I still don't know much about hitches, etc. But I am one step closer to being able to tow my A/S! I just bought a mint 1994 GMC Suburban K2500 7.4l with 38k miles!
Here's my question. Since I don't have the Suburban and A/S "together" yet, I was hoping someone out there with the same configuration could tell me what type of hitch setup I need (ie, drop length, weight capacity), so that I could start shopping for the setup now.
Well I'll take a stab at this. Most people with burbs of your vintage with 4x4 say they need a 12 inch drop draw bar.
Now what you use for hitch set up is a very debated topic. Personnaly I have the AS but not the Burb yet but I have one I'm very interested in and it's a 88 with 71k and proably 60k of that was with a AS behind it. I decided to go with a Reese Dual cam on mine. THe friction style sway controls are sometimes tempermental and I just didn't want the hassle.
The undisputed top of the line is the Hensley arrow but it's $2500. Little out of my budget.
You next question will be brake controllers...Again there is debate but most feel either the Prodigy or the Jordan are the best.
Hit the towing section of the forums and there is tons of available information on htiches and controlers.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
Originally posted by Craig The Suburban came set up with a Tekonsha Sentinel brake controller, so I'm going with that. For now anyway...
Here is a company that does internet sale. but you should be able to find local. http://www.hitches-forless.com/WD/wd_shanks.htm
Now 12 inches is sort of misleading. The drop section would be 12 inches long but because of the hight of the hitch head the ball dor would be less..
1959 22' Caravanner
Atlanta, GA
Congratulations on the 1994 Suburban find. Your Suburban has less than half the miles of my '99 (currently at 103,500). Since your 1994 is in the same family line as my '99 which is also a K2500 series; I am fairly certain that you will need approximately the same drop that I am using (assuming that your Suburban has the stock tire/wheel combination).
The Reese Drop Bar that I am using is a R54917. It is almost 1" too high for my Minuet 6.0 Metre which would prefer a height of 18"; but I believe that your '78 Airstream likely calls for a height of 18.5" which should make this draw bar quite workable for your situation -- especially if you get a ball mount with a flat area where the ball mounts rather than the raised section that my 1978 period ball mount has - - results in an addtional .5" rise that I don't need. The photo below is of the mount installed on my Suburban:
Good luck with your hitch set-up.
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
Thanks for your response. I think the terminology being used is what's confusing me. I looked up the hitch you mentioned on the Reese website and it says that model has a 6" drop. Why do you call it a 12"?
The reason that I have always referred to the bar as a 12" drop is based on the measurement of the bar from the top of the bar to its lowest point - - it will only actually drop the ball height between 5" and 6" depending upon the style of ball mount and the actual design of the ball utilized in the hitch setup.
Kevin
Kevin
Ahhhhh. OK. So the bar is 12", but the drop is only 6". Are you happy with your drop bar? What do you use for your weight distribution?
So if I am understanding all of this correctly, I need to shop for:
1) an adjustable hitch draw bar (w/6" drop)
2) hitch ball
3) weight distribution system
Originally posted by Craig Ahhhhh. OK. So the bar is 12", but the drop is only 6". Are you happy with your drop bar? What do you use for your weight distribution?
2) hitch ball
Thanks, Kevin!
Craig
4) Anti sway device.
You could go with either a Dual cam set up or a friction sway. Most people find the dual cam is more effective but the recomended tounge weigh is 400+ pounds.
Your distribution system is tuned to the tounge weight so you need to find that out before you purches the spring bars. Our 59 Caravanner is somewhere around 550lb and we are going to run 750lb bars.
1959 22' Caravanner
Atlanta, GA
I was just going to go w/ 1,000lb bars. I don't have a way to actually meaure the tongue weight, but thought the 1,000lb bars should be safe. All I found in my manaul is that the tongue weight should be 10-15% of the total TT weight, but no more than 1,000 lbs. And my Excella, fully loaded, had a max weight of 8,500lbs.
Could someone out there with an Excella 500 of tell me what they use?
hello
i had a 78 excella 500 and i towed it with a 97 suburban. i had a eazy lift hitch and used the friction sway control and never had a problem but once when i didnt tighten the sway control . other than that i put a lot of miles on the excella and sub. i still have the drop bar i offered it to a member some time ago and never heard from him again. its for sale at a reasonable price. if interested send me a email. lol
al
