Old 07-26-2015, 04:06 PM   #1
Las Vegas , Nevada
How important is proper torque on hitch install?
We are in the process of switching out our tow vehicle for our 19' international from a Nissan Xterra (great off road, not so great for towing) to a 2015 F150. I had to adjust our equalizer WD hitch yesterday as the receiver on the truck is about 6" lower than on the Xterra. I was able to get the shank bolts out with the help of an impact wrench, but do not have a torque wrench capable of the manufacturer recommended 320 foot-lbs. So, I used the impact wrench to tighten the shank bolts, which is likely more than the recommended torque setting (although I cannot confirm this). Would you consider this acceptable or should I invest in a 3/4" torque wrench or find a place to make this adjustment for me? I want to make sure we are being safe on the road. Thanks.
canyonduck is offline   Reply With Quote
Old 07-26-2015, 04:32 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have several different lengths of stainless tubing that I use as cheaters. The appropriate length easily slips over the ratchet or torque wrench handle.
MICHAEL
Old 07-26-2015, 04:42 PM   #3
1978 Argosy 24
MooreHaven , Florida
Just drive to any truck shop,im sure for a small fee they will torque those nuts for you. Wont cost much and you will feel better knowing they are done right.A 3/4 drive torque wrench is a big long heavy thing and not needed often enough in my opinion to own one
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 08-29-2015, 05:13 PM   #4
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
The proper torque is VERY important. "If the tension on the bolt is greater than the working load, it will never fail. If the tension is less than the preload, it will fail as a 'fatigue break."
If your torque wrench doesn't have the capacity to go as far as specified, then coat the threads and the nut face with C-5 Colloidal copper or similar and reduce your torque by 40%, to achieve the same bolt tension. (Only 10% of your torque is actually used to tighten the fastener, the rest is to overcome friction.)
[Source: Premier Fastener Corp. former agent.]
MelGoddard is offline   Reply With Quote
Old 09-02-2015, 08:33 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
250lb torque wrenches are pretty reasonably priced but past that the cost is prohibitive. I use my 250lb torque wrench on the bolts up to 250lbs. Then I use a breaker bar with a hollow floor jack handle slipped over it down to the socket head. I push down the breaker bar from 2 o'clock to 4'oclock slowly in two passes to get the extra 80lbs. I'm guessing I'm close enough.
Kelvin
Proper torque for lug nuts. ole-red Off Topic Forum 9 05-31-2014 08:58 AM
Important - Proper tire pressure & tires for Argosy Minuet 6.7 ArgosyMinuet All Argosy Trailers 19 05-05-2013 09:20 AM
What's the proper hitch for me? Murphuga Hitches, Couplers & Balls 13 10-08-2010 03:27 PM
proper hitch, bars hook-up procedure az-streamer Hitches, Couplers & Balls 7 08-19-2009 04:45 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
