Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 12-08-2007, 01:52 AM   #1
team_no
team_no's Avatar
Profile:  1966 26' Overlander
Mesa , Arizona
Industrial Utility bed / hitch attachment question
Okay . . . lets say this is all hypothetical . . . .
WHAT IF I was getting a TV that was equipped with a Utility bed (say, something like this: http://tinyurl.com/2go75v) and it had a thick, 1/4 steel integral bumper on it that looked something like this: http://tinyurl.com/2fkoj5 ) and I already had a monstrous ball mount with a Reese Strait-line hitch with dual cam sway control . . . what would be the best way to mount the existing Reese ball mount to the bumper?
Here are the only two options I see:
1. Purchase a frame-mount trailer hitch for the specific model vehicle and hope that the utility bed does not occupy the factory frame mount bolt holes;
2. Weld a receiver tube such as this one http://tinyurl.com/247eqw onto the bottom of the utility bed.
I will have the additional problem of dropping the hitch ball to the appropriate height, but I will cross that bridge when I get to it. I have all of the Reese documentation for determining proper height, etc., for my particular TT but I'm still not sure of the height difference with the prospective TV.
Hypothetically, that is.
Thoughts, opinions, etc., would be much appreciated.
Regards
Bill
1966 26' Overlander
1993 LE D350 Dually TV ("it's a creampuff!")
Team No Adventure Racing
Mesa, Arizona
team_no is offline   Reply With Quote
Old 12-08-2007, 06:18 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Bill, I would take a sawazall to the industrial-strength bumper where the ball mount is, and mount a factory-type receiver on the frame of the truck so I can use the dual-cam head. Alternately, I would cut a 2 1/2" square hole in the bumper where the head would go with the frame mounted receiver, and slide the head through the hole to attach.
You can readily get 6"+ drop mounts at your local hitch supply store.
Hypothetically, of course...
Old 12-08-2007, 08:13 AM   #3
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Reese Dual Cam
Given the suspension under a truck outfitted like that, would there be enough weight on the cams at the end of the spring bars to really let the dual cam do it thing and prevent sway?
After all, the reason the dual cam worked so well with the old cars that it was designed for was because you really needed the weight distribution function to keep the rear bumper from dragging the pavment. You literally had all the tongue weight presing the spring bars onto the cams.
Beginner
Beginner is offline   Reply With Quote
Old 12-08-2007, 08:15 AM   #4
overlander63
Rivet Masher
L.A. , California
He would want no more than 750 pound bars, and preferred 500's--if he could find them. He needs to have enough deflection in the bars to use for sway control, without beating the trailer to death.
Old 12-08-2007, 08:25 AM   #5
safari 28
safari 28's Avatar
Profile:  2004 28' Safari
holland , Michigan
Well I will let you experts figure out how to make this work safely. It appears to be f350 or greater so being careful not to jar the trailer to death is important.
What looks interesting is all the secure water tight storage he will have. I bet those on a tight budget would find these for sale in fleets at the right price with decent history and maint programs. For the all the diesel lovers in this forum it maybe a cost effective way to get into a power stroke. Not for me, but different strokes for different folks. No pun intended.
safari 28 is offline   Reply With Quote
Old 12-08-2007, 08:33 AM   #6
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Hypothetically, a bumper hitch like the one shown in your examples is designed for a heavy industrial load, but not for the open highway.
If that were my rig, I would add a class V receiver and make whatever adjustments are necessary to get it mounted. For weight distribution equipment to work properly, you will need a properly installed receiver.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 12-08-2007, 09:29 AM   #7
jkcru
jkcru's Avatar
Profile:  1976 23' Safari
Escondido , California
Hypothetically with a TV that heavy would an equalizer hitch be necessary, perhaps a standard class V + dual friction sway control would carry the load safely. Hypothetically of course.
jkcru is offline   Reply With Quote
Old 12-08-2007, 12:33 PM   #8
team_no
team_no's Avatar
Mesa , Arizona
Trunnion bars, new ballmount, etc.
Thanks to all. In war-gaming this in my mind, I'd never thought of using the existing ball on the bumper . . . apart from it likely being entirely too high, I would not be able to use the Reese ball mount (which has the provisions for the trunnion bars). My TT came with an old skool Reese Strait-line hitch with the trunnion bars that have replaceable friction points (as opposed to none, as the new ones are).
So, I had expected to have to get a frame-mount hitch (though I had assumed Class IV would be sufficient).
As far as dropping the height of the ball to within the specs offered by both Airstream and Reese, my existing ball mount is this glorious beast:
http://www.lassendas.net/temp/ball_mount_1.jpg
http://www.lassendas.net/temp/ball_mount_2.jpg
Which, while intimidating and massive in its bulk, is not adjustable. Likely I will have to buy a replacement Reese ballmount hitch which allows for height adjustment on the hitch bar (as well as angle of ballmount).
Hopefully, I can find one locally, that is, if I were to get a beast of a truck.
One last question: does anyone have the measurements for the older Reese trunnion bars? I do not know if I have the 500 b. or the 750lb. and I know it makes a difference. If I recall, their length is different by a matter of a few inches.
Regards,
Bill
1966 26' Overlander
Mesa, Arizona
Old 12-08-2007, 12:44 PM   #9
overlander63
Rivet Masher
L.A. , California
Regards,
The weight distribution capacity is measured by the thickness (height) of the bars. 55 pound bars are thinnest, then 750's, and 1000 pounders being thickest.
Old 12-08-2007, 12:59 PM   #10
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 40
Regards,
Wow, those welded ball mounts are worth their weight in gold and are getting hard to find. Many of use use and preferre this type of ballmount over the bulky, adjustable models.
In many ways they are the best ball mount because they allow the ball to be as close as 3 inches from the back bumper (reducing flex).
They are actually adjustable. A good welding shop will cut them apart and reweld them to your specifications. This process can be done up to 3 time without affecting the integrity.
As far as your hitch goes I would find a good old fashion hitch shop and get them to fabricate you a good hitch/receiver, for that vehicle.
Good luck with the project.
1966 Overlander Bed Question Dureedesign 1966 Overlander 0 05-14-2007 08:35 PM
Twin bed support question RNR General Interior Topics 3 03-04-2007 05:44 PM
Poll: What's your favorite utility when camping? Silvertwinkie Our Community 24 03-26-2003 04:39 AM
Bambi Bed Question DreamStream Our Community 2 02-19-2003 08:32 AM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 09:01 PM
