Old 02-04-2018, 09:34 PM   #1
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
How Do Airstreams Perform on The Road
In this video you will see Airstream Travel Trailers on test tracks to show you how they perform on the road in comparison to their competitors.
waninae39 is offline   Reply With Quote
Old 02-05-2018, 06:13 AM   #2
Schoharie , Unknown
That is a very good video and a great selling point. However, usually the weakest link is the driver. Many people comment on how their TV tows their trailer "like it wasn't even there", well it is. It seems like you see more and more RVs in the fast lane hammering down. I have seen a few RV crashes, but only one was an AS. The driver had defective TV brakes and one locked up, throwing him across three lanes of traffic into the meridian, somehow without getting hit by anyone else. The TV rolled, the AS stayed upright, the driver was ok, his comment was, "I was going to get them checked, but didn't get to it". He also didn't have his WD or anti-sway equipment attached as he said, "It was only going to be a short trip", ended up shorter than he thought. The 1970ish AS appeared to have performed well and held together. Travel safe!!
EZTOO is offline   Reply With Quote
Old 02-05-2018, 07:15 AM   #3
1981 31' Excella II
New Market , Alabama
They handle better than any other travel trailer out there. You do need working brakes and sway control. The low center of gravity has a lot to do with handling as well as aerodynamics. They are also lighter than most trailers of the same size. They are also better in a cross wind since they are also more aerodynamic in that situation as well. Cross winds that will roll a square box trailer (SOB) won't bother an Airstream. Mine was sitting in the yard and got hit by a tornado. The front in shifted about 6 inches and one of the awnings was ripped off. Other SOB trailers nearby were rolled and destroyed. It took out most of the large trees in the yard but the Airstream held fast.
Perry
Old 02-06-2018, 10:22 PM   #4
The box trailer in the video also didnít have torsion axles and a low center of gravity compared to the airstream
0557 is offline   Reply With Quote
Old 02-07-2018, 06:03 AM   #5
Lakes Region , New Hampshire
Nothing like a well produced promotional video, to show what they want you to see. They behave as well as anything else when driven properly within their design parameters.
For example, gym tires vs. LT, I don't drive my Fiat 500 the same as my F350. Most who buy a $30,000 box trailer aren't going to invest in a $3000 sway control hitch, but when you spend $100,000...
RandyNH is offline   Reply With Quote
Old 02-07-2018, 06:18 AM   #6
1981 31' Excella II
Most SOB owners don't have load distribution or sway control. I have never seen either one on a boat trailer.
Perry
Old 02-07-2018, 07:45 AM   #7
Gainesville , Florida
Unfortunately most drivers cannot do either of those things shown on the film without getting in an accident. It does show how a properky set up tow rig with a good trailer handles. Most drivers would fail this test. Overcorrecting and improper braking would do most in.
Old 02-22-2018, 07:33 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Perry
Does a boat present the same profile to a crosswind as a TT?
Plus they run a TW of 5-7% by adjusting the bunks.
You havenít seen one because you donít live in an area with big trailerable fishing boats. Where WD is indeed used.
And the arguments have to do with WD hitches compatible with surge brakes.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 02-22-2018, 07:38 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Because they canít be bothered to ask. Or learn.
Because like all the lousy AS rigs I see ó the vast majority ó they fail to do any homework worth turning in. Vehicle spec, hitch rigging, highway conduct, etc. Itís an embarrassment.
Not that it canít be taught or sufficient skill acquired. Some start with better visuospatial skills (monkey skills), but none are exempt from learning procedures.
Old 02-22-2018, 07:43 PM   #10
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just though I'd say what others are thinking........None of these accidents would have taken place if they had been towing with a 3/4 or 1 ton diesel pick up..........
Rubber side down people.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 02-22-2018, 07:48 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
An AS is better than the conventional trailers, and ó where all else is a constant ó were better than the vintage kin competitors.
Itís the only place thatís true, but Wally & crew really got this part right.
A changeover by the others to torsion axle where the wheel face is at or barely outside the exterior walls would be the needed change.
Aero matters most: the family vehicle best suited to that job that can also pull one of these trailers.
Thatís the recipe for success.
The better the TV, the better the road performance.
A TV incapable of the same slalom speed as the trailer is itself unacceptable. Luckily, not many designs are that bad.
Which makes it flat funny the worst is the default RVer choice.
ďYes, sir, weíre backpacking our way into the Rockies for elk hunting trip. How ya like my new sandals? Bought Ďem special for the trip inĒ.
Old 02-23-2018, 05:34 AM   #12
2012 19' International
Southeastern MI , Michigan
Cheers
Sidekick Tony
The big pickups wreck pretty often too, regardless of fuel too.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 02-23-2018, 05:42 AM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Does that AS with bikes on the back have a rear hitch for the bikes?
SteveSueMac is online now   Reply With Quote
Old 02-23-2018, 06:27 AM   #14
2007 22' International CCD
Airstreams perform just fine on the road, if theyíre properly rigged and driven conservatively. Hitch choice and driving habits are the biggest factors. Human error will always lead to accidents...
Drive carefully, no matter what the setup.
KE4GNK/AE
New Airstreams vs old Airstreams Denis4x4 Forum Admin, News and Member Account Info 10 07-18-2013 06:49 AM
FROM AUTOCAMPS TO AIRSTREAMS: The Early Road to Vacationland alclad Airstream History 2 02-07-2010 05:29 PM
18 Airstreams seen on the road in Canada dufferin On The Road... 7 07-13-2007 02:37 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
Are YOU seeing Airstreams on the road? maxandgeorgia On The Road... 26 08-27-2004 10:01 AM
