Old 07-27-2009, 07:47 AM   #15
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
That's the very same model I use.
So Long!
Bob Thompson is offline   Reply With Quote
Old 07-27-2009, 09:11 AM   #16
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Originally Posted by caadoptees View Post
I finally got around to taking some pictures of what I do. Remember that nothing will deter the person that REALLY wants the trailer but I want to slow them down as much as possible. Here is the sequence.
I remove the hitch from the receiver. Put the ball in the trailer tongue and latch it. I think bring the chains from my equalizing bars up to the latch and put a padlock through them all. My father put some tangs to hang the bars on so the ends are near the front during storage. I then take my receiver lock and put it through the hitch and lock it.
The thief cannot simply hook up the the tongue. They cannot put the hitch in their receiver either.
Makes me feel better.
I hadn't thought about the chains, great idea to incorporate them into the whole locked-up spaghetti-tangle. I also take the handle off my manual jack, making it just that much harder for someone to raise or lower the front end. I also love the idea of the FEMA sticker in the window!
tphan is offline   Reply With Quote
Old 08-02-2009, 02:51 PM   #17
Sandpoint , Idaho
Lock Brand
Robertsunrus: Did I miss it, or did you not mention the name/brand of hitch lock you prefer?
(Every time I follow-up on one and read the reviews, there's usually someone claiming it wasn't of much help, or gave false sense of security, etc. They liked it right up until their AS was stolen.)
kathy@bocinc is offline   Reply With Quote
Old 08-02-2009, 04:19 PM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
FREE SHIPPING — Milwaukee Cordless Sawzall Reciprocating Saw Kit — 28 Volt, Model# 0719-22 | Reciprocating Saws | Northern Tool + Equipment
FREE SHIPPING — Northern Industrial Cordless Angle Grinder — 18 Volt, 4 1/2in. Wheel | Grinders + Stands | Northern Tool + Equipment
Need to turn a 5" job of theft into a 20" job of theft. Lights, camera, . . . .
Old 08-02-2009, 04:25 PM   #19
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
We have our first electric hitch. What do you do to keep a kid from messing with the switch?
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 08-02-2009, 04:32 PM   #20
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Add a remote for your use, then use negative therapy to electrify the switch to touch so non-intended users are conditioned not to use.
Action
Old 08-02-2009, 10:14 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my coupler lock is a "Guardian G-37." [for 2 5/16" rolled lip coupler]
Hi, remove the fuse; Or if it's your kid..........
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-03-2009, 05:30 AM   #22
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
We use a tongue lock too, but we also use a kryptonite cable lock between two of the wheels. These kryptonite locks are some of the strongest. It woudl be difficult to cut through this thing.
https://www.kryptonitelock.com/produ...=1001&pid=1179
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 08-03-2009, 07:08 AM   #23
Images: 59
If you can, wire the breakaway switch and electic jack through a heavy duty switch inside the trailer. I use a keyed ignition switch from the local auto parts store.
It also prevents the kid from activating your brakes if he pulls the lanyard on your breakaway switch.
Old 08-03-2009, 07:52 AM   #24
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Ok I hope I don't ruin your day but I can walk up to that setup and hit the top of the latch with a hammer and your stinger will drop right out. the latch is designed to give way under excessive force. Mine let go when the ball pulled out during my first accident.
I use a tongue lock from Master lock.
Michelle TAC MT-0
Sarah, Snowball
Old 08-03-2009, 08:04 AM   #25
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
RE Tongue locks - be sure you get the one robertsunrus has - the first one you see at the store is likely made for tongues with flat flanges. Once you get it home, you'll see it won't fit .
But I had a friend who could use it...
Pat
pmclemore is offline   Reply With Quote
Old 09-12-2009, 12:18 AM   #26
Airstreaming since 1966
1989 34' Excella
Olympia , Washington
I used to have a small trailer parked on the gravel parking area in front of my house.
I dug a hole about 3 feet deep poured about 3 bags of concrete into it with a big chain leading to the surface, I would park the trailer over the chain, then lock it around the axle, maybe they could figure out a way to hook up to the front of the trailer, ( it was protected) but they would not be able to get away.
Air-13800 is offline   Reply With Quote
Old 09-12-2009, 10:28 AM   #27
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
It's a shame that the best you can hope for is to make it as difficult as possible for a bandit.
I use a coupler lock, one wheel lock, and she sits behind closed gates.
Al
Alwhisman is offline   Reply With Quote
Old 09-12-2009, 10:38 AM   #28
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Originally Posted by hampstead38 View Post
A hitch lock deters thieves from dropping your trailer onto a ball... but it is still possible to steal a trailer just using chains. To keep the trailer from moving, I believe there are chock locks. A variation of the chock lock is the tire boot. A variation of this is a J lock. I guess it depends on how secure you want your Airstream to be. Any mechanical lock can be defeated... the value is making it hard for thieves. If you have a restored trailer worth tens of thousands of dollars, you may want to consider going whole hog and putting in a Lo Jack. I'm sure the system could be modified for RV use.
A few years back we were traveling in England (NO, not with our trailer...the bridge isn't open yet) and were amazed at all the travel trailers (caravans they call them) with 'boots' on their wheels. My cousin in Cornwall had one on theirs and it was parked in their fenced yard!
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
how does this lock go together? BGS Doors & Locks 0 05-01-2008 02:42 PM
Stay hitched or unhitch? starflyte1 Hitches, Couplers & Balls 17 12-11-2006 08:11 PM
Help with lock please? centennialman Doors & Locks 10 07-06-2006 05:45 AM
Does anyone use this lock? azflycaster Buyer Guidelines 12 11-24-2005 09:20 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
