Old 10-31-2009, 04:21 PM   #15
Tinsel Loaf's Avatar
Simple answer: They work....get one, you will love it. If not you can return it.
Tinsel Loaf is offline   Reply With Quote
Old 12-06-2009, 08:18 AM   #16
2005 28' International CCD
Camarillo , California
We use the AirSafe with an Equalizer, both class 5. towing a 30' s/o. The AirSafe has no effect on sway, but dramatically makes the ride smoother.
loft47 is offline   Reply With Quote
Old 12-07-2009, 03:44 AM   #17
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Of all these posts/threads it would be instructive to see scale weights: that the Steer Axle is being loaded by the WDH properly when the truck is equipped with this device.
I have not found any recommendation of ever increasing the Drive Axle/Ball Center distance to be a good thing; quite the reverse. No one recommends buying a TV with a long rear overhang.
So if this compromise is a good one, where are the scale ticket numbers with and without this device attached? Hopefully it has no effect, but . . . ?
The company video shows cranking the WD bars THEN adjusting the air bag pressure to cause the rods to be parallel; backwards, also, from advice here and elsewhere about dealing with air ride rear suspensions.
The MorRyde rear spring shackle replacement is the same in price or cheaper, and doesn't adversely affect hitch rigging geometry; I can hardly see wanting a compromised alternative (however much I want a softer ride).
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Hitch/Sway For Tradewind, OK? 72BamaStream Hitches, Couplers & Balls 3 05-12-2009 08:53 PM
Air Safe Hitches loft47 Hitches, Couplers & Balls 4 04-22-2009 03:50 PM
Air Safe Hitch - Thoughts & Questions RDM16CCD Hitches, Couplers & Balls 13 04-11-2009 08:08 AM
Hitch height question, is my setup safe? damonbeals Hitches, Couplers & Balls 13 04-16-2008 11:06 AM
