Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 12-14-2006, 03:06 PM   #1
Profile:  1971 23' Safari
Groveport , Ohio
Images: 18
Hitch Question
TV 02 suburban pulling 71 23' safari. The shank that came w/trailer is 16".I dont think it needs to be that long,it has to reduce tounge capacity alot.The reciever is factory.Can I drill another hole to make it shorter.I'll try a photo.
bertro is offline   Reply With Quote
Old 12-14-2006, 03:20 PM   #2
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Arrow Towbar question.
If that was casted towbar the manufacturers advise you not to cut or alter their towbars. Yours looks as if it was welded cold steel bar. Personaly I do not see any reason for not doing so, providing you center the pin hole properly, and make sure that you have enough turning clearance with load levelers on. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-14-2006, 03:26 PM   #3
Profile:  1977 31' Sovereign
McHenry , Illinois
You should be able to drill this one. Looks like you have a place for a frictional dampener on it also. If you do not have the twin cam setup, I might put a dampener on it. Be sure to take it off before you do any tight parking manuevers as that has the potential to bend the dampener.
Old 12-14-2006, 03:31 PM   #4
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Just as an added though, used draw bars are on eBay for a dime a dozen....ok, maybe not all that inexpensive, but might be worth a look. I picked a reese shipped for about $18.
Old 12-14-2006, 03:48 PM   #5
Profile:  1976 25' Caravanner
Campton , New Hampshire
You may want to just leave it , might be handy if you want to slip a bike rack or mud flaps on . I don't think it is hurting your particular setup all that much . It can be drilled but you won't be able to go back to that length again because of the extra hole . It will also take a good size drill press and some good bits to drill that hole . Another thought is you may be able to trade with someone who is after a longer one . Good luck
ticki2 is offline   Reply With Quote
Old 12-14-2006, 04:39 PM   #6
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
Yes you can---I did the very same thing--the closer you can get the ball mount to the tow vehicle the less leverage the trailer has on the tow vehicle.
I would use a drill press so the hole is straight through.---pieman
Mike Lewis is offline   Reply With Quote
Old 12-14-2006, 05:34 PM   #7
Melody Ranch's Avatar
Profile:  1966 17' Caravel
Valley View , Texas
Wow
Thats a Dusey!
(Ref. another thread.)
Old 12-14-2006, 05:57 PM   #8
Groveport , Ohio
Images: 18
Thanks for the feedback,
I think I will drill.Should I go From 16" to 10" or 12" or shorter.Also sorry if other post of the same show up I was really struggeling trying to post a photo.Thanks Robert
Old 12-14-2006, 06:05 PM   #9
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Although I would not recommend drilling - if you must - check and see if the bar will slide all the way in. On mine, the spare tire blocks any additional bar length - this means you may have to cut the length also.
Drill slow and start with a pilot hole and work your way up. Use a drilling fluid to cool the bit. Good Luck.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 12-14-2006, 08:18 PM   #10
Profile:  1960 24' Tradewind
santa barbara , California
I did the same thing on my drawbar ,it was an upgrade from the old 1 3/4
60s EZ lift (not equalizer) .The new was standard 2" and was 4 to 5" longer .
i towed once with it and noticed notable sway that I relieved with more friction on the sway control .I got home and proceded to shorten it 5" to
what the older length was .i had a machine shop do it so they could square
the drawbar and center the hole .Results were excellent and solved the
"new" sway (not there before ) the closer the ball is to the rear axle results
in much reduced sway .Thats why alot of SUVs with minimal rear body length
past the rear axle have minimal sway issues .agree with the others to check
how much you can go in without turning interference with the bumper or
trailer in tight turns ,but the closer the better .
Scott
scottanlily is offline   Reply With Quote
Old 12-15-2006, 11:55 AM   #11
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Bertro,
I'd be real cautious before I reduced the length - your 'Burb barn doors or tailgate may not have enough clearance to open. If you have a 2500, you've got plenty of tongue weight capacity. You still do with a 1500, by the way.
Pat
pmclemore is offline   Reply With Quote
Old 12-15-2006, 12:51 PM   #12
Profile:  1975 27' Overlander
In the Kootenays , BC
I agree with Scott (on hitch setup matters, anyway ). A short overhang is probably as much a factor in stable towing as a long wheelbase, since the overhang affects how much leverage the trailer can place on the TV, and the wheelbase works to resist that leverage. A longer overhang setup also needs more tension on the wdh to achieve weight transfer, because there's more weight on the rear axle to begin with. Getting the ball as close to the bumper as possible is just a sensible and economical way of ensuring maximum stability. It may not make a noticeable difference in every case, but it sure can't hurt.
If you have a receiver that's open at the front end (like the factory GM receivers), don't cut the shank but simply drill another hole. That way you can adjust the position if you want to, e.g. to clear the tailgate.
A shank is typically cold rolled mild steel (SAE 1010 to 1020 at best, I expect), 2" square; I can't see that the strength would be unduly affected by drilling. It's certainly a lot stronger than the 2.5" x 1/4" wall receiver tube that it slides into. If anyone has first hand experience that would counter my opinion, please let me know.
The easiest way to drill the new hole (5/8" BTW) is to slide the shank into a receiver tube (with the correct, centred hole in it to use as a template), clamp the works onto a drill press table, and go for it. However, unless you fabricate custom receivers or go to a shop that does, you won't have a spare tube available. Therefore, you will want to carefully measure, centre punch, and pilot drill the hole before drilling to the final size.
Any small machine shop or welding shop would be able to do this job in short order if you don't have the equipment and tools.
AlbertF is offline   Reply With Quote
Old 12-16-2006, 06:22 PM   #13
Groveport , Ohio
Images: 18
Modified shank
Thank you everyone,
I drilled another 5/8 hole today shortend it 5".The rear door clears jack by1".I have only pulled the camper one time to bring it home recently.I will have to read up more about setting up WD.it seems that the rear of TV is squatting to much.What I have read says to set ball 1/2" above top of tounge w/level trailer.I think my bars are 1000# I'm afraid to pull and cause damage untill I learn more.I like photos to. I'll try
Thanks Robert
Name:	reworked hitch 004.jpg
ID:	29828  Click image for larger version
Name:	reworked hitch 002.jpg
Name:	reworked hitch 001.jpg
Old 12-16-2006, 06:42 PM   #14
That looks good there bertro ,and you should immediately notice better stability and less sway ,even the little movement that you can feel can be helped considerably .You do need to take up some links as you definately
have no upward curve to your bars .When the TV and trailer is level ,the bars will show this upward curvature of about 2" at the ends .
Scott
Pingbacks are On
Hitch Setup Jabba Hitches 2 10-04-2002 10:33 AM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
SEO by vBSEO 3.1.0
