Old 10-28-2010, 11:43 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I found this hitch...what is
I was working at my paint job today and went around to the Salvation Army dumpsters to retrieve some T- shirt rags, and this was laying down in there,
I already have an old reese hitch...but does anyone know anything about this one by looking at it? Thanks, I am sitting here for a while. Bill PS I am not this smiley character.
ID:	114132   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 10-28-2010, 12:01 PM   #2
VIKING's Avatar
Boulder Creek , California
It looks like an old EAZ-A-LIFT, but I haven't seen one with the little vertical posts. Maybe they were added as a place to hook the chains onto (which is a big no no cause if your hitch-pin fails or falls out, you loose the whole connection to the TV).
The bars and other parts were not there?
Rich the Viking
VIKING is offline   Reply With Quote
Old 10-28-2010, 12:03 PM   #3
1970 27' Overlander
I will be going back after lunch to look further down...
Old 10-28-2010, 12:04 PM   #4
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
How about attaching the trailer safety chains to the posts? ? ?
62bam is offline   Reply With Quote
Old 10-28-2010, 01:38 PM   #5
VIKING's Avatar
See my earlier post for explaination.
Old 10-28-2010, 01:39 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe the posts are for friction sway control. Either homemade or old fashioned.
Old 10-28-2010, 01:54 PM   #7
1986 25' Sovereign
Plant City , Florida
It looks like it is a standard hitch that was modified to have sway control. I almost looks like some one could have put shocks on both sides over the post for a crude sway system. They could have on the other end a simalar post with a pin to hold it on.
Just my .02
ck21084 is offline   Reply With Quote
Old 10-28-2010, 03:01 PM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
There are hollow round tubes to insert round W/D bars from the bottom. I think it is an early Drawtite. The vertical pins look like some homemade frictional dampener pivot points. Not much good without the W/D bars and the frictional shocks that went over the pins.
Old 10-28-2010, 09:51 PM   #9
1970 27' Overlander
I will try googleing it...still wondering, There were no other parts to be found. And there is no makers mark on it either.
Old 11-02-2010, 07:39 AM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I have towed with this type of hitch and sway control before. The sway control (shock absorbers) are attached to the A-frame of the trailer. The welded ball mount that you have in the pic looks to be an Eaz-Lift.
Just found the Advertisement in an old trailer magazine;
Saf-T-Trail Sway Control
The ultimate in towing safety
Sold by Northwest Marketing and Manufacturing Co
Billings, Montana
This magazine is from 1971
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
We've found the one! stephenh2 1974 - 1979 Sovereign 4 05-31-2010 08:22 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Found Original Hitch augier Hitches, Couplers & Balls 14 01-09-2009 10:33 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
