Old 06-30-2010, 08:50 PM   #1
jsamuel8's Avatar
2002 30' Classic S/O
Rapid City , South Dakota
Hitch Zerk Size
Does anyone know the zert size that attaches to the hitch? I have a 2002 Classic 30 s/o that has a zert to apply grease to the ball when attached. I put my grease gun on it the other day and when i went to remove it, it was stuck and when I yanked it with considerable force, it pulled off... The thread in the hitch seems okay but the zert is toast. Any help would be deeply appreciated.
jsamuel8 is offline   Reply With Quote
Old 06-30-2010, 09:12 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I doubt if it is original.
There are only three sizes of zerks in widespread use. There's the press-in, the 1/4"-28 threads, and the 1/8" tapered pipe thread. The 1/8" pipe thread ones are larger than the 1/4"-28 ones. If it pulled out, it's probably one of the press-in ones, and you'd be better off drilling out the hole and tapping it with a 1/4"-28 and then using a matching zerk.
Old 06-30-2010, 09:34 PM   #3
_
hi jsam'
jammers correct, no zerk is NORMAL on the a/s cup.
so some1 added this to your trailer.
given how infrequently and how easy greasen' the ball is...
no zerk is needed
also this doesn't make CLEANING the cup easier.
we've discussed this in other threads...
read 5 posts (#222-226) here...
http://www.airforums.com/forums/f464...tml#post373316
last post has a PHOTO with zerk added.
the problem is, NOW the cups gotta HOLE in it.
so either PLUG it or tap/thread correctly and add another zerk.
________
the lectric screw stab/jacks on your unit may have ZERKS for lubn (mine sure do)
so pick one the SAME SIZE and the grease gun tip does multi duty.
cheers
2air'
Old 07-01-2010, 09:57 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Uh, 2air, there's only one size for the end of the zerk that fits into the collet on the grease gun.
Old 07-01-2010, 10:09 AM   #5
_
right jammer...
so the tap/thread diameter, taper, shape, general size, orientation for the HOLE all vary...
but the nipples are basically all the same size?
cool!
Zerk Fittings / Grease Fittings
now if there was just a multiple tube hose octopus thing connected to all the zerks ...
that could run to ALL the fittings (jacks, ball, spring bars) with ONE common attachment...
i could grease ALL locations at the same time...
chees
2air'
Old 07-01-2010, 10:51 AM   #6
richinny's Avatar
2011 34' Classic
you've just invented OCTOLUBE!
Ricky
Old 07-01-2010, 10:55 AM   #7
_
too funny, u can be the marketing department!
cheers
2air'
Old 07-01-2010, 11:42 AM   #8
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
octolube existed in WWII
the German army had field cars that had a pedal inside the vehicle that lubed the chassis when pumped by foot. hmmm-I guess it was achtung! lube
bill
wmarsha is offline   Reply With Quote
Old 07-01-2010, 01:24 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
bill
If you wanted to go domestic, I understand that Duesenberg also allowed the driver to lube everything but the universal joints. Seems that even they couldn't figure a way to get to the spinning u-joints in the drive shaft.
Vaughan
vswingfield is online now   Reply With Quote
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
Right size WD hitch????????? purman Hitches, Couplers & Balls 4 10-24-2008 09:41 AM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
Ball hitch size schaumannk Hitches, Couplers & Balls 8 12-01-2004 07:31 AM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
