Old 11-08-2010, 07:14 PM   #29
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Bad experience is a good teacher
I had the towing experience that will make a sway control bar believer quickly!!! I was towing a dual axle utility with a one ton dually. I had a blow out on the trailer and the load shifted. The ride of a life started quickly. The trailer started to sway so I slowed down the sway got worse. I quickly surmised that maybe if I sped up a bit I could pull out of it. the sway got worse!!! I was lucky and on a four lane with really wide shoulders. I thought I better get this thing off the road before I hit someone. WWWEEELLLL when I hit that grass things really went wild. I locked up the brakes and needless to say I was quickly jack knifed and in for a ride. That grass was like sliding on grease, seemed like my speed increased. Thank goodness there was a fense that finally stopped me. Need i say more, that trailer had no brakes , or sway bars on it. After totalling out bouth units I won't pull without them, when you really need them it is too late.
Tow safely
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 11-08-2010, 08:30 PM   #30
Wayward's Avatar
Cary , North Carolina
F350 dually short bed
Originally Posted by 2airishuman View Post
ford does NOT offer a 350 dually with a short box.
cheers
2air'
Few and far between here, but there are few in crew cab. Great looking trucks.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-08-2010, 10:18 PM   #31
_
the 156 inch wheelbase dual rw 350 was discontinued 3 years ago.
prior to 08 it was special order and only available in black or white.
dodge still offers the short bed drw trucks.
cheers
2air'
Old 11-08-2010, 10:24 PM   #32
richinny's Avatar
2011 34' Classic
Originally Posted by r carl View Post
I have never seen a w/d or anti-sway setup on a trailer except a tt, and I see lots of trailers...
i see many guys using them at raceway park in englishtown nj
Ricky
Reese Dual Cam Sway for Explorer pulling Bambi ?? SoonerStream Hitches, Couplers & Balls 5 02-27-2010 01:02 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
even bambi needs sway control 2airishuman Hitches, Couplers & Balls 74 10-31-2007 10:03 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Sway Control for Bambi Safari 19' jschelle 1997 - 2004 Bambi 5 05-10-2004 02:40 PM
