05-15-2012, 01:29 PM
#21
Master of Universe
2008 25' Safari FB SE
Grand Junction
Michelle,
That sucks. The first time I kicked something because I was angry, my foot hurt so much I now control that desire. I hope your foot is ok.
You've certainly been tested over the years. I will never forget the photos of your accident near Yellowstone and reading about the adventure near Denver when the cop hit your truck on I-70. And there was the bent part from your Reese hitch that we straightened here destroying in the process a pipe wrench. I keep it as a souvenir of your visit.
Looks like you got off pretty easy on this one considering all the damage that could have happened in the middle of town. But I'm sure that doesn't make you feel any better right now. You've been through a lot with Buttercup and I'm sure you miss flying a lot, but you are strong enough to get through it again. You know the script—curse for a while, get it fixed, sell it, buy something that suits you better now and keep traveling.
Gene
05-15-2012, 01:54 PM
#22
Jupiter
Howdy & ouch..... Happily, no van full of orphans driven by a nun and a horse drawn cart weren't involved, eh?
I'm wondering if there was a lubrication schedule you followed, and if so, what lubricants were used as 80,000 miles is a respectable figure even if it was test-to-destruction.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
05-15-2012, 02:51 PM
#23
Ottawa
, ON
Originally Posted by ROBERT CROSS
Question...can't quite make out what exactly I'm looking at here?
I don't know either, but I think it's leaking.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
05-15-2012, 04:51 PM
#24
Sioux Falls
, South Dakota
....I now secure the latch down with a band clamp + the lock pin.
What's a band clamp?
Where do I git one?
05-15-2012, 05:22 PM
#25
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Where do I git one?
I only use it on the straight tongue coupler for the boat trailer. You can see how vulnerable the lock pin is. Run it thru the pin and around the tongue, I use the latch style.
05-15-2012, 05:51 PM
#26
Sioux Falls
, South Dakota
Oh, I gotcha! That's a cool idea, thanks for the reply and the picture.
05-15-2012, 06:56 PM
#27
1995 30' Excella
Bowie
, Maryland
Originally Posted by Fly at Night
Pardon my ignorance, I don't know what it's called, but there is a wire on my assembly which is supposed to stop the trailer automatically (after an unintended uncoupling).
Breakaway switch. But said trailer also has to get far enough away from the tow vehicle for that pin to be pulled, and given the damage it sounds like it didn't get far at all... in fact it sounds like it got too close.
The good news is that if the chains are still attached, the electrical connection probably is, too, so the trailer's brakes should still be working. But, things happen quickly in accidents, and your first warning is probably the sound of something hitting something else...
Sorry for your bad luck, Michelle.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
05-15-2012, 09:54 PM
#28
More than one rivet loose
Los Alamos
, New Mexico
my break-a-way cable is shorter than the full extension of my chains. it did activate.
my chains are way too long from the factory. they are shortened by ty-wraps.
Michelle TAC MT-0
Sarah, Snowball
05-15-2012, 09:59 PM
#29
Los Alamos
, New Mexico
that is the "battery box". on my trailer it holds the electric-hydraulic brake actuator.
Michelle TAC MT-0
Sarah, Snowball
05-15-2012, 10:06 PM
#30
Los Alamos
, New Mexico
Originally Posted by Steve & Susan
An Airstream can be fixed - people, not so much. How is your FOOT? That's a hell of a dent from your kick! I did that once to the kitchen cabinet and broke two toes.
My foot hurts. especially since I forgot that my right ankle has arthritis.
Michelle TAC MT-0
Sarah, Snowball
05-15-2012, 10:17 PM
#31
Los Alamos
, New Mexico
Cleaned and greased before each trip. I used petroleum jelly. It only stayed on for a few days at a time.
I went to the welding shop today. I have the old coupler. the front lip is gone. worn off. this would have been on the front underside of the ball. I have gone through several balls.
I will get a picture in the morning.
Michelle TAC MT-0
Sarah, Snowball
05-15-2012, 10:23 PM
#32
Los Alamos
, New Mexico
Where do I git one?
you can get one at the hardware store. get Stainless steel only.
also can be called a hose clamp. one brand name is Breeze or Ideal. There is another brand I prefer but it is too late to remember it right now.
Michelle TAC MT-0
Sarah, Snowball
05-15-2012, 10:51 PM
#33
Corpus Christi
Michelle, You're a very experienced RV'er and if this can happen to you, it can happen to any of us. It's a big "heads up" for me. I'll be sure to check mine. Thank you for sharing.
So Long!
05-16-2012, 12:03 AM
#34
2005 19' Safari
GLENDALE
, AZ
Thecatsandi,
I believe you mentioned that you have 80,000 miles on a 2006 Airstream, and I am curious about your statement that you have gone through several trailer balls. Were these actually worn out? I have towed quite a bit, but not 80,000 miles on one trailer; and I have never worn out a trailer ball.
Vaseline is a pretty thin, low temperature lubricant. I tried using it in roller skate bearings, and it liquefies and runs out. I wonder if this might be part of the problem.
We use wheel bearing/ball joint grease, which is much thicker and doesn't melt at normal temperatures. It is relatively resistant to water (though, not water proof) and stays where you put it. I think you may find this better suited for lubricating the mating hitch parts.
Please note that we live in Arizona (versus Montana), so I'm not sure whether this advice applies directly to your situation. Just a thought, though...
05-16-2012, 04:51 AM
#35
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I see it now...that's the brake line with the wound spring reinforcement that exits back towards the axles.
05-16-2012, 09:20 AM
#36
Los Alamos
, New Mexico
Originally Posted by Phoenix
Thecatsandi,
the balls were spawled. metal was flaking off. this should have been a clue. I was told to use vaseline since I would be replacing it regularly. hind site is 20-20. it should have been a thicker grease. although most of the grease went where the pressure are the "greatest", the top of the ball. the front of the ball has all the pulling force. there was grease there.
There is a lot of forces that come into play and I can see the basic ones but do not have all the information to see all the forces involved.
Michelle TAC MT-0
Sarah, Snowball
05-16-2012, 09:56 AM
#37
Common Sense
Steve,
I am a very experienced tower. I am familiar with a false hitch and how to check for it.
The event is behind me. now I have to get the truck and trailer repaired. The insurance company is replacing all of owing equipment on the truck. Hitch receiver, shank, head, ball. plug. pigtail. everything that was in use.
Yes, I understand you are a very expereinced "tower", as most of us here are. I was just trying to help, and not trying to question your capabilities.
However, maybe if you had checked for a false hitch, just maybe you would have found the bad part without the accident on the road, or maybe you did........
05-16-2012, 10:41 AM
#38
Master of Universe
Grand Junction
In any accident there is a lot of speculation and "should haves". I think we all want to figure out how something happened—that's ordinary human curiosity. I think we want to make sure it doesn't happen to us. But … let's be careful about how we discuss this so we don't victimize the victim. And it is natural to question everything.
Each time the trailer was fixed after previous accidents, the repair shop should have checked the coupling and probably replaced it if the accident could have compromised the coupling in any way. I believe after the Colorado accident, the trailer was fixed at Jackson Center.
The coupling actually lasted a very long time despite the stresses involved. Michelle has towed 80,000 miles with it, checked it and checks for false hitches. I wonder how many other people have replaced couplers after an accident or after tens of thousands of miles? Maybe we will think more about that—I was cleaning the old grease out of the coupler the other day and checked it very carefully. But I'm not sure I'd know whether it was starting to go bad. So does anyone know the life of a coupler?
I'm not sure grease is the answer. The grease is mainly to preserve the ball. Even so, the ball gets scratches and pits over time from the dirt that mixes with the grease. It can be argued that vaseline, because of its low drip temperature, is better because the dirt would wash out with the liquified vaseline. Also, the Owner's Manual says to lubricate the coupler with oil—so compared to that, vaseline is thick. I can't remember wether is was 30 wt. motor oil or "household" oil (various things on the trailer get different kinds of oil), but the point is Airstream recommends a lighter lubricant than vaseline. Because of the grease on the ball, I expect the oil used on the coupler is replaced by the grease anyway. I think Airstream means to oil the coupler latch, but some runs down into the rest of the coupler and maybe they mean that too should be oiled, not greased (I'd better check the manual again to make sure I am remembering this right because I can't be expected to remember something I read 2 days ago).
Gene
05-16-2012, 11:40 AM
#39
Corpus Christi
The biggest red flag so far has to be the "spawling" (spalling) of the ball. It takes one of two things to cause spalling, either extreme loading, or low grade metal used to make the ball. I can't imagine loads being that extreme, so I would check and/or replace the ball with a different brand. About the only spalling I've ever seen was steel wedges driven into wood by a sledge hammer.
So Long!
05-16-2012, 12:44 PM
#40
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Sorry for the problem. Sure looks like another 3 miles would not be a problem. The false hitch thing. Not on an airstream. I pulled a golf cart to Florida with a landscape trailer. Hitched it up, checked with the hand crank to be sure it had it, drove the golf cart on, went to florida. There I backed the golf cart off, the trailer jumped off the ball, and the tongue hit the middle of my tailgate pretty hard. Difference, I was pointed downhill at home and the trailer was pushing slightly when I checked. I Fl I unloaded with the trailer pointed up hill and the ball was just loose enough and well greased enough to come off. If there is pressure foward or back even a loose couple may pass a stationary load test. Glad it did not happen on the way. I now have that thing tightened up to where I have to stomp on it to close it down.
