Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 12-28-2007, 08:28 PM
Devoman
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Panama City Beach, Florida
Hitch and receiver rattle
Well...I finally ready to fix the space in which the reciever into the hitch is just a tad to small and it rattles when driving or gives a thunk when I take off.What solutions have you all done to fix this.I have heard all kinds of things but they are all not a permanent solution.I have found 1 though but do you all think this could hold up over time with this much force.Thanks All.
The Hitch Corner sells Draw-Tite trailer hitch accessories
Get your Blue Air Numbers and Custom Signs (Purchase)
AIR# 8855
Streamers For Life
Get rid of these ads... register today, it's FREE
Old 12-28-2007, 08:41 PM
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
That's the first thought I had also when I saw this. How well will it hold up under weight distributing loads? I haven't ever seen one but it looks like an innovative fix. Not that xpensive to try out either.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Old 12-28-2007, 09:09 PM
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Lakewood, California
Status: Online
Hi, I don't have a hitch rattling problem, but what you have pictured, in my opinion, would only work if you drive around with the hitch in the receiver without your trailer attached. I don't think it would be strong enough to hold things in place with a real load on it. [trailer and WD hitch installed] I had thought of makeing and useing a thin metal wedge that you can tap in place either on the top or bottom of the receiver.
2005 Safari 25-B
"Le Petit Chateau Argente"
[ Small Silver Castle ]
Blue Stripes, American flag, Edition
2000 Navigator / Equal-i-zer / P-3
AIR #12144
Old 12-29-2007, 06:30 AM
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula, Montana
That does not look like it will work very well under any load. You hitch pin is likely worn or too small.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 12-29-2007, 06:57 AM
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road, Fulltiming
I have some slop in the receiver/head also. Part of it is the brand of receiver and head you use, some have closer tolerances. Part of it is wear, also. If you have lots of time to mess with it, you can make a nylon/teflon pad for the head to ride on, it should hold up pretty well.
The head moves in the receiver on ours as well, but the only time I hear a "clunk" is when I walk into it ...ouch.
Aluminitis never sleeps...
AIR#2611
Old 12-29-2007, 04:52 PM
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast, BC
Status: Online
I had one hitch head that had the same problem you had. I ran a small bead of weld on the bottom, one on each side of the bottom. Then test fit it and used the grinder judiciously until it slid in tightly but was still removable without hurting myself trying.
As Michelle has noted it could also be a too loose pin. I've found that going to the RV Parts store and trying their hitch pins until I found one that was just slightly tighter fit than mine stopped an annoying rattle on one hh.
Barry
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
1951 Flying Cloud 21'
1957 Pontiac Safari 2dr wagon TV
Old 12-30-2007, 04:18 PM
Devoman
Commercial Vendor
Devoman's Avatar
Pin
I have only tried a couple pins but I think you and michelle are right about that.The only thing I would have to fix then is the up and down movement of the hitch to make it completly solid.I think I am going to talk to a friend of mine who welds and see what I can do about it here in the future.Thanks everyone.
AIR# 8855
Streamers For Life
Old 12-30-2007, 04:38 PM
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs, Florida
Have you checked with VW? I have the same problem with my car and I bet it's the same receiver. Be interesting to see what you come up with.
Old 02-16-2008, 10:19 AM
ROBERT CROSS
"FRANTIC BANANA"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y., "
If it's snug in that fitting, maybe it could be welded on...
LOST IN THE SIXTIES
" I'll know where I am when I get there"
2006 3/4 Burb 8.1
Hensley
Old 03-14-2008, 08:28 PM
16595
Profile:  2005 31' Classic
Gretna, Nebraska
Receiver slack
My receiver is only a year and a half old and I have a lot of slack in the connection. I have been considering some strips of sheet metal to be inserted along side the shank.
Has anyone tried that?
Also, I wonder if the receiver will continue to get more sloppy if nothing is done to stop the action.
The welding and grinding/fitting would be the best solution if done by a welder who protects the tempering of the steel.
Dwight
31' Classic/GMC 2500HD 6.0L
Old 03-14-2008, 08:39 PM
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills, California
My 2007 Suburban requires a deep drop shank for the WD hitch. The receiver is so loose, that the bottom of the shank where the ball resides can swing back and forth over one inch in either direction. It is ridiculously loose. It clunks and wiggles like it's defective. It is not the hitch pin, in my case. It is simply a sloppy receiver tube. I haven't a clue what to do about it.
Uwe
Old 03-14-2008, 09:02 PM
Devoman
Commercial Vendor
Devoman's Avatar
Hitch
I am planning to try the weld line down the shaft on the top and side of it.I would think this would work but I have not tried it yet.I am still looking into a solutions.I would say though that mine wiggles around about 1/2 inch max but I think it is a tiny bit smaller than that.
AIR# 8855
Streamers For Life
Old 03-14-2008, 09:13 PM
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen, Colorado
Devo, BE CAREFUL welding directly on the vehicle. Disconnecting the vehicle ground line at the battery is not enough. All of the computers are tied into ground as well. It can get expensive quickly.
Find someone that has experience with welding on european vehicles.
Chris
Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
Old 03-14-2008, 09:19 PM
safari57
safari57's Avatar
West Coast, BC
Status: Online
The weld down the top and side does work, we've done it with no issues.
The other question is to have a good look at the receiver as well to make sure that it's not cracked. I've seen this a few times. If you need more info let me know.
Barry
Barry & Donna
vB code is On
Pingbacks are On
Hitch receiver plaques rangebowdrie Off Topic Forum 10 11-30-2007 02:48 PM
Receiver Hitch Bolts Davis Hitches 2 08-04-2006 09:06 AM
Receiver Hitch pin hole repair ? Davis Hitches 1 07-15-2006 06:44 AM
Brake rattle kabila Brakes & Brake Controllers 1 06-16-2005 08:44 PM
plumbing rattle/'99 Safari Antique Pedaler Water Heaters, Filters & Pumps 6 02-07-2003 05:54 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
