10-28-2009, 08:54 PM
2012 25' Flying Cloud
Battle Lake
How might an Air Safe Hitch reduce sway?
The Air Safe hitch site claims it can reduce or eliminate sway. It also claims to greatly reduce shock transfer between t.v. and trailer, reducing structural damage to both, and drive train damage to the T.V. If this is true I am reaching for my wallet, but is it?
I believe the reduction in shock transfer is true, but is that in itself a benefit to my relatively light truck and trailer combo? Maybe not, but also reduction in sway? How can this be?
To their credit, I see that the weight distribution/sway control assembly is mounted to the rear of the pivot at the air bag. That would seem to keep constant and relatively even tension on the w.d./sway control bars of my Equal-I-Zer hitch, so when driving over uneven road surface, the sway control would remain constant. Without the Air Safe, the sway control would vary significantly as tension (and therefore friction) on the bars increases and decreases with the pivoting at the hitch ball.
If the decrease in sway control (a bump in the road) happens at the moment a large truck passes, a loss of control may be initiated. Could this be the basis for their claim?
10-28-2009, 09:12 PM
_
covered in detail in other threads, here are 2...
http://www.airforums.com/forums/f464...hes-44641.html
http://www.airforums.com/forums/f464...tch-36522.html
friction sway control via cams or brackets on the w/d bar ends, is the same regardless of air bagged or not...
and there are several threads on how sway control works or doesn't work.
cheers
2air'
10-29-2009, 06:34 AM
Common Sense
Manufacturers and marketing people "claim" a lot of things for their products, but the fact is, the air suspension hitches will improve the ride, and that is all.
And, if you figure the hitch ball is about a foot farther from the tow vehicle in the case of a conventional hitch trailer, and figuring no other sway reducing equipment, the sway in theory, will increase.
10-29-2009, 07:00 AM
Battle Lake
Well Steve, that's kind of what I have been thinking too. The anti-sway aspect of this hitch has not been fully discussed here. It appears they are a good product being marketed by other than the manufacturer, who greatly exaggerates the benefits.
10-29-2009, 07:12 AM
1993 34' Excella
Estancia
I'm not sure what theory this is based on. In practice at best I find less sway and at worst about the same. It seems to me the extra foot the ball is set back ( I think it is a few inches less) amounts to the same as moving the trailer axles farther away from the tow vehicle axle. When you increase this distance I always thought sway decreases. Could be wrong.
It is a moot point though because mentioned above you can and should use a sway control device with a Air Ride or Air Safe hitch which I can with my Air Safe class 5.
10-29-2009, 07:23 AM
1979 30' Argosy
Havelock
, where we park it
Hello ... We have the Air Safe hitch and love it for the softened ride with the trailer. Still use Reese Dual Cam... it is needed...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
10-29-2009, 09:17 AM
Port Orchard
Originally Posted by Lumatic
I'm not sure what theory this is based on. In practice at best I find less sway and at worst about the same. It seems to me the extra foot the ball is set back ( I think it is a few inches less) amounts to the same as moving the trailer axles farther away from the tow vehicle axle. When you increase this distance I always thought sway decreases. Could be wrong............................................. ....
Hi,
To me, it does not seem to be the same, because you are moving the trailer back with the axles. Where the hitch attaches to the ball is the end of the lever that the trailer has available to apply sideways force to the rear of the truck. If you move this point further back, the lever is longer and more sideways force is exerted on the truck by trailer initiated left right movement.
Regards,
Ken
10-29-2009, 09:39 AM
Common Sense
Originally Posted by w7ts
Hi,
Regards,
Ken
Bingo!
10-29-2009, 07:40 PM
2005 16' International CCD
Ogden
, Utah
I always get confused by the term 'sway' - never sure whether it means pitch, roll, yaw, or all of the above.
I use an Air Safe with an Equal I Zer brand hitch and it works really well. I got the Air Safe mostly to help isolate my small 16' CCD from my 2500 Dodge Cummins - to avoid problems that folks report with stress damage, popped rivets, etc (tho' I never noticed problems like that before I had the Air Safe either - so it's a preventative measure).
So for sway - if it means pitch I think the Air Safe provides some 'extra' degrees of freedom with the air bag, so things feel more steady, but pitch is still controlled by the hitch. Yaw is controlled by the Equal I Zer, same as if I didn't have the Air Safe. Seems like roll movement is also dampened by the hitch, but it doesn't seem to me like the hitch ball provides much in the way of roll control - like the plate on a 5th wheel hitch might provide.
I don't believe the Air Safe 'removes' the need for your favorite brand of weight-distributing hitch, with whatever 'sway' control it provides
Anyway, things tow smooth and steady with my set up and I've never experienced (knock on wood) any of the 'sway' or rough ride problems that people sometimes report.
Ogden, Utah
2005 16' CCD
2005 Dodge Ram 2500 Quad Cab 4WD
10-29-2009, 07:46 PM
Port Orchard
It means that the trailer is wagging like the tail on a dog. If it gets wagging hard enough, it wags the dog, and the next thing you know the tail is in front of the dog, until they both go off the dog path (road).
regards,
Ken
10-29-2009, 08:07 PM
Ogden
, Utah
regards,
Ken
So if sway means the back n forth you describe, I don't think my Air Safe makes any difference in that movement.
I've read other places where sway means 'pitch' as well - the rocking motion as the front of the trailer tongue moves up and down, causing the back of the truck to do the same. For this movement I think the Air Safe provides a buffer (the air bag) before I 'feel' that movement in the truck - but I don't think the Air Safe does anything to lessen that movement.
Tho' it doesn't get mentioned much, the other movement to control is the roll, or side to side (perhaps called 'rocking'?). I don't think the Air Safe does much for this either - I think the spring bars on the Equal I Zer help control roll.
Bottom line for me - I think the Air Safe is more for a smooth ride (and saving my rivets.....) than for sway control - my Equal I Zer really provides the sway control, not the Air Safe.
I got the feeling at the Air Safe site that they are suggesting their 'hitch' removes the need for a proper weight distributing hitch - even with my big truck and small trailer I think a hitch (like my Equal I Zer) makes a huge difference. I haven't tried towing with just the Air Safe and a plain hitch ball - that would be an interesting test!
Ogden, Utah
2005 16' CCD
10-29-2009, 08:31 PM
Battle Lake
Sway is scary. Very hard to stop, once it starts. I experienced plenty of it trailering lumber home to build our house.
I have been wondering if the Air Safe prevents sway by allowing constant and consistent tension on the sway control/w.d. bars as you move over uneven road surface, as opposed to the same sway control/w.d. setup without the Air Safe, which seems to vary tension as the hitch point moves up and down over bumps. Hard to describe.
Say Bob, we have an Equal-I-Zer as well. Did yours bolt right up to the Air Safe with their optional bracket?
10-29-2009, 09:30 PM
Ogden
, Utah
Yes - fits great! I upgraded the trailer wheels & tire to 15"-ers at the same time - that together with where the hole line up on the optional bracket meant I had to readjust the Equal I Zer - and I had to play around with how much air to put in the bag since that also changes the height. Wasn't a problem - but took several iterations before I got all the variables just right.
Ogden, Utah
2005 16' CCD
10-31-2009, 02:24 PM
Battle Lake
Thanks Bob, I think I'm going for the Air Safe for our Safari 20, and here's why.
1) Less damage to trailer from stiff connection, and easier on drive train of truck. They are almost isolated from each others shock on rough roadway. Virtually all users support this as its best feature.
2) Better operation of weight distribution/sway control hitch when vehicles are moving. There is very little up and down movement at the ball connection allowing the bars to keep more constant, even pressure. That means better sway control and more even weight distribution over rough roads (therefore avoiding low to high w.d. stresses on trailer and truck). I have nothing to back this theory up. (Am also aware of the hitch ball mounted further back amplifying sway idea, but no user has claimed this a problem.)
3) There are better options for sway control with HaHa and PP hitches. No doubt. But the shock protection is not there, and shock could be worse because the added weight requires higher tension on the w.d. bars. (If I had a much larger trailer, I would choose a HaHa/PP for safety reasons, select or modify the truck suspension for a gentler ride, and select w.d bars only large enough to do the job.) Nothing to back this up either.
Hoping for discussion, with flack jacket on, just in case.
Doug
10-31-2009, 04:21 PM
Simple answer: They work....get one, you will love it. If not you can return it.
12-06-2009, 08:18 AM
2005 28' International CCD
Camarillo
We use the AirSafe with an Equalizer, both class 5. towing a 30' s/o. The AirSafe has no effect on sway, but dramatically makes the ride smoother.
12-07-2009, 03:44 AM
Vintage Kin
Fort Worth
Of all these posts/threads it would be instructive to see scale weights: that the Steer Axle is being loaded by the WDH properly when the truck is equipped with this device.
I have not found any recommendation of ever increasing the Drive Axle/Ball Center distance to be a good thing; quite the reverse. No one recommends buying a TV with a long rear overhang.
So if this compromise is a good one, where are the scale ticket numbers with and without this device attached? Hopefully it has no effect, but . . . ?
The company video shows cranking the WD bars THEN adjusting the air bag pressure to cause the rods to be parallel; backwards, also, from advice here and elsewhere about dealing with air ride rear suspensions.
The MorRyde rear spring shackle replacement is the same in price or cheaper, and doesn't adversely affect hitch rigging geometry; I can hardly see wanting a compromised alternative (however much I want a softer ride).
