Old 03-01-2015, 07:53 AM   #1
Sioux Falls , South Dakota
How much weight?
I've been working with the idea that the truck needs to take the tongue weight, which is usually 10-15% of the trailer's weight. Just now a thought came through the fog, and I wondered if I'm miscalculating. Doesn't an equalizing (weight distributing) hitch send part of the tongue weight back to the trailer? Somewhere I thought I read that it puts 1/3 of the tongue weight on the front axle, 1/3 on the rear axle, and 1/3 back to the trailer's axles. True? I also seem to remember an Oldsmobile advertisement that featured a Toronado hooked up to an Airstream with an equalizing hitch and the rear tires of the car removed to show the front wheel drive. That must have been "interesting" to drive.
Back to my original question. If I have a coach with a GW of 10,000 pounds, I could have a hitch weight of 1500 pounds. If my numbers above are correct, that means that the truck will get 1000 pounds (plus the weight of the hitch?) and the trailer will get back 500 pounds.
What am I missing?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-01-2015, 08:01 AM   #2
dznf0g's Avatar
Oswego , Illinois
The 10% to 15% is a measurement of dead weight. The mass balance doesn't change by adding WD. Your calculation of TW should be prior to WD and you'll be fine.
-Rich-
Old 03-01-2015, 08:17 AM   #3
Thanks, Rich. Guess I was starting to overthink things.
TAC SD-6
AIR 54240
Old 03-01-2015, 08:30 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
You are right in the sense that tongue weight is payload weight on the tow vehicle. WD moves it around the truck, ie depending on bars etc to the front axle and not all on the rear axle.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-03-2015, 09:05 PM   #5
Livingston , Texas
It is correct that a WDH will transfer load to the TT's axles.
However, the 1/3, 1/3, 1/3 "ideal distribution" is a towing myth.
A properly-sized and properly-adjusted WDH is more likely to cause a load equal to about 25% of tongue weight to be transferred to the TT's axles.
A fairly typical distribution of tongue weight is around: zero % added to TV front axle, 75 % added to TV rear axle, and 25% added to TT axle(s).
This is a typical result of adjusting the WDH to restore the TV's front axle to its unhitched load.
Ron
Ron Gratz is offline   Reply With Quote
how much wind is too much Barry Parkof Awnings 15 04-04-2009 12:19 PM
How much is too much, or too little - 1962 Globetrotter? gduffydc 1960 - 1964 Globetrotter 3 01-07-2009 02:39 PM
How much damage is too much? kaulike Ribs, Skins & Rivets 8 01-20-2007 01:10 AM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
How much is to much garry Our Community 13 07-08-2003 03:53 PM
