Old 04-30-2014, 05:54 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Hitch Problem with New Ram 2500
Well I should have taken this into consideration when I traded my Chevy Avalanche in on the Ram 2500. Went to move the Airstream tonight and the coupler/angle of the trailer looked like it was ready for take off. I have used a Reese weight distribution hitch with our Avalanche without issue...but then it was set for the truck.
Now I've got a problem. I would like to stay with the Reese system and distribution bars. But after measuring from the top of the hitch opening (24") and bottom of the coupler (13") find myself about 11" to high. What options do I have at this point? Look for an 11" drop? Do they even make such a thing? Can I use anything off my current hitch? Thanks for the help!
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 04-30-2014, 05:59 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes Reese has an extended drop shank but you have other problems if you coupler is only 13 ins. off the ground. That should be closer to 18 ins.
Why so low?
2004 Excursion 4x4
Old 04-30-2014, 06:22 PM   #3
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Good point! It was dark when I measured the coupler and eye-balled it for level. I'll grab a level and flashlight and head back out for another measurement. I thought that was low also. Would make a big difference on the drop shank.
Indiana, PA
TAC PA-5
WBCCI 4871
Old 04-30-2014, 06:40 PM   #4
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I drive 2500 2013 Suburban with at least 9" drop shank with my Reese setup.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-30-2014, 06:46 PM   #5
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Well I suspect that my lot is not level...to my eye it is. Leveled the trailer using a level and still around 13". Anyone out there with a "74" and know what is the height of their coupler? I would guess that the height should be the same. Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
Old 04-30-2014, 06:52 PM   #6
HowieE's Avatar
Images: 12
The trailer does not want to be level when checking this . Parallel to the ground is what you are after.
If you can get things to a location that will have the trailer and the. Truck on the same plane.
2004 Excursion 4x4
Old 04-30-2014, 06:55 PM   #7
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
After looking at Airstreams specs for the 70's trailers, it would appear that the recommended ball height is 19.5". This would be on a new trailer, on level ground, with good axles. Would I be safe to use this number and go with a 6" drop hitch?
Indiana, PA
TAC PA-5
WBCCI 4871
Old 04-30-2014, 07:03 PM   #8
HowieE's Avatar
Images: 12
You have to first find out how your trailer axles are now. Set the trailer parallel to the ground and measure the frame for and aft to ensure you are parallel to the ground. Now measure the coupling height. You axles may have dropped.
With a double or tri axle Airstream the trailer has to ride parallel to the ground
If not you will be tongue heavy if the coupler is high and tongue light if the coupler is low.
2004 Excursion 4x4
Old 04-30-2014, 07:11 PM   #9
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Thanks Howie...that makes sense. This is a "74" whose axles should probably be replaced. That being the case, I would probably pick up another 2-3". Challenge I have now is not being able to move this trailer to a level spot. Interestingly enough, I have a "78" sitting near the "74" and it's coupler comes in around 17". Still an issue with the slope of the lot. I'll get the tape measure out tomorrow and make sure the front and rear frames are set at the same height then measure the coupler height. Thanks for you help!
Indiana, PA
TAC PA-5
WBCCI 4871
Old 04-30-2014, 07:24 PM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you can get up to 11 inch drop. I pull a 1988 with a 2500 4x4 with a 6" drop, Reese hitch, and it is about right. You need to find out how high coupler needs to be. And the ball is only going to drop an inch when you hook up.
Old 04-30-2014, 07:31 PM   #11
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have a 13 Ram 2500 diesel 4x4. I use a Curt drop bar which I bought from Amazon . As I recall the maximum drop is around 7.5 inches. The cost was around $80. much cheaper than a reese drop bar.. I am using it with a Reese head. Sorry I don't have the numbers, we are on the road right now.
The trailer is level and I have one more hole down available.
Since we have similiar trucks this should work for you. My ball height is 18 inches on the 61 on the original axles.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-30-2014, 09:06 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I removed the factory receiver and added the Curt 15049 hitch to the 2012 Ram 2500HD and converted to an all air bag level ride suspension that lowered the back end of the truck to level. That combination needed only 1.5" offset from level with the adjustable stinger that comes on a ProPride hitch. The trailer tows about ¼" nose down from level measuring at opposite ends of the trailer.
I wonder about the leverage forces associated with an 11" drop using a weight distribution hitch system. That much drop may require a beefed up receiver on the tow vehicle.
Old 05-05-2014, 11:08 AM   #13
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Drop Bar Ordered
Thanks to all those that responded to my request for information. I never expected it would be so difficult to find a 6" drop bar. I have ordered a Curt from Amazon...thx Rick! Again...the Forum members come through...
Bob "Roadrunner"
Indiana, PA
TAC PA-5
WBCCI 4871
Factory Receiver Hitch Dodge Ram 2500 SteveH Hitches, Couplers & Balls 11 12-16-2013 11:16 PM
06 Ram 2500 and 08 Classic 27' breazy Tow Vehicles 9 01-17-2012 08:05 PM
Dodge Ram 2500 Vs. Ford F250 ecotrailer Tow Vehicles 35 12-13-2009 09:33 AM
Dodge Ram 2500 Diesel Foiled Again Tow Vehicles 23 10-18-2007 09:01 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
