Old 10-30-2002, 04:05 PM   #1
Hitch size
I just bought a 1971 27 foot airstream. It was just there and it seemed like a good deal and I liked it, so I said Yes. Now what size ball do I need too hitch it to so I can get it home?
Jim Sease is offline   Reply With Quote
Old 10-30-2002, 04:09 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
2 5/16
any one can jump im if i am wrong
john
Old 10-31-2002, 01:05 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
IMHO
You could be right John. I use a 2" on mine..Which is pretty much standard.
I'd also be sure it can handle the job as well..I don't know if I'm the only one doing this but, I put grease on mine as well before each trip. (just my 2 cents worth)
ciao
Andy sez:
From 1969 and up, all the Airstream trailers are equipped with a 2 and 5/16 inch ball.
Oops~! this is one that I should've checked..thanks Andy and, to the rest..I do have the 2 5/16.
Since I bought it 'used' and, it came with all the hardware.(my only excuse for this blunder)
Andy, have you ever thought about writing a book??
53flyingcloud is offline   Reply With Quote
Old 10-31-2002, 05:46 AM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
it would be nice to know when they switched from 2'' to 2 5/16''.
or were there years or sizes that overlapped?
how about the new bambi's what do they use?
any one? ..... Andy?
i also grease the ball before hitching up. i use the extra wheel bearing grease i have in the shop. as i always use grease from a sealed container when i do the wheel bearings so i always seem to have a couple of partial containers around.
the wheel bearing grease is thick enough it doesn't drip all over the hitch.
john
Old 10-31-2002, 06:17 AM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Mine has a 2 5/16 ball. It might be that certain lighter weight models have a 2. Not sure what the "rules" are for ball size.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-31-2002, 06:53 AM   #6
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
New trailers
According to my dealer, all new A/S trailers are 2 5/16" regardless of size and weight/
John W. Irwin
WBCCI #9632
Old 10-31-2002, 07:59 AM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Hitch size
I am not certain about when the switch from 2" to 2 5/16" hitch balls was implemented, but seem to remember reading that it was a change introduced with the new models in 1969. My '64 Overlander has the 2" hitch ball while my '78 Minuet 6.0 Metre has the 2 5/16" hitch ball.
The one thing that I have learned with the Overlander is that when it comes time to purchase a new hitch ball is that not all 2" hitch balls are created equal. It takes some searching to find a 2" hitch ball with a 6,000 pound or greater trailer weight rating.
Kevin
Kevin D. Allen
AIR #827
Old 10-31-2002, 08:25 AM   #8
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
1971 Overlander
I have the same trailer 1971 Overlander and it has 2 5/16" ball.
Smily
smily is offline   Reply With Quote
Old 10-31-2002, 08:46 AM   #9
1996 30' Excella
Brighton , Michigan
Hitch ball size comes from the V5 Gov't trailer tow standard. You have all seen the V5 stamped on the hitch balls and your hitch receiver on your truck should also say it meets the V5 standard.
This standard which was published in the late 60's and has been updated several times sets ball size by weight. 1 7/8 for trailers under 2000 lbs. - 2' for trailers under 5000 lbs. - and 2 5/16 for trailers over 5000 lbs. This standard also defines test requirements for hitches.
apple 1 is offline   Reply With Quote
Old 10-31-2002, 09:06 AM   #10
All Airstream trailers from 1968 and older used a 2 inch ball.
inlandrv.com
airstreamparts.com
Old 11-04-2002, 11:38 AM   #11
Thanks!!
Thanks every one for the info about the ball size question I had! I got my answer and I learned a lot too - Thanks again!!
Old 10-11-2010, 12:39 PM   #12
1969 21' Globetrotter
Seattle & Olympic Peninsula , Washington
I know this is an old thread but I was wondering our 69 GT uses a 2" ball. Maybe it was manufactured in '68?
Dave
EvelynDickinson is offline   Reply With Quote
Old 10-11-2010, 12:44 PM   #13
Dave
A 69 Airstream uses a 2 5/16 inch ball.
Old 10-12-2010, 08:46 AM   #14
Andy,
Thanks for your response but our 69 GT definitely takes a 2" ball. I gather from the other treads I've read since on the forums that 69 seems to have been a transition year for A/S in terms of ball size.
Regards,
Dave
How to choose a shock-absorbing Hitch ? femuse Hitches, Couplers & Balls 16 06-05-2011 07:46 AM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 05:56 PM
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches, Couplers & Balls 2 12-07-2003 12:04 PM
Hitch Rating DaveJ Airstream Motorhome Forums 4 09-18-2003 08:29 PM
Interesting Reese hitch experience... 85MH325 Hitches, Couplers & Balls 25 07-30-2003 06:00 AM
