Old 09-27-2015, 03:54 PM   #1
Manheim , Pennsylvania
Hitchgrip demo
Here is a short demo of the Hitchgrip. It does make handling weight distributing hitches some easier to handle.
Jukeboxfun is offline   Reply With Quote
Old 09-28-2015, 07:00 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I can usually grip my hitch pretty good....
It's my dirty ball cover that needs griping.... zip-ties forever!!!
....no it's not the AS stinger.....
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-28-2015, 07:24 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I just purchase a Hitchgrip a few weeks ago. Now that I have a 3/4T truck I went with the 2 1/2" Equalizer shank. I had to get the longest model 2 1/2" shank, 12" with 6" drop and put the head on the last set of bolt holes. When I got the Hitchgrip it almost didn't work. The handle, when attached to the ball, is right over the shank top with no space under it. I have to grap the Hitchgrip handle closer to the Equalizer head so its a little off balance. Its still a lot easier to move the hitchhead/shank around then without.
Kelvin
Old 09-28-2015, 07:30 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That would by my issue. I do not think it would safely fit my bar. Without being to grip the handle properly the leverage gained would be defeated.
MICHAEL
Old 09-28-2015, 07:57 AM   #5
KJRitchie's Avatar
2008 25' Classic
If they made it with another 1 1/2" height between the ball clamp and the handle it would allow me to get a gloved hand under the handle. Still, its a lot easier using it then not. I don't have to stoop low to pick up the head and then stoop down to insert it in the receiver. I still use my legs to help lift the head off the floor with the Hitchgrip. The 2 1/2" shank by itself is 30+lbs, with the head attached I'm sure its over 70lbs. Gotta watch my back. Had a laminectomy 15 years ago.
Kelvin
Old 09-29-2015, 09:54 AM   #6
AWCHIEF's Avatar
Images: 33
I contacted the company about using with extended drop bars and got this response back,
"Unfortunately, we do not yet offer a HitchGrip compatible with ball mounts using oversized shanks. If you are unable to use the product conformably due to clearance issues, I suggest you return for a refund. Our apologies for the inconvenience! If we had a fix, I would certainly send it to you, but at this time we simply do not have a product or kit that works with drop-hitches.
If you have any other questions or concerns please let us know."
MICHAEL
Old 09-29-2015, 10:48 AM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I use a piece of rope tied in a loop through one of the unused holes in the shank.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-29-2015, 10:51 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have a handle attached to the 'stinger'... adding the mudflaps adds a lot of weight..
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 10:53 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Well it sure won't work with a Hensley or ProPride will it?
And do the make different ones for smaller balls?
And a lot of people probably couldn't carry that much weight one handed anyway. When I traded my truck I left my do-it-yourself hitch lifter in the old one. I need to make a new one soon. It was just a piece of seat belt material with a BIG loop on one end and a small loop on the other. The big loop went over the whole trunnion and the small end was looped over the part that went into the Hensley. I then ducked under it and carried the trunnion like a paperboy with the old canvas bag. (should make a new one WITH a bag for the dirty rusty trunnion... or just mug the local paperboy!)
Paula
Old 09-29-2015, 02:07 PM   #10
Thumbs up
The hahaheavy stays put....
PFC
RLC
Old 09-29-2015, 03:08 PM   #11
AWCHIEF's Avatar
Images: 33
Like the cones, very stylish. I used to use an old fishing boot I found at the docks but someone walked off with it. I guess it must have been a one legged midget.
MICHAEL
Old 09-29-2015, 03:17 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It looks like the ball might slip out if the grip is tilted a bit- as it did when he put it on the ground in the video. Might get ugly if it did that while it was being carried. You also have to deal with a greasy hitch-grip.
2012 Dodge Durango Hemi/AWD
Old 09-29-2015, 03:29 PM   #13
Images: 59
I looked at these and had the same thought. I hope they have product liability insurance.
I found it easier to just drill and tap the top of the shank and add a square U-bolt with one end cut off.
Old 09-29-2015, 03:35 PM   #14
AWCHIEF's Avatar
Images: 33
I just put on a pair of gloves and pick it up using my legs to lift. My coupler is right at my max lifting limit.
MICHAEL
2008 34 Airstream Slide out DEALER DEMO at invoice eBay Watch Airstreams on eBay 0 03-10-2009 11:20 AM
2008 34 Airstream Slide out DEALER DEMO at invoice eBay Watch Airstreams on eBay 0 02-18-2009 11:00 AM
Zip Dee Awning Video Demo Colonial Airstream Commercial Listings 15 10-16-2008 06:24 AM
Floor Demo hhuber General Interior Topics 3 08-10-2003 11:06 AM
Airstream & NREL Demo gklott Our Community 2 08-05-2003 05:23 AM
