Old 05-02-2015, 10:30 PM   #1
I Need Photos/Diagram of Reinforced Mercedes Hitch
If anyone has pictures or diagrams of a reinforced Mercedes hitch, I would appreciate it. I want to get my GL450 hitch reinforced like they do them at Can-Am but not wanting to drive 2000 miles to do it.
jonnie3 is offline   Reply With Quote
Old 05-03-2015, 08:41 AM   #2
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Check out this thread on ClubTouareg. Not your vehicle, but will give you the idea. Can-Am use (what looks like) 2.5" box section directly in between the chain attachment loops then a smaller box section, probably 2" square, slid up inside the larger section welded with some reinforcement either side. This section is bent to closely follow the line of the rear muffler. Attachment is made to the rear suspension mounting frame using what looks like 0.25" plate. This connection can also be bolted rather than welded. I have a picture of that from Can-Am I'll post later.
http://www.clubtouareg.com/forums/f6...t-70382-2.html
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 05-03-2015, 02:03 PM   #3
Thank you for the info!
Old 05-03-2015, 05:13 PM   #4
Ohiobrits's Avatar
Howard , Ohio
Photos
These are photos for different vehicles, looks like Touareg and Audi Q7 but will give you the idea. I'm sure I saw photos of a Mercedes with similar mods but could not find any.
Note that this mod does reduce ground clearance by about 2".
ID:	237674   Click image for larger version
Name:	Q7 hitch mod - mounting at subframe.png
ID:	237676   Click image for larger version
Name:	Can am mod forum 1.jpg
Old 05-03-2015, 08:15 PM   #5
Thank you so much!
Old 05-04-2015, 11:23 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I think Rich Luhr has a few picture on his blog. Airstream Life.
Bill
Just my personal opinion
Old 05-04-2015, 06:27 PM   #7
U.S. Navy, Retired
Silverleaf's Avatar
1997 30' Excella
Cumming , Georgia
Each one is different, sometimes for even the same model. Mine goes through the shroud that covers the air suspension when so equipped. Mine isn't, so no loss of ground clearance. If I had that option they would have had to build around it. Main items added in my case were the forward brace, an extended receiver tube, and beefed up weld and gussets at the semi circle factory welds - the infamous weak leak on MB hitches.
Bill & Barbara
WBAC 3615 AIR 77452
1997 Excella 1000 Classic 30 (Silverleaf)
2015 F150 3.5L EcoBoost (Redford)
Silverleaf is offline   Reply With Quote
Old 05-04-2015, 10:08 PM   #8
Lexington , Kentucky
We have the same bracing (done by CanAm) on our 2015 X5 diesel. Very simple but very effective.
wlanford is online now   Reply With Quote
Old 05-05-2015, 01:14 AM   #9
Thank you
L@K Airstream Mercedes Diesel Westfalia RV Class B OnaN SL@K Airstream Mercedes Diese eBay Watch Airstreams on eBay 0 03-28-2011 01:00 PM
'89 Excella, Mystery wire bundle, hitch area, photos cjack99 1987 - 1989 Excella 3 01-27-2011 04:03 PM
Fiberglass Reinforced Panels........ RV H-D Lady Sinks, Showers & Toilets 2 11-09-2010 07:15 PM
Fiberglass Reinforced Panels........ RV H-D Lady Upholstery, Blinds, Walls & Interior Finishes 3 11-07-2010 05:14 PM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
