Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-28-2003, 04:33 PM   #1
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Question Interesting Reese hitch experience...
Here's a new one for me... When I bought the 34' trailer, it came with a Reese Dual Cam hitch head with a longer-than normal standard drop bar and 1000lb bars. The head has provision for two friction sway bars.
I have adjusted and adjusted the hitch head, but the connection to the trailer always feels sloppy, and I noticed that if I adjusted the 1000lb bars too tightly that the hitch drop bar would bend up a half-inch or so. I definately needed both of the friction sway controls towing to keep sway under control. While it works ok, it was scary enough that I've been seriously contemplating buying the Hensley.
I had a "high-performance" drop bar and hitch head with a single friction sway control ball in the garage that I've had for a couple of years, but only used once. I hadn't used it for the 34' because it only had the single friction sway control mount, and I thought that because the other hitch head had two, I must need to have both!
I towed the trailer out about 11 miles to a campground last Thursday with the older setup with just the dual-cam bars setup but without the friction sway controls and it was vague and scary. Just to see what the difference would be, if any, I put the "high-performance" hitch head on (again without the friction sway control), adjusted it properly and towed the trailer home today. It was an entirely different experience with this other head. The entire truck and trailer moved as a unit, the way it's supposed to and there was no vagueness in the feel at all. It didn't porpoise over the road like it did on the way out. The difference was amazing.
Anyone have any ideas at all about why the two Reese hitch heads should respond so differently? I am baffled! I'm pleased about the performance of the new head, and because of it's stability compared to the older one I'll definately be using it in the future; but I'm still baffled!
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 07-28-2003, 05:20 PM   #2
drboyd
drboyd's Avatar
Profile:
It sounds like...
...your "standard" head is dangerous and about to break, or something like that. It's really, really not supposed to bend half an inch. That's a heck of a lot, IMHO.
The flex is not letting the dual cams work like they should, thus leaving you with the friction bars only.
The "high performance" head is keeping the bars properly tensioned, and thus letting the dual cams work like they should.
I'm guessing here that you have a Major Heavy Duty tow vehicle, (1 ton dually, maybe?) and the lack of weight distribution effect with the standard drop bar setup isn't readily apparent....
Old 07-28-2003, 05:30 PM   #3
85MH325
85MH325's Avatar
Images: 37
Re: It sounds like...
Well, it's heavier-duty... but not that heavy... it's an Excursion which is a 3/4 ton chassis. That makes sense, tho, about the flex. I wondered if the extra-long bar let it flex too much. The Excursion does sit down when the tongue is put on it, but not much. I don't notice much effect from the WD bars on the Excursion, unlike a passenger car where the effects are pretty dramatic.
Roger
Old 07-28-2003, 05:34 PM   #4
drboyd
drboyd's Avatar
Profile:
Does the Excursion have...
....an automatic rear levelling system?
I'd just use the standard duty head as an auxiliary anchor on your boat, or something.
Old 07-28-2003, 06:09 PM   #5
85MH325
85MH325's Avatar
Images: 37
Re: Does the Excursion have...
I think it's going to be a king-size paperweight!
No, the Excursion just has plain old shocks and coil springs (I think... I'd better look!)
Roger
Old 07-28-2003, 06:17 PM   #6
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
roger
hitch head angle adjusted different on the two?
i'd bet the "good" one has the proper 15 degree angle on it.
just a thought!
john
Old 07-28-2003, 06:39 PM   #7
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Re: Re: Does the Excursion have...
Roger
With all that luxury around you Roger, your starting to slip!
Maybe a downgrade might be the solution. Then again, you were going to donate that rig I thought to get me out of the entry level arena!
You know the mind is the first thing to go!
Eric
Old 07-28-2003, 06:58 PM   #8
85MH325
85MH325's Avatar
Images: 37
Originally posted by john hd
roger
just a thought!
john
Good thought, John... but I had them both at 15 degrees. That's why I'm so surprised at the difference in performance!
Roger
Old 07-28-2003, 06:59 PM   #9
85MH325
85MH325's Avatar
Images: 37
Re: Re: Re: Does the Excursion have...
Eric
Yes, well... the life of idle wealthy will sometimes do that!
Roger
Old 07-28-2003, 07:47 PM   #10
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Roger!
I am not certain from your description, but it sounds like you may have one of the special Reese draw bars from the 1980s/1990s when conversion vans with rear mounted spare tires were so popular. I had one of these, and the special Reese draw bar increased the distance from the front edge of the receiver to the hitch ball by from 3" to 8" depending upon application (the theory was to allow for turning clearance between the rear mounted spare and the trailer). I suspect that they were likely discontinued sometime ago as they did, in my experience, just what you describe - - made for very "squirrelly" towing performance - - one of the reasons that I kept my conversion van for only two seasons. I was told that one of the problems was that this draw bar increased the distance from the centerline of the tow vehicle's axle to the hitch ball which resulted in a change in the geometry of the hitch setup increasing the trailer's influence over the tow vehicle. I am not certain, but seem to remember that these longer draw bars also had a diminished weight rating - - it wasn't something that I was concerned with as my trailer at the time that I had that setup only weighed 4,000 pounds.
Kevin
Kevin D. Allen
AIR #827
Old 07-28-2003, 08:36 PM   #11
Silvertwinkie
Aluminut
Talking Re: Re: Re: Re: Does the Excursion have...
Roger
You crack me up!
Old 07-28-2003, 09:24 PM   #12
85MH325
85MH325's Avatar
Images: 37
Re: Interesting Reese hitch experience...
Originally posted by overlander64
Greetings Roger!
Kevin
BINGO, Kevin! You nailed it... mystery solved! The folks we bought it from towed it with a B-van with a swing-away spare!!! Thats exactly it! No wonder it acted so strangely on my Excursion!
My Safari trailed like it was welded to the truck and I expected the 34' to be the same, but it wasn't. I attributed the 'squirrelly' performance of the 34' to the trailer rather than the Reese setup. I'm glad I had the 'standard' length draw bar to try.
Thanks for figuring this out for me. It was a 'puzzlement'!
Roger
Old 07-29-2003, 06:54 AM   #13
85MH325
85MH325's Avatar
Images: 37
Lightbulb Re: Does the Excursion have...
For Inquiring Minds Who Want to Know...
I checked under my Excursion this morning. It's a standard old leaf-spring/shock suspension system. Nothing special or trick about it. I'd forgotten how physically large the axles are on a 3/4 ton truck tho!
Roger
Old 07-29-2003, 07:12 AM   #14
qqq
qqq's Avatar
Profile:
I tow with the ball only, & it handles 100% perfect in all circumstances, mountains, sharp bends, trucks etc...
& thats a FACT. Those who think otherwise should try & I bet you will love it.
Hart
qqq is offline   Reply With Quote
Reese STRAIT-LINE® HITCH 800 mopar7 Hitches 3 11-29-2003 11:34 AM
Reese hitch dlorahcof Hitches 3 09-13-2003 05:11 PM
