Old 11-10-2011, 12:51 PM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
In the continuing quest!
to sort it all out.....Escapees RV Club offers a "smart Weigh" program to weigh one's rv using the single wheel scales....and so i was able to take advantage of this and am now trying to sort it all out.....
so the total trailer axel weight was 5750 lbs
tow vehicle with trailer was 8130
tow vehicle without trailer was 6900
so then (they say) tounge weight is 1230
and GCVW (combined TV/Tr) 13, 880
so does it follow that the total trailer axel weight plus the tounge weight constitutes the GVW of the trailer (6980) out of a 7300 lb state GVW
is the only out of place figure the 1230 pound tounge weight???????
my equal i zer has 1000 lb bars??????
the GCVW for my tow vehicle is 16000 lbs......
any thoughts????
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 11-10-2011, 01:10 PM   #2
dznf0g's Avatar
Oswego , Illinois
That's a lot of tongue weight for a 25'er. I would try and shoot for 700# to 1000#, and I would prefer about 850#.
I think you should move some stuff around in the trailer and see if you can get there. I would lose the 1000# bars and get a hitch with 600# or 800# bars. IMHO you're kind of stuck inbetween). I would probably shoot for 800# on tongue weight and get 600# bars.
My trailer weighs 8500# loaded for travel and I have a tongue weight of 950#. I use 800# bars and I think the setup is perfect.
-Rich-
Old 11-10-2011, 01:21 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
any thoughts????
thanks
KF,
The 1230 sure seems high.
Before going to the scales i know our loaded un-hitched TW was 1175lbs,(Sherline Scale), You can see from the tickets what our weights were and how much weight was transferred forward and back to the AS axles.
I would recommend a trip to the CAT's to solve the mystery.
Name:	CAT Weights.jpeg
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 11-10-2011, 02:51 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
My 34' doesn't have that heavy of a tongue! I would suggest either you have a lot of "stuff" loaded forward of the trailer center of gravity (CG) or the scale is off somehow. It would be better from a towing standpoint to move some heavy items back to the axle area of the trailer. Also, if you move just a few smaller items to the rear of the trailer, with a 25' moment arm you will cause large changes in the tongue weight.
If you are bored and want to know how weight shift effects balance follow the link below.
Weight and Balance
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-10-2011, 03:06 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
any thoughts????
thanks
The figures you cite are not unusual and are not necessarily a cause for concern.
The tongue weight, while high, is only slightly higher than the typical recommendation of 10-15%.
I would suggest that your next move is to check the front axle weight of the truck hitched and unhitched. It is common for people to have their hitches set up to provide insufficient weight distribution. A properly dialed-in WD setup will reduce the tongue weight somewhat as some of the load taken off the rear axles of the truck will be carried by the trailer axles.
Ideally the front axle weight should be the same both hitched and unhitched. If the front axle weight is lower when hitched that would indicate a need for more WD.
Once you're sure you have the WD dialed in properly, if there's still a problem, you can consider moving some heavier items from the front of the trailer to the rear.
Old 11-10-2011, 04:21 PM   #6
Thumbs up
Weight and Balance
Aviator,
POI...our hitched, WD adjusted tongue weight, 985lbs, in line with totals. And yes heavy stuff is loaded forward where the WD's can be used to transfer weight as needed.
I always use the Sherline Tongue scale after loading and before hitching to get an accurate reading, and adjust as needed. This is why it's important to visit the CAT scales.
Loaded and level, this photo matches the CAT tickets posted above.
PFC
"Tahawus"
RLC
John Prine
Old 11-10-2011, 05:19 PM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Bob, I appreciate that. Our 34' runs in the upper 700's and the 1230 number struck me as hi, thus my comment. As a still working family, our outings are mostly weekend type stuff so we run well under the max weight for the trailer. It would be much less than someone spending more time on the road.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-10-2011, 07:18 PM   #8
Craig,
Took me awhile, (years actually), to get used to just how weighty the Classic is after towing our 63 22' Safari around for 18 Seasons.
PFC
"Tahawus"
RLC
John Prine
Old 11-11-2011, 06:23 AM   #9
Islander
more
front axle with trailer.......3130
front without trailer.........3290
so that is really not a significant difference......
my 8d batteries (2) loaded in the front of the trailer ....add 225 lbs more than the normal batteries........
rear axle with trailer........5000
rear axle without trailer.....3610
rear axle of truck is rated 4000 lbs, but tires are 3200 lbs each......
so all of this tells me what......
Kingfisher24
WBCCI 2541
4CU
Old 11-11-2011, 07:19 AM   #10
KF,
Well, you already know the TV rear axle is overloaded.
One thing not illustrated is how much weight is being transferred forward to the TV front axle and rearward to the Trailer axle. How is the WD set-up?
You can see in the CAT tickets I posted that without WD our rear axle is over by 20lbs and with WD adjusted under by 820lbs. It's important to know how much is being transferred.
PFC
"Tahawus"
RLC
John Prine
Old 11-11-2011, 07:35 AM   #11
Mr & Mrs S's Avatar
Newton , Texas
Hmmm
Kingfisher,
Ive taken intrest in loads lately and when I rolled across the scales with our 29 foot Excella my numbers from the Cat Scales were as follows:
Steer axle: 4580
Drive axle: 4760
Tralier axle: 6560
Gross weight: 15900
Id be concerned with the weight difference between your front and rear axle.
Im by NO means an expert in hitching but seems like your front and rear axle should be closer in numbers.
Maybe when you come out to the rally in the Piney woods we can compare our hitching and load process.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Capt. Wilson's 1959 Overlander nmbosa 1954 - 1959 Overlander 309 05-09-2016 01:18 PM
Taking the Hoosier tour kingfisher24 On The Road... 20 05-15-2011 05:24 AM
Looking for an Unger CtRobert Classic Motorhomes 13 02-17-2011 07:07 AM
Ammeter connection bridor15 Batteries, Univolts, Converters & Inverters 8 02-13-2011 06:19 AM
