeevich's Avatar
1991 29' Excella
Odessa , Ukraine
Is this true : WDH does change the loads carried by ALL three axles !
Just came across the following :
'A WD system DOES CHANGE the loads carried by ALL THREE AXLES, reducing the rear axle load of TV while increasing the loads carried by RV's axle(s) and front TV's axle'.
Any WDH system WILL transfer some of the weight from the rear of the tow vehicle to the trailer axle, and how much goes to front axle vs trailer axle will depend on the ratio of the ball-to-axle distances...
Picture the extreme of the adjustment being set so high that the rear wheels are off the ground (like the old advertisement) -- The trailer axle is clearly supporting more than the trailer!
You can crank up those spring bars enough to counteract the nose-up tilt of the tug, or less, or more (yes, CD Smith, we know this is bad), or whatever you want until something breaks or the rear wheels come off the ground - even if there was zero tongue weight to start with. The amount of load it is able to transfer is not limited or affected by the trailer's actual weight distribution.
The WD system changes the distribution of the load, but doesn't move any mass anywhere, and therefore it can't (nor can any technology known to science) make the weight happen anywhere other than where the mass is. The tongue weight stays where it always was, on the hitch ball. It's just a matter of which tires support the whole mess.'
Is above statement 100% true and correct ?
Timofeevich is offline   Reply With Quote
Old 08-24-2012, 08:45 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The best way to verify this is to take the rig to a scale. Weigh each axle independently. On both the trailer and TV. Then release the tension on the WD bars and weigh everything again.
You will get every opinion under the sun on this subject. So why not just go to the scale? And see for yourself.
Old 08-24-2012, 09:17 AM   #3
Ag&Au's Avatar
Port Orchard , Washington
My opinion is that it is basically describing what happens. One problem comes up in a lot of these discussions and I think some of it is present in this above explanation. That problem is the interchangeable or incorrect use of the words weight, mass and force. If one wants to make a statement like this and have it be totally correct, the term weight should be left entirely out of it. It should be a discussion of forces only. Weight is a term used to describe the static force generated by a stationary mass in a vertical direction due the the apparent acceleration of gravity. Take for instance the statement that the tongue weight stays where it is. The force that is pushing down on the tongue is technically not weight. It is a force resulting from mass that is not directly over the trailer wheels acting at the end of a long lever (the trailer frame).
As long as one sticks with scientifically defined terms and uses methods taught in any basic statics course it is a simple process to analyze the forces present at any given point and the changes in forces if the position of any part of the system is changed. These forces can also be calculated in a system subject to external changing forces, such as a tow vehicle trailer combination traveling on the highway. However it requires a higher level of mathematics.
Therefor I take a careful look at any analysis of forces that uses the word weight.
Ken
Old 08-24-2012, 10:34 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It's a "loaded" question for sure and I like what TG and Ken say.
Simplest look at it, the weight distribution hitch distributes some of the rear axle weight to the front axle and the trailer. If you need to know exact numbers, weigh each axle. In theory it would be 1/3 of the added rear axle weight to the front axle, 1/3 left on the rear axle, and 1/3 to the trailer axle(s).
But transferring weight with these hitches can be increasingly difficult on tow vehicles with stiff suspensions and long wheelbases. Again, only a scale will be accurate.
doug k
Old 08-24-2012, 10:52 AM   #5
Retired.
. , At Large
The weight, force, mass, whatever you want to call it on the ball does not ch,ange, no matter where the force is redistributed. You can't lessen or increase that, you can only redistribute the force. So, if you have a receiver with a maximum capacity of 500 pounds, using a weight distributing setup will not remove any of the 600 pounds or so of weight from the receiver.
Old 08-24-2012, 10:59 AM   #6
When using a proper rated load equalizing hitch, properly installed, AND properly adjusted, two thirds of the trailer tongue weight will go to the tow vehicle and one third will go back to the trailer axle/axles.
Of the two thirds that go to the tow vehicle, one fourth of that should go to each tire, but again, if everything is correct.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-24-2012, 11:36 AM   #7
dkottum's Avatar
True, but does it matter. If the receiver and its mounting are strong enough, and it is the rear axle load you are concerned with, some of the weight on the rear axle is no longer there. In fact you can lighten the rear axle with a weight distribution hitch so that the vehicle is dangerous, not enough traction to control the trailer.
doug k
Old 08-24-2012, 02:35 PM   #8
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Andy,
So if I read you correctly an example might be-Starting with 900 lbs tongue weight (i.e. on the ball) without WD bars installed or adjusted. After proper installation of bars and adjustment results in 600 on the ball, with 150 lbs on each of the 4 corners of the TV. 300 lbs then go back to the trailer axles.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 08-24-2012, 04:51 PM   #9
Retired.
. , At Large
NO.
900 pounds is on the ball, no matter if you move 1 pound or 900 pounds to the front axle. Period. The amount of weight on the ball DOES NOT CHANGE.
Old 08-24-2012, 05:42 PM   #10
dkottum's Avatar
Doesn't matter what's on the ball if the receiver and it's attachments are stout enough to hold it. What matters is that the load on the rear suspension and axle is reduced.
For example, Can-Am RV uses this principle to take a small, lightweight but good handling tow vehicle, reinforce the hitch, install an appropriate weight distribution hitch, better tires and good brake controller and produce a successful tow vehicle for his customers. Not all agree with this approach but the customers are quite pleased.
Some mfg's raise hitch weight limits on their trucks with weight distribution even though the hitch remains the same.
doug k
Old 08-24-2012, 09:57 PM   #11
crisen's Avatar
Fairbanks , Alaska
NO.
I see no reason to be rude and shout. My post was directed at another person asking them to clarify their statement, it had nothing to do with my understanding or lack thereof of the orginal question. I realize this is a public forum and anyone can comment on any post, but this seems out of line.
Rick
Old 08-24-2012, 10:18 PM   #12
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
It's not quite as simple as the 1/3 rule... but that's a reasonable approximation for most designs. What you need to look at is the levered force you are creating... and like any lever, the length from the fulcrum that the force is applied. For example, if you had a 100' long trailer with the wheels 80' back, the weight transferred to the rear axles would be minimal because the lever is so long (just using extreme figures to make a point).
Likewise going the other way, if your receiver is very close to your rear axle, like many SUV's, you can run into making the rear end too light because of how close the force is applied in relation to the rear axle.
The first statement is 100% true... not 100% of the science of it, but its points are true. WD is sort of like wheelbarrow handles for your tow vehicle. When you lift up on a wheelbarrow, it doesn't get lighter... part of the load is now in your hands, the other part is transferred to the wheel. With spring bars, the trailer frame becomes the arms and the bars are the handles. The result is the spring bars are trying to lift the rear of the TV... the 'feet' of the equation are the tires on the trailer... which just happen to be a ways back (which is why they get less force than the tow vehicle).
Friday is offline   Reply With Quote
Old 08-25-2012, 08:08 AM   #13
Andy,
Absolutely correct.
Scales can easily document those weight changes.
The weight on the ball can actually decrease to zero.
Weight tests confirm that.
An opinion, is just that, with no documentation attached.
Many many years ago, Caravanner Insurance and I did tons of tests proving what did and did not happen with load equalizing hitches.
We also proved over 85 percent of the time, what caused "loss of control" accidents, yet some say that cannot be done.
The laws of Physics still applies, no matter what an opinion may be.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-25-2012, 08:43 AM   #14
Retired.
. , At Large
Okay, I am going to try this one more time, then I am going to give up and let people believe what they want. Moving the force on the ball does not change the weight on the ball. That is like getting an elephant to stand on one foot, to make him weigh 75% less.
Old 08-25-2012, 09:10 AM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
Yes, the weight borne by the receiver on the tow vehicle is unchanged.
In my tyro towing days, I improperly closed the latch on my ball. I engaged the WD bars and they popped the trailer hitch completely off the ball. Nobody was hurt and I quickly lowered the tongue jack to stabilize this mess. I concluded that the spring bar engagement sockets on my truck's hitch bar accounted for much of the tongue weight transfer in my case.
5 meter Langford Nahanni
Old 08-25-2012, 09:11 AM   #16
Ag&Au's Avatar
Tongue weight?
I would like to make one comment about what happens to tongue weight when WD is in use. The discussion of does it change is actually a discussion of semantics. Before the trailer is coupled to the TV, the "what is being called tongue weight" is actually the resultant downward force of a complex shaped mass resting on one or two fulcrums (the axles) As soon as you couple the trailer to the tow vehicle, the tow vehicle and trailer become one system and you cannot calculate the vertical force at the trailer hitch without taking the geometry of the total system into account. From this point on, the hitch of the trailer is tightly coupled to the hitch on the TV and they are the same point. From this point on there is no such thing as trailer tongue weight. It does not exist as a single force. So as far as I'm concerned the argument is about something that no longer exists. Both statements," tongue weight changes" and "tongue weight doesn't change" are true when looking at some part of the system only. However, when looking at the coupled system, the term tongue weight no longer has any definition. So you are basically arguing about how to look at something that has no defined meaning. When the TV and trailer are stationary, the only thing we know for sure about that point in the system is that the sum of all forces at that point is zero. If it were not zero, that point would be moving.
Ken
Old 08-25-2012, 09:36 AM   #17
2005 28' Safari
saline , Michigan
Perhaps a better term would be apparent tongue weight.
Kosm1o is offline   Reply With Quote
Old 08-25-2012, 09:44 AM   #18
HowieE's Avatar
Princeton , New Jersey
Images: 12
Most of your comments are correct. While the tongue weight exerted by the trailer does not change the force on the ball does. In order for a WD hitch to transfer weight it has to create forces and if you accept the theorem that a state of equilibrium exists after hitched than the force used to distribute weight to the trailer and the TV has to be reacted to somewhere. That point is the ball /coupling. Equal and opposite reaction.
2004 Excursion 4x4
Old 08-25-2012, 09:52 AM   #19
Ag&Au's Avatar
The real problem is not what it's called. The problem is how it's defined, and is everyone in the discussion defining it the same? We are so used to saying the word weight interchangeably with both mass and force that the only place it seems to have common meaning is when it comes to "how hard is it going to be to pick it up". If we nail it to the floor with weightless nails does it weigh more? Of course not or maybe depending on what weight means. however put that object in a complex system, and the question of does it weigh more or less is lot harder to answer. What does "weigh" mean in that system where the object no longer exists as a single entity?
Ken
Old 08-25-2012, 02:18 PM   #20
1991 29' Excella
Odessa , Ukraine
How is this possible ? I can't understand... If you don't move your stuff inside the trailer backward and don't move the axles of RV forward, then the weight on the ball can't decrease to zero ! Do you mean the down force applied to rear axle of TV can decrease to zero if spring bar set too tight ?
