Old 08-04-2013, 03:52 PM   #43
steverino's Avatar
2018 30' Classic
Ivins , Utah
Originally Posted by dkrug View Post
We eyeball it, then go in and open the bathroom door. If it doesn't swing. it is level.
+1
I use this technique, but might switch to the beer method as well.
steverino is offline   Reply With Quote
Old 08-04-2013, 04:04 PM   #44
mgriffrus's Avatar
1974 29' Ambassador
Ruston , Louisiana
So I use a four foot level on the floor for side to side, if the bubble touches one side, it's one Lego. If its halfway out or more, it's two Legos. I haven't been more than two Legos yet. I then take the level outside and set it on the trim and use the fourteen year old (electric jack went kaput years ago) to crank the level for front to back while I read the bubble for him.
Then the beer.
mgriffrus is offline   Reply With Quote
Old 08-04-2013, 04:29 PM   #45
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by steverino View Post
+1
Drink beer till "level"... Got it!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-04-2013, 05:47 PM   #46
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
That's probably the most sensible method suggested so far. Sooner or later you are bound to reach the point where your tilt matches that of the trailer. That's the goal, I believe.
if you don't drink, you could always put newspaper in one shoe, and keep adding more until you lean the proper amount. However if you use that method, remember not to turn around. If you do you will undoubtedly tip over.
Ken
Old 08-15-2013, 07:26 AM   #47
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Leveling
Originally Posted by NJtoNC View Post
Psshht. I put a can Of baked beans on the floor. If it rolls fast, we got a problem. If it rolls slow, then hey, we didn't do so bad. If it doesn't move then its beer time!
I just thought of something...
Skip the beans and use the beer! Saves steps!
Of all the suggestions I've read on leveling, this makes the most sense to me!
You and I are thinking on exactly the same lines.......people need to have their priorities in the proper perspective!
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
