Old 10-06-2010, 04:02 PM   #1
2010 25' FB Flying Cloud
Longmont , Colorado
Hitch Receiver on the bumper of Flying Cloud
Hello-
I would like to add a hitch receiver to the bumper/back of my Flying Cloud, so that I may put a bike rack to carry 2 bikes. Does anyone have any advice or experience with this kind of thing?
Thank you in advance.
BobbyWhitit is offline   Reply With Quote
Old 10-06-2010, 04:20 PM   #2
Originally Posted by BobbyWhitit View Post
Hello-
NO DON'T
If you do, you will create rear end separation.
Moment arm is the enemy.
Measure the distance from the rear axle to the bumper plus about 6 inches.
Then how much weight is the bikes, and mounting hardware?
Multiply the distance in feet times the weight.
As an example 8 feet and 100 pounds. That weight would be 800 pounds, sitting still.
Then when you hit a bump, that weight multiplies 2, 3, 4, even 5 times or more.
Now, you can see the momentary bumper weight that you will have, which will rip the frame away from the shell.
No, beefing up the frame doesn't help, it makes it worse.
Most owners do not understand that the shell supports the frame, PERIOD.
That's why they call it "monocoque" construction, which means the shell is "load bearing".
Carry the bikes in the trailer or in a truck if that's what you use for a TV.
Old 10-06-2010, 05:26 PM   #3
Kevin245's Avatar
Hello Bobbywhitit,
You will here stories of success and failures when it comes to bike racks on the rear bumper.
The general consensus is that its a No No".
Here is some reading material that may help you decide.
http://www.airforums.com/forums/f209...highlight=bike
http://www.airforums.com/forums/f464...highlight=bike
http://www.airforums.com/forums/f36/...highlight=bike
http://www.airforums.com/forums/f477...highlight=bike
http://www.airforums.com/forums/f238...highlight=bike
http://www.airforums.com/forums/f42/...highlight=bike
Regards,
Kevin
Eleanor Roosevelt
Old 10-06-2010, 05:55 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I will bet..BIG BET...that it is tried anyway. (its just a tiny little bike...what could that hurt?)
Old 10-07-2010, 01:33 PM   #5
Longmont , Colorado
Thank you for the help. Not gonna do it
Old 10-07-2010, 04:10 PM   #6
Antique Pedaler's Avatar
Laramie , Wyoming
Images: 11
Contact denco unit WBCCI. A couple of members have added hitch receivers for bikes
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup,
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 10-07-2010, 05:12 PM   #7
VIKING's Avatar
Boulder Creek , California
Sad, but true, these are the results of well-meaning, everyday folks like you and me, putting bikes on our bumpers. These are the only ones that we were able to get photos of, as the rest either sank into the ground entirely or exploded into teeny tiny pieces. They still find little bits of aluminum here and there.
I wouldn't set a half-empty beer on my bumper after seeing this.
Good luck to you, and welcome to the forums!
Rich the Viking
Name:	DAMAGE DUE TO BIKES ON BUMPERS.gif
VIKING is offline   Reply With Quote
Old 10-07-2010, 06:48 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If ya look around the area where the Axles are mounted you should readily see that the frame thats there is not a C channel of box tube. Its a thin rail with no flange. Yeah ya see them people with the SOB's with bikes and Motorcycles and stuff hangin off the back See how high they are off the ground. Most are on springs and 6 in C channel.
Keep in mind ITS YOURS ,do what ya want too. But when the outside skin starts to buckle at the rear of the wheel wells,REMEMBER we told ya not too.
I know your gonna try it ,it human nature. Save yourself alot of expensive repair and DON'T.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Using Hensley Hitch with 2007 Tahoe In Bumper Receiver Pete Vermont Hitches, Couplers & Balls 36 01-03-2012 06:55 PM
Hitch on rear of 19 airstream flying cloud 2009 caplka Hitches, Couplers & Balls 1 05-02-2010 12:46 PM
Hitch and receiver rattle Devoman Hitches, Couplers & Balls 53 09-09-2009 08:16 AM
damaged hitch receiver flmgrip Hitches, Couplers & Balls 45 08-21-2009 10:14 PM
