Closed Thread
Old 10-23-2011, 10:04 PM   #1
Hitch torsion bars
There is a new article just posted about "Hitch torsion bars".
It may help someone that has questions about the degree of bending the bars with a given load.
The Hitch Torsion Bar Story
Inland RV Center, In is offline
Old 10-24-2011, 05:54 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Thanks, Andy. I appreciate the work that went into this.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline
Old 10-24-2011, 06:16 AM   #3
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Thanks for your time and resources put into this research. Do you foresee similar test on Hensley bars ? Thanks you
F450Harley is offline
Old 10-24-2011, 06:44 AM   #4
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks Andy - always appreciate your input.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline
Old 10-25-2011, 09:12 AM   #5
SteveH's Avatar
Common Sense , Texas
Torsion
tor·sion
Show Spelled[tawr-shuhn] Show IPA
noun 1.the act of twisting.
2.the state of being twisted.
3.Mechanics. a.the twisting of a body by two equal and opposite torques.
b.the internal torque so produced.
A torsion bar suspension, also known as a torsion spring suspension or torsion beam suspension, is a general term for any vehicle suspension that uses a torsion bar as its main weight bearing spring. One end of a long metal bar is attached firmly to the vehicle chassis; the opposite end terminates in a lever, the torsion key, mounted perpendicular to the bar, that is attached to a suspension arm, a spindle, or the axle. Vertical motion of the wheel causes the bar to twist around its axis and is resisted by the bar's torsion resistance. The effective spring rate of the bar is determined by its length, cross section, shape and material.
I've been using weight distribution hitches since the '70's, and have recently been searching the net for hitches using torsion bars, as Andy has tested here, and to date, I have found none.
All that I have found use weight distribution bars that act as common leaf type springs, but no torsion bars.
Andy, would you please tell us what hitches you are testing that use torsion bars.
Regards,
Steve
SteveH is offline
Old 10-25-2011, 04:05 PM   #6
Kevin245's Avatar
<<Mod Mode>>
This thread is now closed. The OP's link is still in effect so let's cool the fires a bit. Please take whatever information you gain from the article and use it responsibly.
On behalf of the site team,
Eleanor Roosevelt
Kevin245 is offline
Closed Thread
1972 Airstream Ambassador 29 Ft. Rear Bath Model with Reece Hitch and Sway bars eBay Watch Airstreams on eBay 1 09-26-2011 08:59 AM
Hitch age? Skater Hitches, Couplers & Balls 18 09-03-2011 01:12 PM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
