Old 04-16-2011, 08:22 AM   #15
1999 34' Excella
Troy , Texas
I just purchased the airsafe hitch...I have a 34' classic...had been experiencing the loping effect...truck and trailer...my equalizer hitch connects to the airsafe...and I must say...I have been airstreaming for 7 years...putting up with the loping...the ride is extrodinary smooth now...
excella99 is offline   Reply With Quote
Old 06-04-2011, 08:49 PM   #16
1999 34' Excella
Troy , Texas
I used the class VII Airsafe...because it was the only class with the 2 1/2 inch shank...most of the 2011 have the 2 1/2 receiver..didn't want to use the sleeve that comes with the truck....I know its overkill....but, I just put 40lbs of air in ...it works great....
Old 06-05-2011, 06:46 AM   #17
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I also run with an Airsafe Class V with the Reese Dual Cam setup. I've found 35psi in the unloaded airbag to be right for my setup. It dramatically reduced the jolting bounce on concrete highways. I can barely feel the trailer axles when they cross a big joint or RR tracks.
It moved the ball mount about 6" aft compared to the standard draw bar and as others have reported, did not add any sway. The added clearance from the bumper also allows for a slightly tighter turn when maneuvering without risk of contact.
My only concern was if I would have to lengthen the chains or umbilical and in my case, I did not have to. Another + was that when unhitched, the ball mount raises about 2" reducing the chance for dragging it on some driveway aprons.
I wore out an older model after 15 years of use. It used big roller bearings running in a vertical track. The tension of the spring bars really stressed this design. The current design of the Airsafe eliminated that problem.
Yes, it isn't cheap, but it may pay for itself over time in by reducing the wear and tear on the Airstream alone.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Shock, absorbing question? markdoane Shocks 4 11-18-2003 07:52 AM
Hitch Rating DaveJ Airstream Motorhome Forums 4 09-18-2003 07:29 PM
Interesting Reese hitch experience... 85MH325 Hitches, Couplers & Balls 25 07-30-2003 05:00 AM
Need HITCH help on a 59 59toaster Hitches, Couplers & Balls 3 02-14-2003 10:13 PM
Equal-i-zer Hitch dmac Hitches, Couplers & Balls 6 01-23-2003 07:14 AM
