Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 08-11-2017, 08:06 PM   #1
1978 31' Sovereign
Brooklyn , New York
How to operate electric tongue jack without juice?
Had a 78 sovereign dropped off on my property and I'm trying to figure out how to move it. It's currently sitting on the tongue jack, but on inspection of tongue jack, it looks pretty messed up, the wire is frayed, and also there is no battery at the moment. Is there a way to hand crank it?
estock is offline   Reply With Quote
Old 08-13-2017, 01:03 PM   #2
2017 23' Flying Cloud
Bartlett , Tennessee
Should be. You will have to find the crank and find a crank handle to fit.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 08-18-2017, 02:26 PM   #3
1978 31' Sovereign
Brooklyn , New York
Yeah, but where do you crank it? i can't actually see a bolt or anything
Old 08-18-2017, 02:41 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
Use a battery charger, or some other 12 volt source, and hook it directly to the jack. Remember that trailer tongue provides the ground. Hopefully, the motor is still good.
John
Trnpk Crsr is offline   Reply With Quote
Old 08-18-2017, 03:25 PM   #5
Sag Harbor , New York
Do you have the owner's manual? I will find one online and post a link. There should be some info on operating the tongue jack manually.
Does this one look right?
https://www.airstream.com/wp-content...-0003.085c.pdf
Sorry but I don't see any info you need. What brand and model is the tongue jack, if you can tell. There should be some way to remove the cover, and have access to the end of the jack's drive shaft, the top of which should be square or hex-headed, permitting a socket set or box wrench to turn the shaft.
Good luck,
Peter
PS -- You can always use a standard hydraulic bottle jack to raise the tongue, to get the tow hitch's ball under the tongue's ball receiver. Hopefully the jack foot pad will be off the ground. If not, you could remove the entire jack assembly if that helps.
Old 08-18-2017, 03:28 PM   #6
2007 22' International CCD
Typically there is an opening under a cover on the top or side. Inside is a socket into which the crank can go. This assumes the crank did not go astray....
Old 09-29-2017, 11:14 AM   #7
1978 31' Sovereign
Brooklyn , New York
just for the record, there are two allen keys that allowed my to take the motor off, once it was exposed I was able to use a wrench and a large skrew driver.
Help! Jack won't operate on 2014 International 2KME Jacks, Stabilizers, Lifting and Leveling 15 03-10-2016 06:27 PM
Hitch jack will not operate Idea Jacks, Stabilizers, Lifting and Leveling 9 09-09-2015 06:56 AM
Can you operate the vent without the fan running Maggiefoss Roof Vents, Skylights & Fans 3 08-26-2013 09:15 PM
No juice for the electric jack Chuck Jacks, Stabilizers, Lifting and Leveling 7 12-05-2011 05:17 AM
No juice to the A/C dmadam Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 08:01 PM
