Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-19-2009, 10:41 AM   #1
pinktrailer's Avatar
Profile:  1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Hitch recommendations please!!
For my 26' overlander (4000+lbs) I use a heavy duty weight distribution hitch with trunnian style spring bars. It is awesome, no sway no matter what. I've been pulling my "new" 1953 17 footer just with the ball and safety chains, but I definately get a bit of sway when I'm over 65mph.
I had been hoping to just adjust the height on my big hitch, and buy some lighter weight, shorter spring bars and hook up brackets. I can't find short, trunnian style bars, and this seems like over-kill for this just over 2000 lb trailer. I pull with a Yukon XL and I do not know the tongue weight of this trailer.
Any suggestions?
pinktrailer is offline   Reply With Quote
Old 10-19-2009, 10:55 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Any suggestions?
I would invest in a dedicated hitch for this little trailer.
This one comes to mind:
Equal-i-zer Hitch Store: 400 / 4,000 lb. Equal-i-zer Sway Control Hitch
It is a product specifically designed for lighter, sub 4000lb trailers. You can find a much better price on this than what is quoted on the site, btw.
Uwe
www.area63productions.com
Old 10-19-2009, 10:57 AM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
PM me your phone number and I will call you. I need more info and it is not easy to just swap back and forth the hitch between 2 trailer.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 10-20-2009, 12:18 PM   #4
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
I use one of these on a 17' Casita and it works really well.
Single Bar Weight Distribution Kit for A-Frame 3205 : Trailer hitch bike rack and trailer hitches - etrailer.com
It's cheap, easy to install, and it works great.
SteveH is online now   Reply With Quote
Old 10-20-2009, 06:02 PM   #5
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Hitch
I have the Reese Dual Cam Straight Line. Sway Control is incorporated into the design. It has worked well for me, just use the lightest trunion bars you can find with the adapters on the ends (550 lb).
Beginner
Beginner is offline   Reply With Quote
Memphis Recommendations jcanavera On The Road... 16 05-08-2007 09:23 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches 3 08-31-2006 12:48 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches 9 05-02-2006 01:35 PM
Hitch and brake controller recommendations for Excursion/28' Safari PWRSTRK Hitches 15 08-17-2004 09:45 PM
Speedometer recommendations wb13798 Mechanics Corner - Engines, Transmission & More... 15 01-01-2004 09:18 AM
