04-27-2011, 02:56 PM
Holly Lake Ranch
Huskey Anti-Sway Bar
About to pick up AS on Saturday and it has a Huskey WD hitch with an anti-sway bar. PO says he didn't use the sway bar because you have to put it on after you pull out onto a straight piece of road, otherwise turns will bend it. I searched sway bars but didn't find the answer to this. I want to make do with this hitch set up for a while but really don't want to tow without sway bar. All thoughts are appreciated.
04-27-2011, 03:23 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Friction dampener with sliding bar that is squeezed between two pieces of brake pad material have been known to be bent when making too sharp parking turns. You can make moderate turns without damage. Use the frictional dampener until you decide to change hitches. This bar is not a weight distribution bar.
04-27-2011, 03:51 PM
Holly Lake Ranch
Dwightdi
thanks fo the response. I realize that it is not a weight distribution bar. The hitch itself is wd hitch with rounded bars and chain set up. I think I've seen people refer to it as a cheaper knockoff of a Reese.
05-24-2011, 06:17 AM
Catawissa
, Pennsylvania
Anti sway bar for 1987 Excella 32'
Hi, We just bought our first Airstream, and it is missing an anti-sway bar. It has a hitch. Can I buy an anti-sway bar alone? What information will I need to purchase it? Can I buy it new from an RV dealer? My husband is out of town, and I am supposed to handle this, so any help would be very welcome. Thanks, Barbann
05-24-2011, 06:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes you can, most trailer supply stores will have it.
What it looks like...
"You don't know where you've been until you leave, enjoy life" RLC
05-24-2011, 11:12 AM
I've been using such bars for many years and have not bent any. I've been very pleased with the performance of these classic anti-sway units.
05-26-2011, 07:35 PM
Vintage Kin
Fort Worth
So long as they are disconnected when the roads are wet, the friction types can just barely rise above their innate doorstop quality. Best to get a better hitch type.
05-26-2011, 07:47 PM
2011 28' International
Chatham
, Ontario
Not been using ours long but they seem very effective. I have started to take them off for backing up, though, if only to stop the whale song effect.
05-26-2011, 08:06 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
It does depend upon what you're towing with. Those sway bars do help. They are easy to hook up before towing because usually you are heading straight when you hook up. It is best to disconnect them before backing up with any tight turns, like into a camping spot. See how it feels towing and then make a decision as to whether or not your hitch is sufficient for future trips.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
05-26-2011, 08:45 PM
Holly Lake Ranch
To follow up
Brought Thumper home from storage on Saturday to put new tires on and thought i would give the sway bar a try. It's only a 44 mile round trip, and none at Interstate speeds, so perhaps not a fair test, but only downside i found was that it definately is noisier when making a turn at a street corner. When we went back to storage, I took it off before making my backing turns into the bay. Have a longer trip planned in June and will see how well it works out on the highway. have not experienced any sway in the interstate driving that i did without using the sway bar a couple of weeks ago, but i guess i would probably just be on the safe side. PO said he went to Canada and back without it and AS tracked perfectly. He didn't mention if he took any power tools across the border....
05-26-2011, 08:57 PM
Chatham
, Ontario
Naughty, naughty!
05-26-2011, 09:00 PM
Holly Lake Ranch
Just testing reading comprehension . . .
Just thought I would see if anyone was reading ALL the threads today... hard to slip anything by UKToad
05-26-2011, 11:06 PM
1972 23' Safari
Houston
I had (still have) a husky hitch with the equalizer bars. Because the bars push up from the bottom and lock in place, I got tired of them falling out and dragging by the chains down the highway. I replaced the locking clips on one and it still was prone to come loose. Not sure what to do with it besides sell for scrap.
05-28-2011, 09:41 AM
Holly Lake Ranch
Rich
so far haven't had that problem.... but if you are going to sell them for scrap, drop those two little rectangular clips that slide through the chain holder when in the up position in the mail to me. I keep worrying im gonna lose those and havent found a suitable replacement.
05-28-2011, 07:23 PM
Catawissa
, Pennsylvania
Thanks to all for anti-sway help, esp. Cloudsplitter.
And thanks for the photo, too. Really helped. Barbann
